Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Sep 4, 2015 at 10:39 AM
    #1281
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
  2. Sep 5, 2015 at 11:19 AM
    #1282
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
  3. Sep 5, 2015 at 3:10 PM
    #1283
    elnip
    LC,NM
    Trust me the v6 is MAP and the i4 is maf. I could not believe it at first but verified on the car.
  4. Sep 5, 2015 at 3:13 PM
    #1284
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Might as well buy a new one. Even if someone sold it to you for cheaper after shipping it will be in the ballpark of a new one.
  5. Sep 5, 2015 at 3:22 PM
    #1285
    nd4spdbh
    SoCal
    Already got one coming from a member here
    Mr. Ed's taco likes this.
  6. Sep 5, 2015 at 3:23 PM
    #1286
    TeamSarcasm
    The better coast
  7. Sep 5, 2015 at 4:09 PM
    #1287
    nd4spdbh
    SoCal
    ^ figured id give it a try worst case pass it along to another member here on the forums.
  8. Sep 12, 2015 at 6:19 AM
    #1288
    Mr. Ed's taco
    Mr. Ed's taco Well-Known Member
    First tank after removal averaged 16.8 mpg. No crazy jump.
  9. Sep 25, 2015 at 10:44 PM
    #1289
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    I gained about 1.5 mpg over the last 3 tanks.........................all since I removed this P.O.S. from my truck.
    Rock Lobster likes this.
  10. Sep 25, 2015 at 11:04 PM
    #1290
    TeamSarcasm
    The better coast
    Move along :spy:
  11. Sep 25, 2015 at 11:09 PM
    #1291
    pudge151
    Sean
    Connecticut
  12. Sep 25, 2015 at 11:12 PM
    #1292
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Wat
  13. Sep 25, 2015 at 11:25 PM
    #1293
    TeamSarcasm
    The better coast
    YOU SAW NOTHING!!!
    I missed that part.
  14. Sep 25, 2015 at 11:26 PM
    #1294
    T4RFTMFW
    :rofl:
    Actually Lold.
  15. Sep 26, 2015 at 2:11 PM
    #1295
    nd4spdbh
    SoCal
    MPG's have not changed for me with it installed, though it has felt more "lethargic"
    This could be due to the hotter weather we have been having but it was felt as soon as i put it on.
    So after 2 tanks i have taken the block off and will see how she feels for the next big, I am also watching long term fuel trims. I noticed with the block in LTFT's were kinda high (7-10), i dont remember seening them ever that high which would make sense that the ecu is going hmm, shes running a bit lean (due to less airflow seen at the maf) let me add a smidge more fuel.... completely negating closed loop gains (where we drive 99% of the time).
    I cant speaker for WOT (open loop) gains, as if there were any they were minimal and not felt.
    Keep in mind, i have an intake manifold spacer between my upper n lower manifold halves. So maybe that changes any gains made by the block.
    Either way, back to stock to see what its like for a bit.
  16. Sep 28, 2015 at 8:14 AM
    #1296
    nd4spdbh
    SoCal
    FYI, after taking the ecoblock off Long term Fuel trims have gone WAY DOWN.
    Before like stated they were always between 7-10, averaging around 8.5
    Now they are 0-3, averaging 2.3
    Obviously the ECU sees the difference in air flow and accounts for it....
  17. Sep 28, 2015 at 8:27 AM
    #1297
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    Can you explain what that means to someone who knows nothing about the fuel trim numbers ?
    Sje1124 likes this.
  18. Sep 28, 2015 at 8:35 AM
    #1298
    nd4spdbh
    SoCal
    So long term fuel trim is a "long term (less than instantaneous)" overall adding or subtracting of fuel to the system.
    So the way the eco block works is moves the MAF sensor so that the ECU sees less airflow which should lean out the fuel mixture because less air means less fuel.
    While initially that might be the case, but over time (like one full heat cycle drive) the ecu realizes hey.... why am i seeing a slightly lean mixture at the o2 sensors in the exhaust.... hmm well ill trim up the fuel an add 7-10% more fuel to compensate for the fact the mass airflow sensor is seeing the 7-10% less airflow to get my actual o2 reading back to where i want them.
    Essentially being a closed loop system that is constantly monitoring all the sensors and has a very small working window for fueling at any given rpm / load.... changing one thing it will compensate and get itself right back to "normal".
    I cant say for 100% sure that the eco block does nothing but unfortunately numbers do not lie.... the truck adds an average of 6.5% more fuel at any given point with the eco block in, negating any "leaning out" effects that the eco block claims.... also my mpgs never changed but worse my truck felt lethargic.
    bluewaters182[QUOTED] likes this.
  19. Sep 28, 2015 at 8:39 AM
    #1299
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    So since it's adding 7-10% more fuel what are the MPGs doing?
  20. Sep 28, 2015 at 8:40 AM
    #1300
    nd4spdbh
    SoCal
    ^ see my ninja edited post.
