Eco Block from crawford performance
Discussion in 'Performance and Tuning' started by laney487, Jan 26, 2015.
  1. Feb 17, 2015 at 1:04 PM
    #121
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    I'm interested to see how this goes with the snorkel. I am almost always showing IAT at or within 1* of ambient temp which in the summer is great but in the winter when it's 15* my fuel mileage blows! Tons of power, crap mileage!
  2. Feb 17, 2015 at 1:08 PM
    #122
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    THAT^
    I give him a week before he realizes his sales tactics have failed. Go to a civic forum brotha. Unless you have dyno charts to back up said gainz GTFO.:cool:
  3. Feb 17, 2015 at 1:41 PM
    #123
    Quirt
    Quirt Mad Scientist
    That is up to the vehicle more than our dyno. That said, it does not really matter what gear its in as we are interested in the difference between the two runs more than the actual power number.
    If a power number is all you are interested in then let me know how much you want to see and I will make it happen. Cheating the dyno output is as easy as breathing ;)
  4. Feb 17, 2015 at 1:42 PM
    #124
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    correct. needs to be done at high rpm like around 3k so it wont downshift.
  5. Feb 17, 2015 at 1:43 PM
    #125
    Quirt
    Quirt Mad Scientist
    We installed an EB on a taco with a snorkel yesterday, I am sure he will keep you guys updated.
  6. Feb 17, 2015 at 1:47 PM
    #126
    Quirt
    Quirt Mad Scientist
    Na... he is just a customer. I work for the company though:)
  7. Feb 17, 2015 at 1:48 PM
    #127
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Yup. I even have a stock intake should the afe be an issue.
  8. Feb 17, 2015 at 2:25 PM
    #128
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Phil is a tough cookie. :cookiemonster:
  9. Feb 17, 2015 at 2:55 PM
    #129
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Its my mom's 4runner, shell never notice. Let her run it for 2 weeks and when I get back into town Ill check her mileage.
    Testing one on TacoDelPlayas truck as well. Really want to put these thru the ringer.
  10. Feb 17, 2015 at 5:07 PM
    #130
    Daltong
    Daltong Well-Known Member
    Dalton
    Tempe, AZ
    19' Cement DCSB TRD Off-Road 4x4
    Did we ever get clarification on this working with an AFE stage 2 intake? I also noticed that the products were for up to 2012 Taco's. I have a 14 so would this not be an option for me?
  11. Feb 17, 2015 at 5:22 PM
    #131
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    If you can contact aFe and get the diameter of the tube at the MAF, that would be ideal.
  12. Feb 17, 2015 at 7:16 PM
    #132
    Daltong
    Dalton
    Tempe, AZ
    good idea, i suppose i could also just measure it yeah?
  13. Feb 18, 2015 at 4:52 AM
    #133
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It has to be measured at the location of the MAF sensor.
  14. Feb 18, 2015 at 6:16 AM
    #134
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    He gave him a week. Thread has been opened 3 weeks ago and firts post by QUIRT 2 weeks ago! :eek:
    I would be happy to see a dyno run but for the moment, i don't have any problem with QUIRT's tactics. He's present on the site and most of the time his comments are on the conservative side. We'll see what happens with the members that installed it and the dyno run when avalaible.
  15. Feb 18, 2015 at 6:57 AM
    #135
    Lucario Runner
    Robert
    06 Toyota 4Runner
    reminds me of the intake manifold spacer thread....
  16. Feb 18, 2015 at 7:21 AM
    #136
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
    So does this work or what?
    I am considering purchasing this product if there are positive results from reputable peeps.
  17. Feb 18, 2015 at 8:36 AM
    #137
    Quirt
    Quirt Mad Scientist
    Thanks! This is not my first rodeo ;) My pops started raceing cars when I was 7 years old.
  18. Feb 18, 2015 at 8:41 AM
    #138
    Quirt
    Quirt Mad Scientist
    Yes it does work... I am not sure if the patent office would give a provisional on snake oil ;)
    We designed and ran our Eco Block on these factory backed Scion tC's for a full season and finished 2nd and 3rd in the series. Both cars were driven by girls who were racing against guys...
  19. Feb 18, 2015 at 9:05 AM
    #139
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    To bad Crawford Performance doesn't make a turbo kit for Tacoma's. :( That would be legit!
    Or build 1GR's...... Then we could do a Tacoma Gymkhana :cool:
  20. Feb 18, 2015 at 9:24 AM
    #140
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    intake manifold spacer was definitely not junk. i have it and noticed a huge difference.
