ECGS needle bearing replacement for vibration/rotational groan
Discussion in 'Hawaii' started by Segjohvg, Jan 19, 2023.
  1. Jan 19, 2023 at 5:31 PM
    Segjohvg
    Segjohvg [OP] Member
  2. Jan 19, 2023 at 5:41 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    It is well thought of here.
  3. Jan 19, 2023 at 5:47 PM
    Segjohvg
    My dealership brushed it off multiple times saying it's normal. Did you find anywhere that fixes it with a good aftermarket replacement?
  4. Jan 19, 2023 at 5:49 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I’ve replaced my needle bearing a few years ago. It’s a mid level DIY job. I
    replaced the oil seal while I was in there.
  5. Jan 19, 2023 at 5:50 PM
    fxntime
    The ECGS replacement is what everyone swears by.
    AR15xAR10 likes this.
  6. Jan 19, 2023 at 5:50 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Take the truck to an independent shop who will install the ECGS bushing. Call around. You can order the bushing yourself and borrow install tools and provide all to the shop. Or do it yourself if able.
    There’s got to be a shop on the island that’s done this a few times.
  7. Jan 19, 2023 at 6:14 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I've done over 20 of them. Most off road shops can handle it for you. I wouldn't trust this to just anyone, if not replacing it yourself. As simple as some make it seem, the repair can easily go sideways.
  8. Jan 19, 2023 at 6:24 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I thought this repair was always done sideways…hardee har har
    Superdave1.0[QUOTED] likes this.
  9. Jan 19, 2023 at 6:27 PM
    Superdave1.0
    SoCal
    Upside down when you get real good at it. :thumbsup:
    Hook78[QUOTED] likes this.
  10. Mar 12, 2023 at 12:36 PM
    tARRRRGHd
    tARRRRGHd Active Member
    Looking to have this done on my ‘23 when it arrives from Servco. Willing to pay somewhere here who is experienced and can do it for me. Thanks!
    I called MJ but they said they cannot do it.
    TacoBob808 likes this.
  11. May 26, 2023 at 11:34 PM
    tARRRRGHd
    Hey, I’m on Oahu and have been looking for someone to install this for me. Would you be able to? I’ll happily pay brother. Let me know. Thanks!
  12. May 27, 2023 at 12:26 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  13. May 30, 2023 at 1:01 AM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    Got my ecgs bushing install done today. I took my time and got it done in about 2 1/2 hours. Those who are mechanically inclined should have no issues getting this job done with all the tutorials out there. Stock needle bearing came out pretty easily and didn't break on the way out. I did modify the tool a bit to help it get behind the bearing easier.
  14. May 30, 2023 at 1:04 AM
    tARRRRGHd
    Glad to hear man! I’m still in the hunt for someone to do mine since I’m not mechanically inclined whatsoever. I called MJs and they don’t do them. Would you be willing to do mine if I compensated you?
  15. May 30, 2023 at 1:46 AM
    808stateofmind
    Kona
    I live on big island, unfortunately, so i cant help you out... but theres gotta be a shop that does it over there. Does mj have another shop do the bushings or do they just not do add them to their builds? Try find guys on Instagram or something from oahu that have lifts and ask if they have it done and where they did it. There's one shop i know of on big island that does it and they charge $350
  16. May 30, 2023 at 2:01 AM
    tARRRRGHd
    Ah no problem brother. MJ does lots of taco lifts and surprisingly, they never do it on the trucks. I just know it’ll eventually be a problem, and would rather have the piece of mind and do it right from the start. I’ll do more digging man. Thank you
  17. May 30, 2023 at 10:46 AM
    808stateofmind
    Kona
    Yea thats the main reason i changed mine out. In gonna lift this week and id rather do it now than down the road. Good luck finding someone to do yours
