Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Feb 23, 2015 at 9:01 AM
    #261
    Quirt
    Quirt Mad Scientist
    The math our Eco Block changes in the computer is similar to what is changed with a CAI so you cannot / should not do both.
    Did your vehicle come from the factory with the supercharger?
  2. Feb 23, 2015 at 9:06 AM
    #262
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Tacoma's do not come from factory with a Supercharger. Most of us have the TRD supercharger which is a Toyota TRD part that comes with Toyota blessing that is installed on the truck once it's at the dealer or in private hands. It has it's own tune, that is flashed onto the factory ECU, that is usually a bit rich.
  3. Feb 23, 2015 at 9:12 AM
    #263
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    well poo
    definitely rich.. trying to get mine into that perfect sweet spot.. i believe it needs to be leaned out just a tad. although.. i should probably spend some money and time doing some dyno runs to see whats really goin on instead of just the butt dyno and my AFR gauge.
  4. Feb 23, 2015 at 9:20 AM
    #264
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You should be more seriously considering the MAF Cali, to get the flexibility you need to fine tune it. There is no ability to tune this MAF spacer, and getting AFR wrong on an SC could be quite painful/expensive.
  5. Feb 23, 2015 at 9:23 AM
    #265
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Being slightly rich is safe on a boosted application. That's why the TRD S/C flash is rich. Being lean is what can cause a very high repair bill.
    I've looked into the MAF calibrator from URD. It's nice but I'm not ready to start cutting into my factory harness quite yet.
  6. Feb 23, 2015 at 9:29 AM
    #266
    Quirt
    Quirt Mad Scientist
    In that case it should work then.
  7. Feb 23, 2015 at 9:34 AM
    #267
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    They make harnesses.
  8. Feb 23, 2015 at 9:36 AM
    #268
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Not for the newer 2nd gens ;).
  9. Feb 23, 2015 at 12:20 PM
    #269
    CleanupBoss
    CleanupBoss Well-Known Member
    Chet
    Sparks, NV
    SR 5 with Leer shell
    S/C w/ Gibson exhaust Araid CAI, afr/boost gauges in Craven Speed mount, LED camper shell lighting kit clear bra, fogs, Leer shell w/keyless entry & Thule roof rack system Pop & Lock tailgate handle Rugged country 30" light bar for lower front bumper, Baja Designs SR2 flush mount rear bumper lights, DB Customz grill w/ 3" cube lights, Viair 2 gal tank, Viar Compressor
    Mine still stumbles on take off but gets going real well around 35mph and continues strong through 75mph.
    I'm still looking to improve that elusive low end torque :burnrubber:
  10. Feb 23, 2015 at 12:32 PM
    #270
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Being to lean can cause a very high repair bill. But that's the whole goal as a tuner essentially to see how lean you can get it with out being detrimental to the engine. Engines make the most power running lean.
    Atleast this is what I recall from my Hondata and AEM days. But maybe boosted cars are a different story and make more power being leaned out because of the air coming in being denser.
  11. Feb 23, 2015 at 1:03 PM
    #271
    gray223
    SE Missouri
    2014 Tundra Limited
    The goal is to have 14.7 a/f ratio thoughout the engine rpm, load, etc. That is the perfect amount of air and to completely burn all the fuel. If you not burning the fuel you are wasting it, or using as a heat soak.
    Running to lean will cause it to run hot as more oxygen will burn hotter, which can lessen or end the life of an engine.
  12. Feb 23, 2015 at 1:06 PM
    #272
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Gotcha. I remember 14.7 being idea at ideal and guess getting everything as close to that as possible throughout the rpm range was the ultimate goal. Granted I feel like my turbo cars always ran a little lean in 15-16 range. But always made respectable power and I never had any internal engine issues.
  13. Feb 23, 2015 at 1:31 PM
    #273
    Quirt
    Quirt Mad Scientist
    Running too rich as well as too lean hurts power and the engine. Too lean causes pistons to burn and to rich washes down the cylinder walls.
  14. Feb 23, 2015 at 1:38 PM
    #274
    Quirt
    Quirt Mad Scientist
    14.7 to 1 is the ideal Stoichiometric or Theoretical air fuel ratio... but if you try to run that lean at full load then you can kiss your power and engine goodbye.
  15. Feb 23, 2015 at 2:00 PM
    #275
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    I recall WOT afr's in the 12-13's
  16. Feb 23, 2015 at 2:06 PM
    #276
    Quirt
    Quirt Mad Scientist
    Yes mid 12's to the very low 13's depending on the engine for an N/A application.
  17. Feb 23, 2015 at 2:40 PM
    #277
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Running 14.7 throughout the entire rpm range and load range is not safe.
    1GR factory programming runs ~ 14.7 for most of closed loop. Depending on the load, rpm, and TPS, IAT, & coolant temps, open loop AFR's are usually in the mid to low 10's. N/A and TRD reflash for the s/c. At 100% load, mine sees 10.0-10.2 AFR. Still way to rich for optimum N/A power.
    Here is a short video demonstrating the OEM ECU 's control of Open and Closed Loops.
    https://www.youtube.com/watch?v=ErPJEn2TmSY
  18. Feb 23, 2015 at 4:56 PM
    #278
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This.. I'm at a consistent 14.7 via the AFR gauge. I would like to just dial it in perfectly.. which.. ultimately is the goal for all of us.. Just trying to get there like the rest of us. At WOT.. I'm around 11-12.. I believe.. keeping an eye in it while driving always proves to be difficult. :rolleyes:
    Maybe the URD MAF Cal is in fact the way to go. It would be the best time to get it since everything else is done now prior to it.
  19. Feb 23, 2015 at 6:25 PM
    #279
    gray223
    SE Missouri
    2014 Tundra Limited
    Yes at full engine load 14.7 is too lean. Needs to richen up
  20. Feb 24, 2015 at 4:53 AM
    #280
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    There in lays the problem WOT requires more fuel to make the power it is not a lean mix. A lean mix increases emissions (HC) it is not something the EPA likes and it does not increase power or for that matter economy what any gas engine wants is a perfect mix of fuel and air (14.7:1) and the designers try their best to achieve that.
