ECGS BUSHINGS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TN1000, Mar 19, 2024.
  1. Mar 19, 2024 at 4:21 PM
    TN1000
    TN1000 [OP] Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    I have read countless threads and talk about ECGS clamshell bushings (on the driver side) when you lift your truck, but I never hear or read anything about the passenger side. is this ball bearing not as important of a replacement, or should both be done at the same time?
  2. Mar 19, 2024 at 4:25 PM
    timw1
    timw1 Well-Known Member
    Tim
    Arapahoe, NC
    2023 Tacoma TRD OR DCSB
    I'm new here as well, but what I understand from reading numerous posts, only the drivers side is needed.
  3. Mar 19, 2024 at 4:50 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Passengerside isn't affected because of the ADD unit and also it having it's own bearing at the end of the housing. The shortness of the D-side inner shaft doesn't help matters either.
  4. Mar 19, 2024 at 5:25 PM
    545 Well-Known Member
    2015 Access Cab
    Toyota only puts a needle bearing on the driver side
    It does not respond well to lateral loads, and it’s always under a lateral load when lifted
  5. Mar 19, 2024 at 5:31 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Mines been lifted for some time, haven’t replaced any bearings or bushings. Maybe I’ve been lucky. If trouble finds me, then I’ll react.
  6. Mar 19, 2024 at 5:34 PM
    guest_707
    guest_707 Well-Known Member
    Can anything bad happen other than vibrations and humming sounds if you don't replace the needle bearing? I've had my lift and mud tires on for a year now and tbh, I can't even tell if I need the ecgs bushing done because there's always a bit of vibration from the loud ass tires, lmao. I got the MTs put on a month after I got the lift and didn't feel any vibrations or humming and I've put it into 4Hi to see if there's a difference.
  7. Mar 19, 2024 at 5:58 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Bad is subjective but needle bearings fail, will cause premature wear of the CV, potentially damage the diff.
    guest_707[QUOTED] likes this.
  8. Mar 19, 2024 at 6:20 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    To answer the OP’s original question…There is only one on the driver’s side.
  9. Mar 20, 2024 at 3:58 PM
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    Learn something new everyday I thought this replacement needed to be done on both driver and passenger side. Good to know for when I do the front end and do it while I’m in there.
  10. Mar 20, 2024 at 4:01 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    If the needle bearing fails and breaks apart, pieces could easily end up in your diff. It's better to replace them when they're in one piece.
    It's a very easy job with the proper tools. Not worth ignoring, IMO.
  11. Jun 10, 2024 at 1:21 PM
    IA DIY
    IA DIY Well-Known Member
    Iowa
    2008 DCLB 4x4
    Good info, thanks!
  12. Jun 10, 2024 at 6:47 PM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    from what I understand there is a needle bearing on both sides, the difference is the passenger side has a bearing on one end that takes most of the load/force which is why the passenger side doesnt have the same issues as the driver side.
