Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Mar 11, 2015 at 12:49 PM
    #761
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Just curious to know why and have an explanation when poeple doesn't believe about the product or are worried about wear.
  2. Mar 11, 2015 at 1:02 PM
    #762
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Caved in and ordered one. a 5% increase in mpg will save $3000 over my expected lifetime of the truck.. and if it results in accelerated engine wear I get to do the 5.7L V8 swap sooner. win-win.:burnrubber:
  3. Mar 11, 2015 at 1:23 PM
    #763
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Wear is really subjective to the personal vehicle. The person who prolongs oil changes will have excessive wear compared to the enthusiast that performs oil changes every 2k miles. Then the person who neglects their vehicle will complain that their motor had to be rebuilt every 100k.
    If you take care of your ride, it will take care of you. Toyota builds pretty stout motors for all their cars, but if you abuse your car/truck, no amount of engineering is going to save it.
    This particular device may actually increase the longevity of the motor. Consider that unburnt fuel can create carbon build up over time, diminishing the efficiency. So far, we have seen many reports of people getting better mpg. If less fuel is being used, then there is less fuel in the cylinders to remain unburned.
    Now, consider worse case scenario: the eco-block actually causes makes the computer see too much or too little air. Too much air and it injects extra fuel. Too little and it pulls fuel. Too much fuel isn't that big of a deal. You'll notice the engine bog somewhat. Too little and you run the risk of a lean condition. The lean condition would have to be a pretty large deviance. So much that the ECU couldn't compensate for it and retard timing to reduce knock. In both cases, you would notice right away the problem. You could remove the eco-block to see if that makes any noticeable changes. There's really no excessive wear since you would have caught it right away. ECU's have a +/- % fuel trims and to get outside of the range would require something pretty drastic, like the MAF itself failing.
    Since the eco-block doesn't have any moving parts and doesn't have any electrical connectivity to your ecu, your MAF will have failed regardless of the eco-block.
    Just my 2 pesos.
  4. Mar 11, 2015 at 1:33 PM
    #764
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    I agree that the S/C would cause even more wear on the engine. I wasn't arguing that fact, but as you stated, you are guessing as to how much greater the S/C wear would be over this.
    Just because a part doesn't move, doesn't mean it is not causing premature wear on the engine. These engines are built to last based on the stock configuration it is engineerred and built as. This product will cause the engine to run lean, which may create enough heat in the block to cause premature valve problems.
    Until there are vehicles that have traveled 200k miles with one, we will not know the long term issues.
  5. Mar 11, 2015 at 1:41 PM
    #765
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Even with the winky-moti, a serious response. Damn you Internet, can't you ever be clear??
    :D
  6. Mar 11, 2015 at 1:46 PM
    #766
    T Fades
    Simi Valley, CA
    I'm pretty confident Toyota tested all configurations of where the MAF sensor is placed in order to maximize MPGs. There was a reason they chose the stock configuration.
    I'm not saying this product does not do good things in the short run, I am saying (as a person who typically owns vehicles for 2-300k miles), these improvements may have a long term affect that can only be realized with longevity. Of course I do not know that it does, just me being leary of performance upgrades with respect to long term reliability.
  7. Mar 11, 2015 at 1:48 PM
    #767
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    How would you know that the Eco Block caused the problem with longevity?
  8. Mar 11, 2015 at 1:49 PM
    #768
    T Fades
    Simi Valley, CA
    edited my above post...
  9. Mar 11, 2015 at 2:43 PM
    #769
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Is this available for a 1999 2.7L?
  10. Mar 11, 2015 at 2:56 PM
    #770
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    I'm not going to be able to give an accurate reading if it helped with millage or not. I installed the Eco block at 3/4 a tank and installed bigger tires at 1/2. But I can say I didn't feel much if any power loss with adding bigger tires.
  11. Mar 11, 2015 at 3:30 PM
    #771
    Quirt
    Quirt Mad Scientist
    Not currently, but it is on our to do list.
  12. Mar 11, 2015 at 5:00 PM
    #772
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Any update to the Q3 code?
  13. Mar 11, 2015 at 5:07 PM
    #773
    Quirt
    Quirt Mad Scientist
    I just sent it to you.
  14. Mar 11, 2015 at 5:21 PM
    #774
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :laugh: Keyboards - Sarcasm's arch nemesis.
  15. Mar 11, 2015 at 6:13 PM
    #775
    Quirt
    Quirt Mad Scientist
    Dyno fail today :(
    The truck was an automatic that cannot be locked in high gear so the dyno runs would be useless from down then up shifting during the test, sorry guys.
  16. Mar 11, 2015 at 6:15 PM
    #776
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    Shit I got a 6 speed. If no Dyno on a MT by June I will be in SoCal wif my truck after Moab.
  17. Mar 11, 2015 at 6:23 PM
    #777
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Don't see how this is a problem. Plenty of automatic tacomas on here with dyno runs. You just get the 3,000 rpm and up .
  18. Mar 11, 2015 at 7:28 PM
    #778
    Quirt
    Quirt Mad Scientist
    Thanks for that :)
    I am pretty anal about how we run our dyno so we get the most accurate results as possible.
  19. Mar 11, 2015 at 8:33 PM
    #779
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. All autos must start from 3k. Trust me when I say that so many member will complain that it isn't good enough because the rpm range that they spend most of their time driving in isn't shown, and thus the data is useless, to them.
    Been through that many times here, myself. And so everyone is clear, you don't drive at 600 RPMs, and you don't start a chassis dyno at 600 RPMs. Let's be realistic. That makes me chuckle. SALTS.
  20. Mar 11, 2015 at 8:36 PM
    #780
    Yota64
    Yota64 Professional Threadjacker
    So what can I do if I want to know the gains in the 1800-2200 RPM range since that is where 90% of my driving time is spent?
