ECM swap questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reign808, Apr 20, 2019.
  1. Apr 20, 2019 at 1:01 PM
    Reign808
    Reign808 [OP] Well-Known Member
    Ian
    2013 Tacoma 4dr
    Magnasun charger, walbro 255, TBS, K&N intake, LED everything, cosmetic mods
    I bought a used ecm off ebay and they told me it couldn't be flashed due to the old vin number being locked with the immobilizer. Has anyone had this happen to them? They said a used ecm can't be re written. Where do I go to get a new one?
  2. Apr 20, 2019 at 1:11 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Whomever told you this is lazy, a liar, and or uninformed.
    RacecarGuy likes this.
  3. Apr 20, 2019 at 1:19 PM
    Reign808
    Ian
    2013 Tacoma 4dr
    They said they couldn't start the truck with the ecm. So they could try again if I got a new one. A brand new not used one. This is the Toyota dealership here
  4. Apr 20, 2019 at 1:21 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Try a different dealership. Don't mention what the previous dealership said.
  5. Apr 20, 2019 at 1:24 PM
    Reign808
    Ian
    2013 Tacoma 4dr
    I live on kaua'i in Hawaii I'll have to ship it out somewhere for a new dealer to flash it
  6. Apr 20, 2019 at 1:26 PM
    Reign808
    Ian
    2013 Tacoma 4dr
    So they come back and tell me they didn't clear the vin off the ecu before trying to write they're trying again
  7. Apr 20, 2019 at 1:31 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    We only have one dealership out here lol it’s all the same company it’s a monopoly
    whatstcp likes this.
  8. Apr 20, 2019 at 1:47 PM
    Reign808
    Ian
    2013 Tacoma 4dr
    Yeah bro we have 1 toyota dealer here on kaua'i next place would be oahu
    El Duderino[QUOTED] likes this.
  9. Apr 20, 2019 at 1:47 PM
    El Duderino
    Jeremy
    HI->PNW
    And we only have one lol :rofl:
  10. Apr 20, 2019 at 2:38 PM
    Reign808
    Ian
    2013 Tacoma 4dr
    Now in being told they need a code from a dealership in the mainland so they can clear the vin to write a new one
    El Duderino likes this.
  11. Apr 20, 2019 at 3:23 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Vin doesn’t have to match .. but make sure you have the correct ECU model for your year .. this will work !
  12. Apr 20, 2019 at 3:41 PM
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Umm .. are you trying to replace to ECU and having issues with the immobilizer ?
    Or .. trying to load the TRD tune to another ECU ?
    Either case .. the dealer is being lazy. You can load it yourself with a 2 day sub to techstream, but will need a mongoose cable.
    Reign808[OP] likes this.
  13. Apr 20, 2019 at 6:42 PM
    Reign808
    Ian
    2013 Tacoma 4dr
    Trying to load the TRD tune to a stock one..they say even with the code it can't reset the vin number attached to it. I need to get a brand new ecm is what they say
  14. Apr 20, 2019 at 6:43 PM
    Reign808
    Ian
    2013 Tacoma 4dr
    How do I do it by myself?
  15. Apr 20, 2019 at 7:16 PM
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Techstream .. with mongoose cable.
  16. Apr 20, 2019 at 7:29 PM
    Reign808
    Ian
    2013 Tacoma 4dr
    I understand that part ha. What I mean is, do I download the software to a computer and then what? It has the trd tune in the tech stream? How much is said tech stream and a mongoose cable
  17. Apr 20, 2019 at 7:34 PM
    replica9000
    2019 T4R ORP
    The only time I swapped an ECU was in a GM car. Only needed a Tech II to reset the crank position sensor. Other than that, car started fine. Is it not this simple for Toyota's?
  18. Apr 20, 2019 at 7:40 PM
    jojotoo
    Brandon
    Socal
    2015 DCLB
    2 day subscription for techstream is $50. Mongoose cable can run you $200+ Used / $500 new.
    Techstream will have the trd calibration file to load.
  19. Apr 20, 2019 at 7:42 PM
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Post in : performance and tuning section.
    Someone might be nice enough to load the tune for you. Obviously, you would have to mail them the ECU.
  20. Apr 20, 2019 at 8:03 PM
    Reign808
    Ian
    2013 Tacoma 4dr
    I searched on Amazon and found some for less than 100$?
    Also found the techstream plus sale for less than 100$ too. Legit ?
