Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Feb 12, 2015 at 3:55 PM
    #61
    Quirt
    Quirt Mad Scientist
    Thanks for posting that!! Always puts a smile on my face it does... sometimes it pays off to be in the right place at the right time.
    This is a video of the build;
    https://www.youtube.com/watch?v=kTB6tpnmveo
    Tony V likes this.
  2. Feb 12, 2015 at 4:22 PM
    #62
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Do you know that it doesnt work? I say we should let the beta testers collect some data, dynos and fuel trims and then we can all make a decision as to whether this product is good for our trucks or just another wannabe throttle spacer. Based on what ive seen so far, I have high hopes for it. The science makes total sense to me, but then again I inhale a lot of solder smoke
  3. Feb 12, 2015 at 4:38 PM
    #63
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Fuel Mileage is one of the biggest marketing strategies with car manufacturers. If this really saves 1 MPG than why isn't Toyota installing 2$ worth of plastic spacers on everything they sell. I guess if it does really work than Crawford better patent this quickly and sell the technology to the auto manufacturers for billions.
  4. Feb 12, 2015 at 4:48 PM
    #64
    Quirt
    Quirt Mad Scientist
    We actually did patent it before we put it out on the market ;)
    The manufactures have so many hoops they have to jump through that they end up leaving some room on the table for us aftermarket guys to exploit. Most all tuners trim the fuel at high loads / high RPM's when we make stage maps to replace the factory's tune. This product uses the same math as an aftermarket tune but on a smaller and safer scale.
    The increase in fuel mileage comes directly from injecting less fuel, it's pretty simple math.
  5. Feb 13, 2015 at 6:05 AM
    #65
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Toyota dont even need to install this spacer. It can be done via the flash of the ECU. Cause of this flash, Tacoma running very rich at WOT. I understand the way this spacer is working and basics behind it. In fact it's a mechanical MAF calibrator.
  6. Feb 13, 2015 at 6:33 AM
    #66
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Their fueling strategies are designed to work across every worst case scenario. Not best. From excessively clogged fuel filters, hot climates, cold climates, severe elevation changes. Install an AFR gauge and get an idea of how rich these engines run when climbing the load scale to 100%. Fuel pigs.
    DanoDavis likes this.
  7. Feb 13, 2015 at 8:35 AM
    #67
    Quirt
    Quirt Mad Scientist
    Correct, they must build in a cushion for many variables.
  8. Feb 13, 2015 at 8:37 AM
    #68
    Quirt
    Quirt Mad Scientist
    Exactly, they could make the exact same changes if they chose to do so.
  9. Feb 13, 2015 at 10:21 PM
    #69
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    any love for a first gen taco? live right down the road :D also used to own a suby :D
  10. Feb 14, 2015 at 7:16 AM
    #70
    Quirt
    Quirt Mad Scientist
    Looks like Q1 is the part for your taco;
    1999-00-01-02-03-04 Tacoma 3.4L #197-6020 =Q1
    2005-06-07-08-09-10-11-12 Tacoma all 4.0L #197-6030 =Q1
    2000-01-02-03-04 Tundra 3.4L #197-6020 =Q1
    2005-06-07-08-09-10-11 Tundra 4.0L #197-6030 =Q1
    2012-13-14 Tundra 4.0L #197-6160 =Q2
    Drop on by next week and we will install one for you.
  11. Feb 14, 2015 at 8:08 AM
    #71
    paranoid56
    San Diego
    14 double cab taco
    oh, i can just order and install, its only 2 bolts :D do you have a dyno chart for before and after of this on a first gen taco?
  12. Feb 14, 2015 at 10:45 AM
    #72
    Quirt
    Quirt Mad Scientist
    Yea, easy order and install. We have three different trucks headed our way for some dyno runs so we can show the before and after power numbers. We're at their mercy for the actual dates though.
  13. Feb 14, 2015 at 10:44 PM
    #73
    paranoid56
    San Diego
    14 double cab taco
    if you are around, i am off monday and can swing by for a dyno test :D
  14. Feb 15, 2015 at 8:56 AM
    #74
    Quirt
    Quirt Mad Scientist
    Sure, I'll be there all day. Afternoon would be best.
  15. Feb 15, 2015 at 9:12 AM
    #75
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    HHHHMMMMMMMMM
    Tor, think I should swing by since I am also local?
  16. Feb 15, 2015 at 4:11 PM
    #76
    Yota64
    Yota64 Professional Threadjacker
    Can't wait to see dyno.
    General question But how does a dyno tell us how mods work when not in wot? Like daily driving or normal accel?
    I know it's off topic but seems we have some professionals in here
  17. Feb 15, 2015 at 8:09 PM
    #77
    paranoid56
    San Diego
    14 double cab taco
    oh wow, um yea, i can swing by. what time would be best for you? also, what would you need from me?
  18. Feb 15, 2015 at 8:25 PM
    #78
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
  19. Feb 16, 2015 at 4:42 AM
    #79
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    More test data equals more accurate results. Worthy of speaking to them about it. :thumbsup:
  20. Feb 16, 2015 at 5:31 AM
    #80
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    It doesn't, dyno is open loop test. If your normal driving includes open loop that will help, but dyno doesn't tell you about closed loop operation.
