Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Sep 28, 2015 at 8:41 AM
    #1301
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Sneaky :spy:
  2. Sep 28, 2015 at 8:47 AM
    #1302
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    Thanks, very well explained.
  3. Sep 28, 2015 at 9:46 PM
    #1303
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    i totally agree with you about the LTFT's going down after removing the eco block, and also about the mpg's going up after removing it. i need to send this thing back lol.
  4. Sep 28, 2015 at 9:48 PM
    #1304
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    I just removed mine this evening after using it all year. Curious to see any change.
  5. Sep 29, 2015 at 1:04 AM
    #1305
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I removed mine two weeks ago.
  6. Sep 29, 2015 at 2:13 AM
    #1306
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    What kind of review can you provide? Did you track your MPGs the entire time it was installed?
  7. Sep 29, 2015 at 7:10 AM
    #1307
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    The purpose of the Ecoblock never been to lean the mixture in closed loop. It lean it in open loop only and in closed loop it is supposed to move you on the timing map cause of the different (lower) MAF reading.
    A higher LTFT doesn't mean that you're consumming more fuel.
    About the results, to know if it raise or not the MPG, i can't say cause never use it.
  8. Sep 29, 2015 at 7:13 AM
    #1308
    samiam
    Sam
    Stinky Vegas
    I don't keep hard data on MPG's. I monitor my Scangauge. I average about 17.5 MPG on the way to work. Oddly enough, today was 15.5. I was more curious about feeling a difference in power. Today it felt a little lathargic. I'll continue to monitor throughout the week.
  9. Sep 29, 2015 at 7:33 AM
    #1309
    SigSense
    So people that purchased the product and saw an increase in their MPGs are fools? Help me understand your ignorant post.
    deeezy and Vassily28 like this.
  10. Sep 29, 2015 at 7:43 AM
    #1310
    samiam
    Sam
    Stinky Vegas
    I wonder if there is a difference between newer and older Tacomas.
  11. Sep 29, 2015 at 8:18 AM
    #1311
    bluewaters182
    Greg
    Ohio
  12. Sep 29, 2015 at 8:21 AM
    #1312
    Sje1124
    Sean
    Louisiana
    Just a few
    I would agree, waste of $40 on my part but oh well.
  13. Sep 29, 2015 at 9:54 AM
    #1313
    SigSense
    I guess that myself and others can be set into the foolish category then. Do you believe that the Earth is flat?
    deeezy likes this.
  14. Sep 29, 2015 at 1:50 PM
    #1314
    SigSense
    Excellent! I'll get your "Flat Earth Society" T-Shirt sent out before midnight!
  15. Sep 29, 2015 at 4:42 PM
    #1315
    bluewaters182
    Greg
    Ohio
    Please send $5 to save the unicorns fund
  16. Sep 29, 2015 at 4:52 PM
    #1316
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    I got one and all it does is throw a check engine light cant get anyone from the company to explain it or give me a refund please use caution
  17. Sep 29, 2015 at 8:23 PM
    #1317
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    what did they say to you when you asked for a refund? did you email or call them? just wondering because i want to send mine back also lol
  18. Sep 29, 2015 at 10:06 PM
    #1318
    samiam
    Sam
    Stinky Vegas
    For those that are getting check engine lights, did you request the the larger o-ring, which fits tighter eliminating air leaks?
  19. Oct 5, 2015 at 10:38 AM
    #1319
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    A higher LTFT definietly means you are consuming more fuel.... if the system on a long term average is adding 10% more fuel to its base map vs 3% (that i typically see given the mild temperatures and sealevel driving i do).... you are adding 7% extra fuel to the base map given the sensor readings.
    The ecu is simply compensating for the slightly less than designed air readings at the maf by compensating with extra fuel getting you right back to where you started.
    All in all my truck is running a lot better without the eco block.... it wont be going on my truck.
  20. Oct 8, 2015 at 1:05 PM
    #1320
    Vassily28
    Sorry but no.
    It only means that the ECU need to add fuel to maintain the correct AFR, let say 14.7. If your not entering more air, you dont need more fuel. With the ecoblock it's normal to have higher fuel trim cause moving the MAF sensor in the flow path reduce the reading of it. Without fuel injection loop you will normaly run leaner (and it's the case in open loop) but the ECU will correct the fuel injected to maintain 14.7 AFR.
    It's only a compensation like aiming a bit left of the target cause your riffle shooting a bit right.
