Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. May 11, 2015 at 6:34 PM
    #1141
    roehoe72
    roehoe72 Well-Known Member
    Dan
    Vacaville, CA
    04 dc prerunner v6 trd
    Got my oring! Now i just need to install it! Thanks quirt and jon!
    Edit: just installed oring. Hell of a time getting the ecoblock to mate with the maf. Had to spit on it to ease it in (thats what she said). Fired the truck up, no cel. Sprayed some maf cleaner around the seam, no evidence of a leak. Gonna monitor the ltft on the drive into work tomorrow morning. Will report back. Again, thanks quirt and jon.
    Quirt likes this.
  2. May 12, 2015 at 1:51 PM
    #1142
    Quirt
    Quirt Mad Scientist
    You are welcome! FYI... my GF helped pick out that oring, hence the need to spit on it ;)
  3. May 12, 2015 at 4:35 PM
    #1143
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. May 12, 2015 at 5:12 PM
    #1144
    roehoe72
    Dan
    Vacaville, CA
    Yeah, im gonna keep my mouth shut on that one. Regarding whyj's post on ltft. Im still showing on my torque app that im running around +12-15 ish. I do notice a punchier throttle. Not sure about mpg's cause i didn't have a baseline to judge from. Is this normal or ok?
    Quirt[QUOTED] likes this.
  5. May 13, 2015 at 6:26 AM
    #1145
    Quirt
    Quirt Mad Scientist
    That is totally normal and as expected when the ECU in running in closed loop fueling. That is the amount of fuel needed to offset the Eco Block so it gets back to 14.7 to 1 AFR.
  6. Jun 1, 2015 at 11:29 PM
    #1146
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    I guess tomorrow is Dyno day.
    -be sure to post up the results, thanks.
    RJM
  7. Jun 1, 2015 at 11:46 PM
    #1147
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    No dyno, truck rolled a few times last week and is totaled.
  8. Jun 2, 2015 at 12:20 AM
    #1148
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    Yup...Dyno truck is gone...sucks. I'm sure another 6spd will step up...
  9. Jun 2, 2015 at 7:05 AM
    #1149
    Loco38SUP
    North Seattle, WA
    WTF?
    Hope you are OK.
    Damn...do I need to run a craigslist ad to get a truck over to Crawford for that dyno or what...lol.
    RJM
  10. Jun 2, 2015 at 8:46 AM
    #1150
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    how do we return these? is there info on the website?
  11. Jun 2, 2015 at 9:33 AM
    #1151
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Wtf. Hope driver is OK. I have been waiting for dyno results before I buy.
  12. Jun 3, 2015 at 6:12 PM
    #1152
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    OK, here's my short experience with the Eco-Block installed on my 2013 Taco, DCLB. Prior to the installation of the Eco-Block in mid March 2015 I took a road trip. Conditions: Stock TRD Sport, OEM 265/65/17 tires inflated to 38 PSI. All gas used is 87 Octane. Did not use the air conditioning at all. All highway travel. One driver (200 LB), plus about 100 LB of luggage/gear, ARE Shell (175 LB). Total weight: 475 LB. All mileage numbers calculated using the miles driven divided by gallons used method.
    PRE-Install
    80+ MPH (cruise control): 16.1 MPG, 68° OAT, Flat Hwy, FL/GA I-75/Turnpike. No A/C, (three tanks averaged).
    75 MPH (cruise control): 17.7 MPG, KY/TN, some hills. 55° OAT, No A/C, (two tanks averaged).
    ________________________________________________________________________________________________________________________
    Post-Install
    All City driving during Jan/Feb: 15.1 MPG, OAT 20°, lots of winter warm-ups etc. No A/C, heater used extensively, (four tanks averaged). Some heavy snow driving. Occasionally two passengers, total weight never exceeding 450 LB.
    April 2015, Highway trip on I-64 East, ARE Shell (175 lb), 300 lbs total weight of passenger, luggage and gear. No lift, OEM 265/65/17 tires inflated to 38 PSI. Total weight carried 475 lbs. 87 octane gas.
    Tank 1: 143 miles on 7.46 gal. = 19.2 MPG, OAT 60°. 75 MPH on cruise control, No A/C, 87 octane gas (I-64 East KY/VA)
    Tank 2: 262 miles on 14.04 gal. = 18.71 MPG, OAT 60°. 75 MPH on cruise control, No A/C,
    Tank 3: 183 miles on 9.34 gal. = 19.59 MPG, OAT 62°. 70 MPH cruise control, No A/C (I-70 in MD)
    Tank 4: 282 miles on 14.5 gal. = 19.45 MPG, OAT 62°. 70 MPH cruise control, No A/C
    *Average MPG for the above tanks (without using A/C) is: 19.23 MPG
    Tank 5: 201 miles on 12.25 gal. = 16.41 MPG, OAT 82°. 80 MPH cruise control, with A/C
    Tank 6: 182 miles on 10.9 gal. = 16.69 MPG, OAT 82°. 80 MPH cruise control, with A/C
    Tank 7: 191 miles on 11.2 gal. = 17.05 MPG, OAT 85°. Mixed/City driving, with A/C
    *Average MPG for the above tanks (using A/C) is: 16.71 MPG
    May 2015, Highway trip on I-65 north. ARE Shell (175 LB), 5 men @ 200 LB each, bed filled with luggage and fishing gear, 50 LB per bag, 50 LB other gear. Total weight: 1425 LB.
    Tank 1: 303 miles on 17.0 gal. = 17.82 MPG, OAT 70°. 80 MPH cruise control, No A/C.
    Tank 2: 181 miles on 10.2 gal. = 17.74 MPG, OAT 70°. 80 MPH cruise control, No A/C.
    Tank 3: 271 miles on 15.7 gal. = 17.26 MPG, OAT 67°. 80 MPH cruise control, No A/C.
    *Average MPG for the above tanks (without using A/C) is: 17.60 MPG
    Tank 4
    : 245 miles on 14.7 gal. = 16.66 MPG, OAT 60°. 70 MPH cruise, towing boat and trailer, same men. Total weight 1850 LB, No A/C
    Tank 5: 256 miles on 15.7 gal. = 16.30 MPG, OAT 60°. Mixed highway/backcountry driving, towing boat and trailer, same men. No A/C. Total weight 1850 LB, No A/C
    Tank 6: 205 miles on 12.8 gal. = 16.01 MPG, OAT 60°. Mixed highway/backcountry driving, towing boat and trailer, same men. No A/C. Total weight 1850 LB, No A/C
    *Average MPG for the above tanks (without using A/C) is: 16.32 MPG
    Conclusions:
    1. It appears that after installing the Eco-Block, the Taco gained more than 1, but less than 2 MPG (1.53 to be exact) for similar driving conditions.
    2. The use of A/C really sucks away MPGs.
    3. Towing a boat/trailer/guys/gear with the Eco-Block produced good MPGs IMO.
    4. Winter driving conditions (and winter gas) are the devil.
    Questions/Comments?
    Quirt likes this.
  13. Jun 3, 2015 at 8:51 PM
    #1153
    North222
    North222 Well-Known Member
    Did you catch any fish?
  14. Jun 4, 2015 at 4:38 AM
    #1154
    SigSense
    Yes, but not the fish I really wanted: Muskie. Those darn things are elusive!
  15. Jun 4, 2015 at 2:44 PM
    #1155
    North222
    I've never fished for them specifically, but I've heard stories. Trophy fish for sure.
    It's too bad about the dyno - on multiple fronts. I was looking forward to seeing the results. It's really too bad about the truck rolling, Moab....it looks like? I hope the driver fared well, apart from truck damage.
  16. Jun 4, 2015 at 4:54 PM
    #1156
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Yes, it was in Moab. Driver and his dog were both okay. I'm interested to see dyno numbers too, but mostly for my own curiosity. I have had the eco block in for over 10,000km now.
    Quirt likes this.
  17. Jun 15, 2015 at 3:19 PM
    #1157
    Quirt
    Quirt Mad Scientist
    Our dyno does not care about a few scratches!! Glad to hear that you are ok, the truck is replaceable...
  18. Jun 15, 2015 at 5:01 PM
    #1158
    loco
    Phil
    Virginia Beach, VA
    Called that Monday and left a message for yah Quirt. Wish I could have gotten her on your dyno...she wasn't doing much on her own power after the part out in Moab.
  19. Jun 16, 2015 at 7:39 AM
    #1159
    Quirt
    Quirt Mad Scientist
    Yea, it is what it is. Thanks anyways! What will you replace it with?
  20. Jun 16, 2015 at 7:49 AM
    #1160
    loco
    Phil
    Virginia Beach, VA
    Already replaced with a 96 Landcruiser diesel swap...cd47f6a127b5caa7364d7f8fa27e4529_0e0f94fa23a42dfeaf350acf9a67dc0f097e116b.jpg
    bobsuruncle and SigSense like this.
