Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Mar 1, 2015 at 1:20 PM
    #481
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Quirt,
    After I get my new intake I will get one of these. Either from you or Chas. I had to go to an aftermarket one since the throttle body upgrade didn't like off road action and its held on with a ratchet strap lol
  2. Mar 1, 2015 at 3:22 PM
    #482
    JTrean
    JTrean Well-Known Member
    Recieved and installed the Q1 this morning. Initial test drive felt a little more power climbing hills and at half throttle. I just started a new tank of gas and will report back with more findings.
  3. Mar 1, 2015 at 5:14 PM
    #483
    Quirt
    Quirt Mad Scientist
    Making a dyno graph is easy... what gain would you like to see and I will make it so :eek:
  4. Mar 1, 2015 at 5:36 PM
    #484
    Quirt
    Quirt Mad Scientist
    The plan is to run a couple different trucks next weekend.
    My goal is to dyno a 4, 6 and 8 cylinder so we have a good comparison of each.
  5. Mar 1, 2015 at 5:38 PM
    #485
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    Perhaps just a 4 and 6 cyl...finding a V8 Tacoma is pretty rare ;)
  6. Mar 1, 2015 at 5:42 PM
    #486
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    I think the 8 was the tundra chas has.
  7. Mar 1, 2015 at 5:42 PM
    #487
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Awesome! :thumbsup:
  8. Mar 2, 2015 at 5:27 AM
    #488
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    For those with the TRD SC, whwn you say you have the factory flas, i suppose you're talking about the reflash for the supercharger.
    Best would be to have an AFR gauge to confirm everything is OK.
    Hey Quirt when you do the dyno run, make a logging of the AFR readings.
  9. Mar 2, 2015 at 6:52 AM
    #489
    Quirt
    Quirt Mad Scientist
    If there's a port for our Lambda sensor then I will put it in. One can never have too much data!
  10. Mar 2, 2015 at 7:46 AM
    #490
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Running one from chas. I think that the response is improved and idle seems smother. Will see what the test results are.
  11. Mar 2, 2015 at 8:08 AM
    #491
    andlours
    andlours Well-Known Member
    Andy
    Denver, CO
    09 TRD Offroad
    If the dyno proves results, I'll buy one immediately. I'm just holding out for a little more than the butt dyno haha.
  12. Mar 2, 2015 at 8:35 AM
    #492
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
  13. Mar 2, 2015 at 8:42 AM
    #493
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    As it's been stated before, I don't know why anybody wouldn't just try this, it's cheap enough plus if you don't like it you can get a refund.
  14. Mar 2, 2015 at 8:49 AM
    #494
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    That's what they said about the shake weight :wink:
  15. Mar 2, 2015 at 8:50 AM
    #495
    loco
    Phil
    Virginia Beach, VA
    What's wrong with shake weights? I use mine all the time...
  16. Mar 2, 2015 at 8:52 AM
    #496
    loco
    Phil
    Virginia Beach, VA
  17. Mar 2, 2015 at 8:57 AM
    #497
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    I bet! :jerkoff:
  18. Mar 2, 2015 at 9:01 AM
    #498
    loco
    Phil
    Virginia Beach, VA
    Did you even watch the video???
  19. Mar 2, 2015 at 9:18 AM
    #499
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Haha I've seen that video before, definitely NSFW
  20. Mar 2, 2015 at 12:27 PM
    #500
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    just got shipping info on mine! hopefully I will get this in before I make the trip down to Alabama. if not then it should at least be done for my trip to NC next week.
