ECGS Bushing Tool
Discussion in 'Colorado' started by krm11, Mar 25, 2024.
  1. Mar 25, 2024 at 10:41 AM
    krm11
    krm11 [OP] Well-Known Member
    Kyle
    2011 Tacoma Ext Cab Long Bed
    Hey all, looking at doing the ECGS bushing swap on my '11 in the next week or so (basically whenever the bushing gets to my doorstep). Looks like ECGS charges a pretty penny to add on the install and removal tools. After watching some youtube videos i feel pretty confident installing with homemade tools but the removal tool looks pretty handy.
    Does anyone in the greater Denver area have the removal tool that I could borrow for a few bucks? (i'd love to borrow the install tool if you have it also) If it comes down to it i'd pay their $45 for the removal tool to save the headaches but wouldn't mind saving a few $$ if I can.
    Removal and Install tools linked here: https://eastcoastgearsupply.com/i-8536125-toyota-8-clamshell-bushing-eliminates-needle-bearing.html
    Thanks!
  2. Mar 25, 2024 at 10:55 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    krm11[OP] likes this.
  3. Mar 25, 2024 at 11:13 AM
    krm11
    Kyle
    All good, found a secondhand one from a TW member. Once i'm done i'll be happy to pass it on to the next lucky winner if someone needs. haha
    bryank and TnShooter like this.
  4. Mar 25, 2024 at 11:13 AM
    krm11
    Kyle
    This is good to know though, if i had a bit more fab capabilities i'd consider it. the tool does look pretty simple overall...
    TnShooter[QUOTED] likes this.
  5. Mar 25, 2024 at 11:18 AM
    pp2small
    pp2small Well-Known Member
    Brian
    Socal
    2022 TRD Offroad
    good choice to pick up the removal tool as it makes it much simpler. I bought the removal tool only when i purchased the bushing and just for kicks i tried removing the needle bearing without the tool using some parts i had laying around.
    Just note that like most people here, i had to remove some material on the removal tool (nut part) in order to get it to fit behind the needle bearing.
    Bushing install tool was not needed. I used an axle nut ~32mm and a deadblow hammer to press the new bushing in.
  6. Mar 25, 2024 at 11:30 AM
    TnShooter
    Deogee
    STOCK
    I bought the install tool because once the tool bottoms out, the bushing is set correctly. Same for the seal.
    The install tool is not needed. It’s only for convenience.
    T4R_hereforbearings likes this.
  7. Mar 26, 2024 at 8:48 PM
    Dead-Weight
    Dead-Weight Well-Known Member
    Scott
    Sedalia, CO
    ‘22 OR Lunar Rock
    Pine tree air freshener
    Very nice of you to offer this up! I’m not needing one- just wanted to give you a gold star for your kindness. The world needs more people like you. :burnrubber:
    TnShooter likes this.
  8. Mar 28, 2024 at 9:53 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    For both the bushing and the seal, take note of where the factory one is and drive the replacement ones in at the same place. You can drive the axle seal in too far and it will leak then.
    For the removal tool, you have to center it perfectly or the whole unit will spin and not press out. If its not centered it can also bend the thick steal plate instead of pressing out the old bearing.
  9. Apr 18, 2024 at 10:01 AM
    2muchhp
    2muchhp Member
    2014 tacoma TRD Sport
    None at this time
    Can I get on the list for the tool pls.
    Thx
  10. Apr 22, 2024 at 1:24 PM
    2muchhp
    2muchhp Member
    None at this time
    If I bump this 42 more times I can post this question where it needs to be.
    CO MTN Steve likes this.
  11. Apr 23, 2024 at 7:35 AM
    krm11
    Kyle
    No problem, I'll send my contact info via PM (hopefully you can receive at least? not sure what the permissions are).
  12. Apr 23, 2024 at 11:59 AM
    2muchhp
    2muchhp Member
    None at this time
    Thanks for reaching out, headed too PM.
