ecm issues.
Discussion in '1st Gen. Tacomas (1995-2004)' started by salvagehamilcar, Nov 28, 2015.
  1. Dec 11, 2015 at 1:43 PM
    #41
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    The Mazda incorrectly thought there was one thing wrong (high fluid temp) when in fact the problem something else (bad temp sensor).
  2. Dec 11, 2015 at 1:59 PM
    #42
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I was just about to ask if you were getting "not ready" or just nothing.
    The communication buss is functioning and not a bad connection (your getting data). Are you getting all the running data, closed loop, nothing missing? Values seem reasonable? Sure seems like it.
    I have not heard of any oddball Toyota specific conditions that enable or prevent a "ready" status. Not saying there aren't any but not to my knowledge.
    As long as the observed value, right or wrong, for coolant temp is over 176F, that's enough for closed loop it is also the default ECT set for fail safe mode.
    I concur about things pointing towards the ECU. I am not going that far out on a limb just yet but it might be time to start "casually" looking for an ECU to swap or maybe get a diagnostic read from another party with different equipment although both you and the emissions testers seem to be seeing the same thing. :confused:
    Brie likes this.
  3. Dec 11, 2015 at 2:03 PM
    #43
    Dirty Pool
    99 XCAB V6 MT TRD
    Speed sensor working? It seems as if what ever the problem is, it's across the board with the monitors.
  4. Dec 11, 2015 at 3:43 PM
    #44
    salvagehamilcar
    salvagehamilcar [OP] Active Member
    juan
    2000 tan 2dr 4x4 manual tacoma
    Bone stock
    My original question was with respect to my monitors not being ready. But in doing some research and some tests I found the odd ecm symptoms.
  5. Dec 11, 2015 at 3:45 PM
    #45
    salvagehamilcar
    juan
    Bone stock
    I don't see what else it could be. How can just one part of the ecu be bad?
  6. Dec 11, 2015 at 4:07 PM
    #46
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
  7. Dec 11, 2015 at 4:19 PM
    #47
    salvagehamilcar
    juan
    Bone stock
    What kind of values should I be looking at?
  8. Dec 11, 2015 at 4:19 PM
    #48
    salvagehamilcar
    juan
    Bone stock
    I'll take it apart tomorrow morning.
  9. Dec 11, 2015 at 5:26 PM
    #49
    billybob50
    Bob
    Brie likes this.
  10. Dec 12, 2015 at 11:02 AM
    #50
    Dirty Pool
    99 XCAB V6 MT TRD
    I think my point was missed. The ECM is seeing an acceptable number from the temp sensor to allow closed loop and readiness tests. It could be off but it matters not as far as the OP's suspected problems with the ECU are concerned. The ECU is seeing a reasonable temp value (right or wrong) and that's all that matters. I would keep looking.
    The ECU is made up of numerous circuits/circuit systems. Some are electrically entwined some are not. It is entirely logical that one single failure in an internal ECU circuit/circuit component dealing with trouble codes/readiness tests/drive cycles may not have any effect on the actual running of the engine.
    What engine is this?
    Brie likes this.
  11. Dec 12, 2015 at 11:28 AM
    #51
    salvagehamilcar
    juan
    Bone stock
    The engine is a 3.4l v6 in a 01 Tacoma manual, 4x4.
  12. Dec 12, 2015 at 11:28 AM
    #52
    billybob50
    Bob
    Are you the original owner? Could the previous owner had altered the ECM, wonder if you can get it re flashed or purchase a replacement?
  13. Dec 12, 2015 at 11:34 AM
    #53
    salvagehamilcar
    juan
    Bone stock
    I am not the original owner. I don't think so, when I looked behind the glove box for the ecm everything looked undisturbed. No screws or bolts missing/rounded off. I'm looking to see if a shop or the dealer will reflash it for me. But I think I hit a dead end.
    BTW I tested the coolant temperature sensor using the chart provided by Billybob50 value were spot on. Sensor is fine.
  14. Dec 12, 2015 at 11:42 AM
    #54
    billybob50
    Bob
    If the previous owner had it reprogrammed, all is needed is a cable and computer to do the work. This is probably your problem since it doesn't recognize some of your sensors.
  15. Dec 12, 2015 at 12:02 PM
    #55
    Dirty Pool
    99 XCAB V6 MT TRD
    No flashy for 1st gens.
  16. Dec 12, 2015 at 12:06 PM
    #56
    salvagehamilcar
    juan
    Bone stock
  17. Dec 12, 2015 at 12:24 PM
    #57
    Dirty Pool
    99 XCAB V6 MT TRD
    I feel your pain. You have a sucky situation and mostly all just to pass a test.
  18. Dec 12, 2015 at 12:31 PM
    #58
    billybob50
    Bob
    Brie likes this.
  19. Sep 16, 2016 at 10:37 PM
    #59
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner & 2016 Taco Sport
    What's this mean?
    They can't be flashed?
    Lord Helmet likes this.
  20. Sep 20, 2016 at 8:11 PM
    #60
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Yup
    Brie[QUOTED] likes this.
