ECM not detected
Discussion in '1st Gen. Tacomas (1995-2004)' started by SS64, Jun 28, 2023.
  1. Jun 28, 2023 at 5:54 AM
    SS64
    SS64 [OP] New Member
    Michael
    2001 prerunner 2wd automatic 3.4
    stock
    Hello and thanks for reading, I have a 2001 3.4 with 164K miles automatic 4-door Prerunner. First time posting, I did search around in here but see nothing similar to my problem. I'm hoping someone can help me out. A few days ago I went to start it and it turned over a few times then click, click, click. After inspecting the battery I discovered some corrosion on the terminals, after cleaning them up it cranked over but ran ruff and white-blueish smoke with a heavy gas smell coming from the exhaust, almost as if the injectors are running wide open. I tried to read any codes but the ECM is not detected, I borrowed another scanner and same results. It will run but is extremely ruff. The truck had been driven a few days before with zero issues. All other electronics seem to be in working order. I've pulled the computer and everything looks good inside it, I have also ordered a replacement from a salvage yard, with the same part number. My concern is what caused it and what can I do to prevent this from happening again. I've ohmed out the grounds and given the harness a good look over for any critters or abrasions but all looks well. We live in the East TN area, any help or suggestions would be appreciated.
  2. Jun 28, 2023 at 6:03 AM
    Bishop84
    Bishop84 Well-Known Member
    Usually leaking windshield, if it hasn’t been fixed it will happen again.
  3. Jun 28, 2023 at 6:25 AM
    SS64
    Michael
    stock
    Thanks, Bishop84, the windshield was actually replaced a year ago. We did have some pretty bad storms the night before. Are you thinking the computer got wet, everything was dry inside the truck.
  4. Jun 28, 2023 at 7:11 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Dirt or corrosion can also cause a failure to connect !
    in fact it happens to me quite often when helping other people out.
    A little cleaning fixes the issue.
  5. Jun 28, 2023 at 8:06 AM
    Glamisman
    Glamisman Well-Known Member
    Bivouac likes this.
