Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Feb 24, 2015 at 5:01 AM
    #281
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Forced induction makes power by reducing the effort to bring air into the engine. An engine is a big vacuum pump it takes lots of power to draw air/fuel into the cylinders the turbo/super charger forces air in making it easier for the engine to get the mix into the cylinders.
  2. Feb 24, 2015 at 5:06 AM
    #282
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You're missing the point. The factory tune runs really rich. As i explained a few posts above. When you lean that overly rich mixture, from say 10.0:1 to 12.5:1, for N/A, then fuel consumption is saved and power is gained.
  3. Feb 24, 2015 at 5:08 AM
    #283
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    When you read AFR on a scan gauge it is an average the fuel system is not static it goes from rich to lean because of reaction times the bottom line it is trying to produce a 14.7:1 mix If you read O2 sensor voltage you will see that happening.
  4. Feb 24, 2015 at 5:17 AM
    #284
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    The factory is not going to run a rich mix they would not meet emission standards and there is no earthly reason they would want too.
  5. Feb 24, 2015 at 5:19 AM
    #285
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Clearly you have no AFR gauge and are going off of hypotheticals, and don't know about tuning. Do I honestly need to get a video made to show you what the AFR does from factory tuning?
  6. Feb 24, 2015 at 5:53 AM
    #286
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    thats how you blow the welds on your intake.
  7. Feb 24, 2015 at 6:27 AM
    #287
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    No. Forced Induction creates power by cramming as much O2 molecules as possible into a cylinder. The more O2 you have, the more fuel you add, the bigger combustion will be produced. It's the difference between a boosted application which has a positive atmosphere vs n/a which will never reach past 0 psi unless you are running ram air.
    The n/a mods like CAI's and exhaust will allow the engine to breath easier, which is what you are ascribing to forced induction.
  8. Feb 24, 2015 at 6:28 AM
    #288
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    ^^ This
  9. Feb 24, 2015 at 6:46 AM
    #289
    Vassily28
    Hey TOR,
    Never realized the fuel mixture was not static :eek:
    See attached picture of my AFR readings in third gear after my fine tuned map with the URD MAF controller. The stock mixture in open loop is not slightly rich, its f$/?%$ rich. To maintain a mixture between 11 and 12 AFR i had to removed a lot of fuel. Some cells of my MAP are now set at 8.5 compare to 10 that is a neutral value. At WOT it changes the MAF reading for 320 g/s to 270 g/s.
  10. Feb 24, 2015 at 9:37 AM
    #290
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    So even though 14.7 is ideal do manufacturers tune them rich because at 14.7 the temp inside the cylinder is just a little to hot that it will ware the engine faster or cause early failure?
  11. Feb 24, 2015 at 10:00 AM
    #291
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    As Quirt mentioned earlier, that is the best theoretical stoichiometric ratio for catalytic efficiency. It is also where the majority of time is spent by drivers while cruising.
    In the events where more load is added to the engine, through acceleration, for example, more fuel needed to prevent detonation. It also act as a way to cool the cylinder temperatures.
    Industry standards are 12-13 AFR for best performance from N/A applications, and 10.8-11.5 for boosted. On gasoline. With room for variance depending on other factors.
    The point is, again, OEM's a tuning for a lot of the worst case scenarios. Thus make the AFR's richer while under heavy loads, within reason, as it is effectively safer.
    A lot of wiggle room for the aftermarket, to safely make changes for performance, on vehicles. Usually the aftermarket finds out quickly which flaws there are in OEM systems and components. OEM builds the base and aftermarket builds upon it.
  12. Feb 24, 2015 at 12:47 PM
    #292
    gray223
    SE Missouri
    2014 Tundra Limited
    Theoretically 14.7 Afr will make the most power efficiently right, but in certain citation more fuel is need to keep cylinder temps down.
    But can you make more power running rich or lean, just one is using fuel to soaking up heat while the other is running too hot and is increase risk for detonation.
  13. Feb 24, 2015 at 3:11 PM
    #293
    Quirt
    Quirt Mad Scientist
    Correct... thanks.
  14. Feb 24, 2015 at 3:14 PM
    #294
    Quirt
    Quirt Mad Scientist
    A wideband Lambda / AFR sensor is necessary to get the true picture of what is going on. And a must for any tuner out there.
  15. Feb 24, 2015 at 3:16 PM
    #295
    Quirt
    Quirt Mad Scientist
    Hence the term Lean pop!
    Throw a little NOS in the mix and you can throw the intake manifold right off the engine! Don't ask me how I know this!! :D
  16. Feb 24, 2015 at 3:22 PM
    #296
    Quirt
    Quirt Mad Scientist
    There is some good information in here, sounds like I need to hire this guy ;)
  17. Feb 24, 2015 at 3:25 PM
    #297
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Can I work from home? I don't feel like moving. Lol.
  18. Feb 24, 2015 at 3:30 PM
    #298
    Quirt
    Quirt Mad Scientist
    Dude... it's 70 deg here today ;)
  19. Feb 24, 2015 at 3:44 PM
    #299
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    But California doesn't like my turbo Tacoma. :(
  20. Feb 24, 2015 at 3:50 PM
    #300
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    It's ok buddy. I like your Tacoma. Because Texas>everything:cheers:
