ECM swap with wrecking yard ECM.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by firewrench, Feb 12, 2014.
  1. Feb 12, 2014 at 10:04 PM
    firewrench
    firewrench [OP] Member
    06 tacoma pre-runner
    I've got issues! My ECM is bad in my 2006 taco so I found a matching unit at a local wrecking yard. Before the swap the truck would only crank but not start. After swap, the truck starts but then dies immediately. All fuses are good and no MIL or DTC's. The wrecking yard says they tested and drove donor vehicle before removing and that the unit they sold me is good. I tried firing engine on starting fluid but it still died so it's not fuel pressure related. I'm thinking the computer is shutting it off but not sure why?
    Any help would be greatly appreciated.
  2. Feb 13, 2014 at 12:54 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Ive heard the VIN is progammed into the computer so when you start it the anti-theft runs a check and when the vin comes back not matching it cuts it off. Its a security feature. My brother had a Chevy Malibu in the shop for 3 months trying to figure out this exact problem after an ecm swap. I dont know how it finally got fixed but last I heard they got it running. I think they might have just disabled the anti theft module but im not positive.
  3. Feb 13, 2014 at 1:57 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I agree! My Solstice is the same way, ECM has to be "paired" to the vehicle.
    TomTwo likes this.
  4. Feb 13, 2014 at 4:53 AM
    firewrench
    Thanks for your replies guys, I talked to a Toyota tech and you're right the VIN needs to be programmed into the ECM or the immobilizer won't let it start. The good news is he said this is not a Toyota only thing, that there are scanners with the capability so I should be able to find a local shop to do it. I'll keep you posted.
    TomTwo likes this.
  5. Feb 13, 2014 at 7:45 PM
    ProForce
    Anthony
    Alaska
    I know the cluster has data stored like mileage but if you swap clusters the truck still starts just fine and will display whatever mileage was on the actual cluster that was installed regardless of how many miles are really on the truck. So I dont think the cluster will affect the ecm or immobilizer
  6. Feb 13, 2014 at 7:56 PM
    Toyotacerttech
    Toyotacerttech Well-Known Member
    Michael
    Texas
    2011 double cab 4x4 TRD
    You don't need a scan tool to do it, if I have some time I'll look up how to do it
  7. Feb 13, 2014 at 9:21 PM
    firewrench
    Toyotacerttech, if you can tell me how that would be great cause I'm about to tow it to the dealer
  8. Feb 13, 2014 at 9:37 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Also get the latest ECM software flashed while you are at the dealer (includes the brake override functionality and improved transmission shift logic).
  9. Feb 13, 2014 at 9:55 PM
    firewrench
    Thanks for the heads up on that
  10. Feb 14, 2014 at 7:09 PM
    Toyotacerttech
    Michael
    Texas
    Could figure out how to post it on here so I took a picture of it
    sikruis, GilbertOz, ajmogen and 3 others like this.
  11. Feb 14, 2014 at 9:04 PM
    firewrench
    Thank you Toyotacerttech. I found this for anyone in my situation,
    Google "registration of ecu communication ID" and you will find the document Toyotacerttech suggested.
    Much like Captchas says, the newer ECMs are not plug and play anymore. However you do not need to have this done at the dealer. There are several new scan tools with VIN writing capability such as Snap-On's Modis Ultra or Solis Pro so long as they have the latest software updates. You just need to find someone with these tools and experience with this type of programming. Not many ECMs are being replaced on vehicles this new yet so I had a hard time finding someone who could do it.
    I did end up towing it to the dealer, they rewrote the wrecking yard ECM VIN to match my Taco's VIN. All is good now and my truck runs.
    Recap: Dealer wanted $1345 for a new ECM plus fee for flashing it. So about $1500-$1600.
    I bought a wrecking yard ECM for $175 then had vehicle towed (AAA) to dealer for ECM rewrite $112.
    So I'm in about $300 total.
    I wish I would have tried Toyotacerttech's way first, just didn't get it in time.
    Thank you all for your help!
    TheDevilYouLove likes this.
  12. Jun 30, 2014 at 1:04 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Were can I get this set thing?
  13. Jul 19, 2017 at 4:25 PM
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Has anyone tried this method of replacing a ecu?
  14. Jul 19, 2017 at 8:09 PM
    gersus
    Missouri
    14 Tacoma DCOR
    Well, I can say it works!
  15. Jun 2, 2018 at 6:23 AM
    JohnThomas Sorrels
    JohnThomas Sorrels New Member
    2006 Tacoma DCSB
    Apologies for resurrecting an old thread but would the procedure posted by Toyotacerttech be all that is required if I were to replace the immobilizer module, (link to one below). Currently my truck won’t accept any new key fobs or keys. I bought some fobs a while back and the truck wouldn’t go into program mode. More recently, I took it to the dealership to get a new key, they said they couldn’t get it to program and that they would need to diagnose the immobilizer module but they didn’t have time that day and the service guy at Toyota even said it was pricey. So I found this on eBay but wanted to make sure I’ll be able to start my truck after installing it...
    https://www.ebay.com/i/172834384855?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F2%2Fe112358.m1951.l1123%2F8%3Fbu%3D43123260195%26segname%3D16TE179842_T_PREPURCHASE_CT2%26crd%3D20180601090000%26mpre%3Dhttps%253A%252F%252Fwww.ebay.com%252Fulk%252Fi%252F172834384855%26ch%3Dosgood%26url%3Dhttps%253A%252F%252Fwww.ebay.com%252Fulk%252Fi%252F172834384855%26osub%3D3273dae3724e6d54af1c4d5eca464884%257E16TE179842_T_PREPURCHASE_CT2%26sojTags%3Demid%253Dbu%252Csegname%253Dsegname%252Ccrd%253Dcrd%252Curl%253Durl%252Cch%253Dch%252Cosub%253Dosub%26srcrot%3De112358.m1951.l1123%26rvr_id%3D0%26rvr_ts%3Dc0aa72201630a86007c35d4bfffb0eb2&ul_noapp=true
  16. Jun 2, 2018 at 11:06 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    If I remember correctly, the system will only record 4 or 5 transponders, and you need the black master key to start the process.
    It may be maxed out.
    Again I'm not sure, but i believe the system can be cleared of all codes. If so, then bring all the keys you want recognized and go that route.
  17. Jun 2, 2018 at 4:37 PM
    JohnThomas Sorrels
    2006 Tacoma DCSB
    I don’t think that is the issue with my truck. To the best of my knowledge there are only two keys, plus wouldn’t the dealership have thought of it? I do have the black key that came with the truck but it is very worn, to the point of slipping out of the ignition and not being able to manually unlock the doors, which is why I tried to get another one made. But just in case, is there a way to clear off the memory on my own without Toyotas’ Intelligent Tester?
  18. Nov 15, 2018 at 11:04 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    How did you figure out which ECM your truck has? every time I search by VIN on parts website it gives me a few model #'s.
  19. Nov 18, 2018 at 4:33 PM
    gersus
    Missouri
    14 Tacoma DCOR
    I gave the salvage yard my info, but didnt give them vin.
  20. Nov 18, 2018 at 4:35 PM
    henryp
    Henry
    Montana
    Gotcha
