ECM Processor Error
Discussion in 'Technical Chat' started by Chappie, Aug 21, 2009.
  1. Aug 21, 2009 at 2:47 PM
    Chappie
    Chappie [OP] Member
    My check engine light was no for a couple of days, then went off, and has stayed off since. From the advice in my original thread, I took it to Autozone. The diag test came back with :
    ECM processor error
    Probable cause - Failed ECM
    As I said, the C/E light is now off, and I have observed no oddities of any sort. Recommendations? It's an '06 V6. A quick scan of the internet shows me that these things are $500+. yuck.
  2. Aug 21, 2009 at 2:59 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    I'm sorry to here that. You should get a second opinion.I replaced the ECU a couple months back,cost me $950.00 that not include the labor/tax. I hope nothing like that with your.'06 shouldn't have that problem.
  3. Aug 22, 2009 at 8:40 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    This is the kind of issue that should probably be referred to a dealership shop. Toyota is the only outfit that can determine if the ECU is definitely faulty.
  4. Aug 22, 2009 at 9:01 AM
    Chappie
    Chappie [OP] Member
    Is the ECM considered part of the powertrain?
  5. Aug 22, 2009 at 9:06 AM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    Most ECM's are under a 8 year 80,000 mile warranty. If you are within the time or mileage take it to the dealer. Most likely it is covered. ECM's are not a powertrain item. Powertrain consists of internally lubricated parts within the engine and transmission, including bearings on the drive axles. For instance a front wheel drive vehicle will have a 5 year 60,000 mile warranty on front bearings and 3 years 36,000 miles on the rear bearings.
  6. Aug 22, 2009 at 9:08 AM
    97Blk_one
    Memfrica
    not so low
    The Brain of all the Electrical Systems in your Truck. Electrical Control Module(Unit) Without it your truck, will suffer a great deal. Take it to the stealership let them check it.
