Ecgs busing: some noise normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GawainXR, Sep 8, 2024.
  1. Sep 8, 2024 at 7:02 PM
    GawainXR
    GawainXR [OP] Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Is it normal for there to be friction noise with an ECGS bushing similar to that of a bad wheel bearing?
    I installed the ecgs bearing kit, taking my time and following the directions and several videos.
    The hub rotates without issue although there is definitely a more pronounced noise when free spinning the wheel by hand over the stock bearing and passenger side.
  2. Sep 8, 2024 at 7:39 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    I've double checked and verified it's not the rock guard rubbing on the caliper and the noise indeed is coming from the bushing
  3. Sep 8, 2024 at 9:42 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Was there noise before changing out to ECGS bushing kit?
    You put light film of grease on inside of ECGS bushing before putting CV axle back in?
  4. Sep 8, 2024 at 9:45 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    No noise prior, I was doing it as a preventative maintenance item.
    I made sure to smear 75w85 on it inside and out as well as made sure it was driven flush with the carrier using the supplied tool.
  5. Sep 8, 2024 at 9:46 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    You’re sure you checked noise before you swapped? The left axle turns spider gears, the right axle turns nothing but an intermediate shaft that isn’t connected to the diff in 2WD. So it is normal to hear differences in noises between the two sides when free wheeling them, because they are turning different things.
    To answer your question, I did not notice any additional noise with my bushing. I do have a light clank noise from the spider gears turning if I turn my left wheel in the air.
  6. Sep 8, 2024 at 9:47 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    It sounds like the CV is chafing against the bushing but I wasn't sure whether that's normal break in noise or not. Planning to call ecgs first thing in the morning.
  7. Sep 8, 2024 at 9:58 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
  8. Sep 9, 2024 at 12:12 AM
    STEELeR43
    Hawaii
    You sure the ECGS Bushing is flush with carrier? Did drive the bushing past flush, and it contacting spider gear?
  9. Sep 9, 2024 at 3:48 AM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    It's flush, I used the tool to install it and then ran my finger along afterwards to make sure there wasn't a lip.
    Unless perhaps somehow when wearing the CV in, it pushed it past flush some?
  10. Sep 9, 2024 at 4:00 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    After I installed my ECGS bushing there was still some remaining sound on the left side. Turned out my left front wheel bearing was going bad.
  11. Sep 9, 2024 at 2:13 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Figured it out! The caliper was just scrubbing the rotor, which I was able to isolate by having someone spin the tire while I listened closely, I then verified by pulling the brake pads and the noise going away. The differential makes a very subtle noise that sounds kind of like you were gently blowing on a pinwheel, but ecgs says that's very normal spider gear noise so all is well.
  12. Sep 9, 2024 at 2:16 PM
    BLtheP
    Plano, TX
    I was going to suggest that, but when the right side was quieter than the left side, I figured it wasn't that. Good to hear it's resolved at least.
