Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. May 7, 2015 at 10:16 AM
    #1121
    Quirt
    Quirt Mad Scientist
    The only thing I will monitor is the actual air fuel ratio as this is what I tune by. When doing a dyno run the ECU runs in the open loop fueling mode so there are no closed loop fuel trims happening.
  2. May 7, 2015 at 2:02 PM
    #1122
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Got my new O ring in the mail today. Popped it in on my lunch break. Muuuuch better fit
    Quirt likes this.
  3. May 7, 2015 at 2:56 PM
    #1123
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    I still don't have an o-ring, or my email replied.
  4. May 8, 2015 at 10:32 AM
    #1124
    motorhead310
    motorhead310 Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
    Any idea when they will make one for 01-04 3rz? Seems to be the only engine missing
  5. May 8, 2015 at 11:50 AM
    #1125
    Quirt
    Quirt Mad Scientist
    Can you take a photo of the MAF sensor for me? there is a good chance that Q1 will fit that motor.
  6. May 8, 2015 at 6:10 PM
    #1126
    motorhead310
    Pomona , Ca
  7. May 8, 2015 at 6:11 PM
    #1127
    motorhead310
    Pomona , Ca
    Sorry bout the late reply..
  8. May 8, 2015 at 8:27 PM
    #1128
    Why J
    Why J I'm the master of my own domain.
    2012 DCSB V6 SR5 Prerunner
    OEM Roof Rack, 3" lift, 1.25" Spidertrax Wheel Spacer, Front skid plate
    I was working on it today. I have no fueling issues, no air intake issue and no unmetered air getting in. It is pretty simple. When the block is not installed my fuel trims are +/-3 after the block is installed my idle fuel trim is 7+ under load or crushing it goes 25+ And detonates.
    Also I have noticed that my shift points have changed with the block installed. Which is what gives the fuel savings. Is that good or bad? IDK but the shift points suck and it lives in lower RPMs than it does stock. And if you reference back to the Dyno numbers Quirt posted the block doesn't do anything until the high to WOT RPMs so any MPG savings are do to the altered shift points from the MAFs lower reading. Not any increase in horsepower or torque.
  9. May 8, 2015 at 8:37 PM
    #1129
    epa4wd
    Eduardo
    2019 SR
    Looks like Jon missed my emails again. Another week, no response, no o-ring....
  10. May 9, 2015 at 6:25 AM
    #1130
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you tried calling?
  11. May 9, 2015 at 8:32 AM
    #1131
    Ripper
    Ripper Well-Known Member
    :pout:I have one I haven't installed yet, you can have it. PM me your address and I'll mail it out to you.
    Quirt and epa4wd[QUOTED] like this.
  12. May 9, 2015 at 5:08 PM
    #1132
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    How are you figuring out there is not any increase in hp or torque? It was my understanding that no tacomas have been dyno'd yet. Also curious, have you read the linked thread about the tsb flash that has helped 12+ model years with shifting?
  13. May 9, 2015 at 6:23 PM
    #1133
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Thats just crazy talk right there!
    epa4wd and Torspd[QUOTED] like this.
  14. May 9, 2015 at 6:37 PM
    #1134
    epa4wd
    Eduardo
    2019 SR
    Yeah! I mean I would have to get my phone, put the passcode to unlock it, touch a combination of magic numbers that makes someone speak from the inside my phone, I mean how tiny must he be to fit in my phone, how does he get there, its crazy!!!!!!
    Anyway, Ripper I really appreciate the offer, but I will be returning the eco-block though, and yes I was planning on calling; when I get the thread updates in my email, it reminded me to call the following day, but once I get to work, it gets in the bottom of my to do list and by the end of the day I didn't call. Sucks that they didn't respond to my emails though, looks like its as difficult for them to respond to an email as it is to me to call.
    Ripper likes this.
  15. May 9, 2015 at 7:49 PM
    #1135
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    whats with the OP, 7 posts and gone?
    I have had this in for a couple months now, I see no change at all
    yes my mileage is better than when I put it in, but its warmer out, no more winter fuel. and that goes for everyone here, we all got them and installed in winter. ill probably be pulling it soon for a few tanks to see if its doing anything
    im not sold at all. no dynos yet, nothing.
  16. May 9, 2015 at 7:58 PM
    #1136
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    Dyno is scheduled for the 2nd of June....I have to drive all the way from VA to Socal just for the Dyno run. I'm sure Quirt will post them up as soon as complete.
    Also the shift point thing might mean something to you auto drivers but I have a 6 speed and show a 2 MPG difference. I recently removed mine for a trip to the dealer and left it off to see how I was doing now that the temps are up and winter gas is on the way out. I'm not removing it again.
    Quirt likes this.
  17. May 9, 2015 at 8:33 PM
    #1137
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Didn't notice much difference to power or gas mileage so I took my Q1 off the 4Runner. Didn't want to return it so I threw it on the LS430 I just picked up instead. I have less than an hours worth of drive time on the Lexus so I doubt I'll notice anything. The Lexus hauls ass compared to my 4Runner, that's about all I know as of now.
    Quirt likes this.
  18. May 10, 2015 at 4:45 PM
    #1138
    Why J
    Quirt or someone else has posted a dyno sheet earlier in the thread. It showed zero change until 4-5k out the WOT. Who DD at 4-5k?
    My shifting was fine prior to the block. What I am saying is that the ECU is seeing a different MAF value and is adjusting the shift parameters accordingly.
  19. May 11, 2015 at 8:56 AM
    #1139
    Quirt
    Quirt Mad Scientist
    No problem. I am not sure when we will get that style done, we have three other ones ahead of it ;)
  20. May 11, 2015 at 9:04 AM
    #1140
    Quirt
    Quirt Mad Scientist
    Try taking it off the LS430 after you get used to driving it, it is easier to feel a loss of power.
