Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Feb 26, 2015 at 2:21 PM
    #361
    JTrean
    JTrean Well-Known Member
    That's good to hear. The 2.5's were pathetic in terms of reliability.
  2. Feb 26, 2015 at 2:33 PM
    #362
    Yota64
    Yota64 Professional Threadjacker
    Tuned in
    That's great. Hopefully more for the trucks. I read in here that the reason motor companies did not use this method was for a safety margin... But how dangerous is this block that it prevents motor companies from taking advantage of 7% increase? What is the negative balancing this positive in order for this to work?
  3. Feb 26, 2015 at 3:52 PM
    #363
    Quirt
    Quirt Mad Scientist
    The manufacturers are mandated to have a pretty big safety margin and this is what all aftermarket tuners take advantage of. The negative side is you could get a check engine light sooner if you have a sensor start to go bad. And because you are making a little more power, there will also be a little more wear on some of the drive train components.
  4. Feb 26, 2015 at 4:12 PM
    #364
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Just got mine today, coast to coast it only took a few days. Really easy install, th hardest part was just making sure the little o ring didn't fall out of place. If I were to experience a cel would it most likely happen quickly? Looking forward to tracking mpg, my last 6 or 7 tanks have been averaging 17mpg and according to ultra gauge it's 17.1 mpg.
    Unfortunately ultra gauge doesn't seen to measure afr unless I missed it. Anybody with a ultra have any suggestions on what I should monitor?
  5. Feb 26, 2015 at 4:23 PM
    #365
    Quirt
    Quirt Mad Scientist
    If your O-ring was not sealing correctly then you would have a check engine light immediately.
  6. Feb 26, 2015 at 4:39 PM
    #366
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    MPH, MPG current, MPG avg and intake air temp.
  7. Feb 26, 2015 at 4:50 PM
    #367
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Can the ultragauge give you Lambda? You can get AFR from Lambda by multiplying the lambda value by 14.7 .
  8. Feb 26, 2015 at 5:05 PM
    #368
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Good to know. I haven't actually driven it anywhere but it was idling for 5 mins or so after I installed it and everything is good.
    I have all those set already, was just wondering if there was anything else I could/should look at.
    I'll have to check on that one, don't know.
  9. Feb 26, 2015 at 5:29 PM
    #369
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    The Crosstrek with a WRX engine sounds awesome. My wife wanted a Crosstrek but they're too slow. She got a Forester XT instead. Subaru would sell a ton of turbo Crosstreks if they offered them.
  10. Feb 26, 2015 at 6:25 PM
    #370
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    This is an interesting piece. So it looks to move the maf closer to the wall of the pipe. Maybe slower velocity going through the maf sensor. That might help make the truck run slightly leaner, causing the bump in mileage. Just a guess that is probably wrong.
    Curious to see if anyone is getting results from it. Maybe someone can look and see if their long term fuel trims will trim fuel compared to stock.
  11. Feb 26, 2015 at 7:06 PM
    #371
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
  12. Feb 26, 2015 at 7:14 PM
    #372
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    Said screw it and ordered one. Two main reasons. #1 I'm going up in tire size pretty soon and this will give hopefully negate any or some of the mileage lost. #2 I have a 90 mile round trip commute every day and I drive pretty aggressively on the highway so bring on the power.
    I have been keeping track of my mpg for close to 2+years now. I'm averaging 17.3mpg now.
  13. Feb 26, 2015 at 7:44 PM
    #373
    Quirt
    Quirt Mad Scientist
    Perfect, keeping track for that long will give you a great baseline. Please share your results.
  14. Feb 26, 2015 at 7:46 PM
    #374
    Quirt
    Quirt Mad Scientist
    Spot on, that's exactly what is happening. We are moving the sensor head to a location in the intake tube where there is less air flow.
  15. Feb 26, 2015 at 7:53 PM
    #375
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Day one, felt a bit more response to my foot. I have to fill up before work, so I can start a new tank for a few weeks.
  16. Feb 26, 2015 at 8:13 PM
    #376
    Gabassman
    Tyler
    Georgia
    I figured with a 7% increase in fuel economy I should save around 1 cent per mile. Adding up to $3+ a tank. So it would pay for itself after roughly 15 fill ups.
  17. Feb 26, 2015 at 8:38 PM
    #377
    John taco
    John taco Well-Known Member
    JT - Johnny
    King of Prussia PA
    Price is now $49.99 not $40.
    I commute my tacoma so Im pretty light on the pedal and try to manage my mpg and monitor my rpm and fuel consumption to collect.
    Anyone that has used this product actually have some approved mpg increase and what not?
    Thanks
  18. Feb 26, 2015 at 8:41 PM
    #378
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    If you go back a few pages there's a discount code. Not sure if you didn't notice or if it expired :notsure:
  19. Feb 26, 2015 at 9:06 PM
    #379
    TSJESME
    TSJESME Well-Known Member
    James
    Maui
    14 TRD SPORT A/C 4X4 M/T
    I ordered for the Tacoma and the wife's BRZ. Confirm coupon code no longer works, small enough price to worry about.
    I have followed this closely, did outside research, I think this is good value.
    PM'd Quirt, very helpful, friendly.
    Seems like a decent result for small investment.
    I will update, after installed.
  20. Feb 26, 2015 at 9:07 PM
    #380
    Yota64
    It's always said that you can't simultaneously improve fuel economy and performance by changing the air flow. Don't air and power go hand in hand meaning less air=less power but more mpg? How are we seeing more power and mpg at the same time? I would expect a tradeoff.
    Sorry, it seems like I'm the only one here not wrapping my head around it.
    What about the engine wear? is it enough to shorten the life of the engine?
