Ecgs removal tool, does anyone have one ?
Discussion in 'Ontario, Canada' started by TacomaGirl555, Nov 10, 2020.
  1. Nov 13, 2020 at 3:32 PM
    TacomaGirl555
    TacomaGirl555 [OP] Well-Known Member
    Ya awesome
    llamasmurf and tacoma16 like this.
  2. Nov 14, 2020 at 4:21 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    @TacomaGirl555 I knew these guys would help, just had to get their eyes on it :rolleyes:
    To tag someone, you use the @ and start typing their nickname, it will bring up auto complete list and notify them they have been tagged:thumbsup:
    Skada, Atlas86, Manfred and 3 others like this.
  3. Nov 14, 2020 at 4:34 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Gotta love this group!
    she should be getting the tool tomorrow!
  4. Nov 14, 2020 at 5:03 PM
    TacomaGirl555
    You guys rock
    I will be doing it next weekend with my dad, hope this does the trick. I’ll let you guys know. After I fix it, is there any other potential problems I might have with the lift?
    Manfred and llamasmurf like this.
  5. Nov 14, 2020 at 5:21 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Just take of shudders in the rear do to pinion angle. I can explain it all to you tomorrow.
  6. Nov 15, 2020 at 9:51 AM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    did you get it?! Mission successful?
  7. Nov 15, 2020 at 9:53 AM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    correction it was all @tgelata who made it lol
  8. Nov 15, 2020 at 10:10 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Dropped it off an hour or two ago. Mission accomplished
  9. Nov 15, 2020 at 12:32 PM
    TacomaGirl555
    Yes thanks, going to do next weekend...thanks again Peter
    tgelata, llamasmurf and tacoma16 like this.
  10. Nov 18, 2020 at 5:13 AM
    TacomaGirl555
    Hey Guys @tgelata @tacoma16 @llamasmurf
    hoping to get some advice
    Went to Toyota last night to get some differential oil for my project to replace needle bearing, same place I took my truck complaining of noise. The parts manger who I have come to know and trust over the last few years went to double check on what type of gear oil I needed. After checking into some things he pulled me aside and said that several 2018 & 2019 models had problems with noise/vibration on the front end and had the entire front carrier replaced under warranty. (not sure what that is) He advised that my truck according to the vin has the same part number as the ones having the problem. He is going to look into having this covered under warranty and is going to get back to me. (lift may be a problem with warranty)
    Option #1: if they cover this under warranty should I just get this done and see if it fixes the problem or just do the needle bearing replacement like I was going to
    or
    Option #2: Should I just wash my hands trade in and get stock again........ I was offered $38,000 trade in for my truck from another Toyota dealership
  11. Nov 18, 2020 at 6:01 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    Im assuming the front carrier is the diff?
    Id let them warranty it first cause well free parts and it’ll be replacing the needle bearing anyways. You still might need to do the ecgs bushing but this would just delay having to do it
    plus there could be more going on if toyota thinks its worth it to swap the whole diff under warranty
    Cant speak for trade in because it would still be the same truck just stock
    Unless you wanted to get a different cab/bed length
  12. Nov 18, 2020 at 8:20 AM
    TacomaGirl555
    Tyler
    The cab /bed length would make a difference in the truck?
  13. Nov 18, 2020 at 8:33 AM
    tgelata
    Probably at work.
    Sorry i more meant trim level lol. the 2021’s have some more tech packages but as far as ive looked into it the same truck mechanically as what you have now
    but an access cab long bed and a double cab short bed have a shorter wheel base than a double cab long bed. Thats about it. (Fyi)
    so unless u want something different than what you have now its not worth trading in IMO
  14. Nov 18, 2020 at 8:51 AM
    llamasmurf
    Wes
    Northern Ontario
    My dealership never mentioned my 'lift' at all. If its under 3" it should not be a problem.
    Get that warranty goodness if you can :rolleyes: Might just solve the issue.
  15. Nov 18, 2020 at 9:07 AM
    #35
    TacomaGirl555
    thanks
    Ya think I will get it done if they cover it, parts guy is going to call me back, and let me know if they will do it
    llamasmurf[QUOTED] and tgelata like this.
  16. Nov 18, 2020 at 3:46 PM
    #36
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    As mentioned go for the warranty, sometimes if the financing is better it may be worth it, but you’ll be getting a stock truck so what ever you have put into the current truck is gone.
    Also as Tyler said, the trim level on the trade. Of your trading your truck in for a lower trim level, is that okay with you? just comes done to what you have vs what you can get and if it’s worth it.
  17. Nov 19, 2020 at 11:41 AM
    #37
    TacomaGirl555
    Hi Peter
    you are right I have done a lot of stuff already, lift, rails, front window tint, pro grill, tonneau cover, decals,
    still haven't heard from guy at Toyota, called left message ... don't want to do ECGS bearing yet in case they do warranty work and my ECGS gets taken out with new parts lol, as I know I will replace anyways once warranty work is hopefully done.
  18. Nov 23, 2020 at 3:12 PM
    #38
    TacomaGirl555
    Hey guys
    just got back from Toyota, they are replacing the entire front differential, all under warranty.
    Toms2Yotas, tgelata, Manfred and 2 others like this.
  19. Nov 23, 2020 at 5:24 PM
    #39
    llamasmurf
    Wes
    Northern Ontario
    :bananadance:
    :woot:
  20. Nov 23, 2020 at 5:41 PM
    #40
    TacomaGirl555
