ECGS bushing replacement and write up to follow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nazlax10, Jan 26, 2017.
  1. Jul 19, 2018 at 5:45 AM
    #121
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Someone who has done this before can do it about an hour depending on if all of the nuts and bolt break loose. With someone who is doing this for the first time with a couple of rusty bolts, it can taking upwards of 2-3 hours. There are a couple of YouTube videos on how to do it. Even if a mechanic, home grown or professional, has not done it before, show them a couple of YouTube videos on it the help them get a better idea on how to do it. Make sure you get a new axle seal before you do it and you might want to have them clean up the edges of the axle seal hole with some heavy grade sandpaper .....it might be sharp from surface rust, before the new seal goes back in. I made that mistake and I ripped a brand new axle seal putting it in with cleaning it and needed to get another one.
  2. Jul 19, 2018 at 6:08 AM
    #122
    lee1092
    lee1092 Well-Known Member
    Lee
    Charlotte, NC
    18 MGM Tacoma
    What is an axle seal? New to all of this. Havent seen this brought up yet
  3. Jul 19, 2018 at 9:56 AM
    #123
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Took my mechanic 2.5 hours to do. This was including a new axle seal as well.
  4. Jul 19, 2018 at 7:09 PM
    #124
    crashngiggles
    Jared
    the axel seal is a rubber coated metal seal the butts up against the bushing that keeps the front differential fluid from coming out. Just go to your local toyota dealership and pick one up or have them order you one. They are fairly cheap. You will take out the old one, then take out the needle bearing, then out in the new bushing, then new axle seal, then top off the front differential fluid.
    lee1092[QUOTED] likes this.
  5. Jul 20, 2018 at 2:52 AM
    #125
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Have you ordered the bushing from ECGS yet? If not, they have the seal too. However, normally, the seal does not need to be replaced. It wouldn't hurt to have one on hand though. There's a few you tube videos that go over the process.
    lee1092 likes this.
  6. Jul 20, 2018 at 5:29 AM
    #126
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    Ordering when I order the lift. The trucks new so I guess the seal is ok?
  7. Jul 20, 2018 at 5:30 AM
    #127
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    What if the trucks new? Shouldn't need a new seal?
  8. Jul 20, 2018 at 5:50 AM
    #128
    NBourque
    Nick
    Maine
    ‘21 PRO
    A new seal is handy to have and cheap just in case u damage the old seal while pulling out the bearing.
  9. Jul 30, 2018 at 7:33 AM
    #129
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I swapped my needle bearing out at about 100K for the ECGS bushing. did not replace the seal, it looked fine, felt fine. developed a slow drip in this area. Swapped seal next weekend. no more drip. Then sold truck :facepalm:
    m603holden likes this.
  10. Jul 30, 2018 at 10:50 AM
    #130
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Anyone need the the puller? PM me
    Edit:Sold!
  11. Jul 31, 2018 at 1:42 PM
    #131
    CBenfell
    CBenfell I don’t know sh*t about f*ck
    Christian
    Western Washington
    21 DCSB TRD OR Midnight Metallic Black
    Crippling Debt
    Would I know for sure if I have vibes, I have on 05 AC that I just buy Billies on @ .85. You could say I’m a bit paranoid about getting the vibrations. I’m uncertain if it could be my roads, tires, engine reving, but whatever sensation I’m getting is very subtle. Also, switching to 4h doesn’t always change anything. If I had vibes, would it be obvious?
  12. Aug 1, 2018 at 12:55 PM
    #132
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    thanks for the info! I'm looking at replacing mine in a couple weeks and was hoping I could do this without removing the ball joint.
    I'd be happy to pay the shipping to/from to borrow your puller :thumbsup:
  13. Aug 3, 2018 at 4:25 AM
    #133
    BearintheWoods
    BearintheWoods Well-Known Member
    Barry
    2018 Black Tacoma Off Road
    Sure, be glad to. You want to PM me your address?
  14. Aug 3, 2018 at 6:37 AM
    #134
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Curious...lifting my new-to-me 2nd Gen and wondering if anyone has tried to remove the OEM needle bearing with a blind bearing puller? Always itching to use tools I have but don't often use. Thanks!
  15. Aug 7, 2018 at 1:41 PM
    #135
    WillT11
    WillT11 Well-Known Member
    Will
    I have the puller, a driver kit for the bearing, and an extra seal. Will send first two for shipping, preferably to someone who would like to purchase the seal. Didn't use it at install as my seal seemed fine. $15 seal + shipping. Tools free
  16. Aug 7, 2018 at 4:21 PM
    #136
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    I’ll take the puller
  17. Aug 27, 2018 at 6:54 PM
    #137
    RhodeIsland4bang
    RhodeIsland4bang Back seats are for freeloaders!
    Rhode Island, USA
    2011 DCSB SR5 6MT
    Count of one four legged freeloader
    Just bought the full potatoes from @ECGS. Install tool, removal tool, bushing, and axle seal.
    Hoping to get this done a few weekends from now, tools will likely go up for sale then. :thumbsup:
    Thanks everyone that posted info on how to get this install done right.
  18. Aug 30, 2018 at 9:58 AM
    #138
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    I'll be driving up to RI the 17th. I'll swing by for them :wink:
  19. Aug 30, 2018 at 10:02 PM
    #139
    RhodeIsland4bang
    Rhode Island, USA
    2011 DCSB SR5 6MT
    I’m glad you said this now I have to get it done haha, hit me up!
  20. Sep 20, 2018 at 7:18 PM
    #140
    FuzzysTacos
    Corey
    Wichita, KS
    You've got until Sunday evening!
