Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Aug 2, 2015 at 4:10 AM
    #1221
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    After Getting 10 pages in I have to say:
    Wow, so much effort into digging, sarcasm and scepticism that you would think Crawford were running for the presidency.
    It's a $45 part guys, relax. Purchase it if you want to try it and if not let it go, time end effort spent better elsewhere other than debating a part most of you do not own.
    No I don't work for Crawford, no I did not make this account just to jump into this conversation and no I'm not running for the presidency.
  2. Aug 5, 2015 at 8:42 PM
    #1222
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    This does not work. It just doesn't. If there are believers out there pm me and you can have mine for $20.
  3. Aug 5, 2015 at 8:55 PM
    #1223
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Sold. Pm inbound.
  4. Aug 5, 2015 at 9:03 PM
    #1224
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Dam it I had to listen to my wife's day at work and missed out on a$20 eco block.
    FatTexan and nfs257 like this.
  5. Aug 5, 2015 at 9:08 PM
    #1225
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    I don't know... my gas mileage went back up 2mpg after putting it back on. So I am perfectly content with it.
    Torspd and bobsuruncle like this.
  6. Aug 9, 2015 at 8:14 AM
    #1226
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    It does not work for YOU, to be specific. It has worked for many others, including myself. Thanks for trying it out and I am sorry it did not provide the results that other Tacoma owners have experienced.
    Torspd likes this.
  7. Aug 9, 2015 at 8:22 PM
    #1227
    Yota64
    Yota64 Professional Threadjacker
    Now that there is more reason to believe this works, was the question of reliability ever addressed? There's got to be a trade off for this, right? A reason Toyota didn't tune this way in the first place?
  8. Aug 12, 2015 at 12:00 PM
    #1228
    Bhwang
    Bhwang Well-Known Member
    Josh
    Canada
    Tacoma
    Working on it. Never Ending :)
    anyone tried the eco block with a URD True Cold Air Intake yet ?
  9. Aug 12, 2015 at 12:29 PM
    #1229
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    What's your concerns about reliability? I don't think that it can be worst then most of mods Tacoma owners do on their truck like super charger, CAI, exhaust, headers, lift, etc..
  10. Aug 12, 2015 at 12:33 PM
    #1230
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I haven't seen anyone try this with the URD. Also note that if you have the MAF Cali installed. Personally, I would not run the MAF Cali with a properly tuned map and this spacer. Risk of running too lean is too great.
  11. Aug 12, 2015 at 12:36 PM
    #1231
    Vassily28
    There is absolutly no reason to run a MAF cali with the ecoblock. The purpose of the ecoblock is to mechanicly emulate what your doing with a MAF calibrator to correct AFR at WOT. You are way better serve by a MAF cali (well tuned).
  12. Aug 12, 2015 at 12:40 PM
    #1232
    Yota64
    My concerns about reliability are that there must be a reason Toyota didn't choose to do this in the first place. Notice, Toyota trucks are generally more reliable than others but a little less efficient. It's also known that Tacomas run very rich, and I think there is a correlation between the two. Not that I know everything about how the engine was designed, nor do I know everything about this spacer, (which is why I ask the question) but it seems to me that the premise of this gained MPG by simply moving a piece an inch higher in the system, is that we are eating into something. If I had to guess what it was I'd say it's making the engine not run so rich so to preserve some gas. I'm not saying this product is bad for the engine in any way, just asking "what gives" and explaining my curiosity.
    As for a S/C, I think that's a little bit of apples to oranges. A supercharged 1gr might not last as long as a stock 1gr with the eco-block (or it may outlast it, who knows?) but the eco-block doesn't cost 5K and give 68 HP. Yes I agree there are worse things you could probably do to the truck (even running oversized tires can be considered detrimental)
  13. Aug 12, 2015 at 12:41 PM
    #1233
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    MAF calibrator is for open loop to prevent an excessively rich mixture, not the same concept as the ecoblock to be perfectly honest.
    The Ecoblock won't make open throttle response any better.
  14. Aug 12, 2015 at 12:45 PM
    #1234
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not totally correct the Cali can be used to "fix" the MAF readings in closed loop, similar to the mechanical method of the block. This is how the Cali can fix the MAF readings for an improperly matched intake tube, like in the Volant.
  15. Aug 12, 2015 at 12:48 PM
    #1235
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Toyota, as all manufacturers, need to design to a set of specs that will work for the vast majority and will be safe over a wide range of conditions. As far as AF then, richer is safer, as too rich causes problems, but not catastrophic problems. Too lean can cause holed pistons and other internal nasty damage.
  16. Aug 12, 2015 at 12:49 PM
    #1236
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Hmm, really? Not throwing anything out but I was always told the MAF Calibrator didn't do anything for tuning once the engine was in closed loop. All the MAF Calibrator is "fixing" on those Volant intakes is the resistance value coming from the MAF to get the engine to not throw a code. The MAF calibrator is not for tuning the closed loop part of the engine cycle, at least not that I know of.
  17. Aug 12, 2015 at 12:55 PM
    #1237
    Bhwang
    Josh
    Canada
    Tacoma
    No MAF Cali yet, maybe in the future but for now truck runs amazingly with jus the URD TCAI !!!
    But if there is anyway to get a few extra MPG out of a 4.0L with this on the cold air intake I would love to add it !
  18. Aug 12, 2015 at 12:56 PM
    #1238
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    "Induced MAF sensor error" is the term to research up on. While in closed loop the AF sensor is more important then the MAF, but the MAF is still used to set the injector pulse, with the AF sensor used as the process end check that the AF ratio stays optimum. It's definitely borderline to call that tuning, as with the Volant, the MAF readings are off due to the intake tube cross section delta with stock. But end of the day, the Cali helps set the MAF reading such that short/long term fuel trims don't get all wacked out. Same concept for the block, modify the MAF reading to subtract some injector pulse.
  19. Aug 12, 2015 at 4:23 PM
    #1239
    Vassily28
    ^+1, your right. Normaly you will use it to correct your LTFT and have close to zero and then set your AFR in open loop. But like you said, doing this you can correct for important LTFT that generate error codes (correct me if i'm wroong but i think a code is produce when total trim is larger then +-15%).
    And yep even with a MAF, in closed loop an AFR of 14.7 will be maintain by the ECU.
  20. Aug 12, 2015 at 4:31 PM
    #1240
    Vassily28
    Sorry but to be honest the ecoblock is reducing the MAF reading by moving the position of the MAF sensor in the flow patern and the result is a reduced reading and then a leaner mixture at WOT. I thinks it's clear that mechanical vs electronic adjustment are not exactly the same concept it's why i was talking about emulation. Carburator and FI system are not exactly the same concept but they have the same purpose.
