ECM reset?
Discussion in '4 Cylinder' started by 2.7taco, Feb 10, 2017.
  1. Feb 10, 2017 at 5:23 PM
    2.7taco
    2.7taco [OP] Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Anyone know of the proper way to reset the ECM?
    I have been told to unplug the positive cable for an hour but I don't think it did squat.
  2. Feb 23, 2017 at 6:02 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Why do you want to reset out of curiousity ?
  3. Feb 23, 2017 at 3:01 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yes a battery disconnect will do it, but to be sure you might want to let it sit longer than 1 hour. Not sure if that is the official/proper way but it works.
    I disconnected the battery while changing spark plugs, was about 2 hours total disconnect time. Definitely noticed a difference in the way it ran, way more than would be caused by a new set of plugs. Took about 3 days to get normal again.
    2.7taco[OP] likes this.
  4. Mar 8, 2017 at 5:57 PM
    2.7taco
    Texas
    Way late but I got her done. She runs like a top after the ECM recalibration was finished learning the new injectors.
  5. Mar 8, 2017 at 5:59 PM
    Bishop84
    Bishop84 Well-Known Member
    It doesn't always reset fuel trim but it starts the throttle relearn over again, and it can take hours to figure out the ETCS if the valve is dirty.
  6. Mar 8, 2017 at 6:10 PM
    Timmystaco
    Timmystaco Active Member
    Timmy
    Taco X Runner
    K&N air intake system
    Does this work for the 4.0 6 banger?
  7. Mar 8, 2017 at 6:17 PM
    2.7taco
    Texas
    Yes it will. You will need to complete a few drive learns after doing it. It consists of various driving conditions. I can't post the picture of the info but someone on the 2nd gen forum posted it years ago.
    Timmystaco[QUOTED] likes this.
  8. Mar 8, 2017 at 6:19 PM
    2.7taco
    Texas
    The only thing it took was 3 drive learns. First one I followed it to the Tee. The next were scattered about and the truck runs great after I completed them.
    After new injectors the truck would black smoke. After the ECM reset it ran great and zero smoke.
