Eclipse AVN62D issue
Discussion in 'Audio & Video' started by kooltacoma, Feb 24, 2010.
  1. Feb 24, 2010 at 11:11 PM
    kooltacoma
    kooltacoma [OP] Active Member
    Las Vegas
    08 Prerunner
    Hello all, I just installed the Eclipse AVN62D HU. I hear it is the same exact HU as the Eclipse AVN6620. Anyway, it was an easy plug and play install as I just used my factory wire harnesses to plug right into the HU. Everything seems to work fine, but I have an issue with the DVD portion. When I insert a DVD, the audio plays fine, but there is no video. This happens when the car is parked or in motion. It just shows the wallpaper while the audio from the DVD is playing. I've tried 10 different DVDs and I get the same result. Does anyone know how to fix this? I hope this isn't a lemon.
  2. Feb 25, 2010 at 4:35 AM
    n2advnture
    n2advnture Well-Known Member
    Mark
    New Market, MD
    2007 Double Cab 4x4 TRD Sport Longbed
    Front skid plate color matched to wheels, Weather Tech floor mats, Window visors, Bug deflector, Exhaust tip, Bed mat, EZ down tail gate, Redline hood struts, Cover Wet Okole custom seat covers w/ heaters, FJ Anthracite Special Edition Wheels, 265/75/R16 BFG All-Terrain KOs, Pioneer Avic Z110BT, Back up cam in Pop N Lock, XTang Solid Fold tonneau, Escort Xi45 hardwired radar detector, Scan Gauge II
    Did you run the brake bypass to ground?
  3. Feb 25, 2010 at 7:47 AM
    kooltacoma
    Las Vegas
    08 Prerunner
    It does not show video with the e-brake on or off. All I did for this install was plug the factory wires into the HU. I did not ground anything as I wasn't aware of doing that. I thought it was just simple plug and play. Can you guys explain further on the ebrake wire that I need to ground? Is it part of the wire harness? Im a bit of a noobie to this. Thanks for your replies.
  4. Feb 25, 2010 at 7:56 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    There will be a green wire on the back of the unit, at least that was the color on mine. If you wire it to the parking brake you can only play it while its set. Or you can do a parking brake bypass. Get an on off locking switch, little 4 prong red one from Radioshack, and what you have to do is wire one to the ground, and the other one goes into the harness I believe. Then hook it up. Pretty simple.
  5. Feb 25, 2010 at 8:01 AM
    Stillfly199
    J.D.
    2010 FJ Cruiser
  6. Feb 25, 2010 at 9:04 AM
    kooltacoma
    Las Vegas
    08 Prerunner
    My deal is that my car, while in park, still wont display DVD video with the parking brake already on. So, grounding the parking brake wire is required to watch DVDs?
  7. Feb 25, 2010 at 9:12 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    There will be a wire coming out of the eclipse that says, "parking brake" just connect that to the factory ground on the wiring harness. Should work like a champ after that.
  8. Feb 25, 2010 at 2:56 PM
    kooltacoma
    Las Vegas
    08 Prerunner
    I will try it after work. Thanks for all your help.
  9. Mar 1, 2010 at 12:47 AM
    kooltacoma
    Las Vegas
    08 Prerunner
    Thanks everyone for your help. I installed the harness and grounded the parking wire and now my DVD player works in drive or park. But now I am having an issue with my navigation. I mounted the antenna in the car, and it knows that Im moving because I can see it on the navi while im driving, but my problem now is that it shows im in california when im actually in nevada. I dont know what else to try. Thanks again for your replies.
  10. Mar 1, 2010 at 5:24 AM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    08 Prerunner Texas Edition
    in california?
  11. Feb 21, 2012 at 7:33 PM
    brax
    brax Member
    brax
    Charleston
    hey guys, i recently bought this deck to install in a NON toyota and am missing the oem eclipse harness, anyone still have one they didnt need after their toyota install?
    thanks
