Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Mar 11, 2015 at 8:36 PM
    #781
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Quirt, when you finally get a manual in for dyno, do it in 4th gear. It isn't 1:1, but it is close. 1:1 is 5th. However, speed cut will likely kick in before the dyno pull is finished, if done in 5th gear, and the governor hasn't been removed. So in 99% of cases on these transmissions, 4th is the best gear.
  2. Mar 11, 2015 at 8:42 PM
    #782
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Wait for someone with a manual to dyno. If you want to see a graph.
    Have a datalogging device of your own. If you have a pre '09+, that can be a UCON or X-1. After that year model, a datalogging scan tool will work. Minus a wire-in EMS.
  3. Mar 12, 2015 at 4:47 AM
    #783
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You were warned that the Taco auto tranny was a known dyno issue, but did you listen? No.
    Kids,,, I tell you... :D
  4. Mar 12, 2015 at 7:41 AM
    #784
    Quirt
    Quirt Mad Scientist
    Lol... me, listen?? :D
  5. Mar 12, 2015 at 8:38 AM
    #785
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Just ordered the Q1 for my 2012.
    I'm running really rich (during WOT) with the TRD SC and reflash, let's see if this brings me to a better place :).
  6. Mar 12, 2015 at 8:53 AM
    #786
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  7. Mar 12, 2015 at 8:53 AM
    #787
    Quirt
    Quirt Mad Scientist
    Thanks, and please share your findings :)
  8. Mar 12, 2015 at 9:03 AM
    #788
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    wow. That's pretty good.
  9. Mar 12, 2015 at 9:47 AM
    #789
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Never heard back from Jon about the 2010 V6 Camaro. Any idea if you have anything available?
  10. Mar 12, 2015 at 11:01 AM
    #790
    Quirt
    Quirt Mad Scientist
    Chevrolet Camaro SS 2010 6.2L and v6 Hitachi Q3
    Looks like Q3 is your fittment, I know we have already sent some out for Camaro's
  11. Mar 12, 2015 at 1:07 PM
    #791
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I'm sure this has been covered, but can this be used with a CAI?
  12. Mar 12, 2015 at 1:18 PM
    #792
    Quirt
    Quirt Mad Scientist
    They make the same mathematical change to the ECU so if you put the two together then it would run too lean.
  13. Mar 12, 2015 at 1:19 PM
    #793
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    What about a 1st gen Tacoma 3.4 V6...
    Would the deck plate mod affect anything?
  14. Mar 12, 2015 at 1:24 PM
    #794
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You should really add the assumption that this "change" is based on the CAI diameter at the MAF being larger then stock. If the diameter is the same, the EB may help, assuming it does help to begin with :D
    "most" of the Tacoma CAIs use the same diameter in order to ensure that the MAF sensor reads as stock. The Volant was known to be different, and the Gen2 TRD CAI was known to have some flow delta differences.
  15. Mar 12, 2015 at 1:33 PM
    #795
    Tacomanator
    Clam Slammer
    Southern Cali
    I have the Volant with air scoop and i'm wondering if the Q1 with stock intake will be better or worse. My MPG is pretty shitty, looking to bump it up a bit.
  16. Mar 12, 2015 at 1:38 PM
    #796
    Quirt
    Quirt Mad Scientist
    Interesting, I assumed that the CAI on these vehicles had a larger ID than the OEM unit. My bad
    In that case, if the ID is the same as the stock unit then our EB will work as designed.
    Thanks Lurker :p
  17. Mar 12, 2015 at 1:39 PM
    #797
    Quirt
    Quirt Mad Scientist
    Measure it to see what the difference is and let us know the percentage of change.
  18. Mar 12, 2015 at 3:28 PM
    #798
    Del Scorcho
    Del Scorcho O-------l
    Eagle, ID
    DCLB 6 banger, 4X and Super Charged
    Magnuson Supercharger, 2.85 Stealth Pulley, TRD Baja Suspension, Walbro Fuel pump, Icon add a leaf, Method 701s
    I'd better not EVER drive my truck. That could cause premature wear and tear too...
  19. Mar 12, 2015 at 4:18 PM
    #799
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Just installed my Q3. I'll let you guys know if I notice any differences over the next few tanks. Currently have 7000mi of MPG history to compare to.
  20. Mar 12, 2015 at 4:50 PM
    #800
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    I just tried to install Q1 into my afe intake. No go. The maf on the afe is already spaced out about a 1/4" with plastic spacers. So the provided screws are not long enough. Should I find longer screws and put it on? Or it'll be spaced out too far and lean out?
