EcoFlow 800W Alternator - Who Has Used It?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by m805, Jul 19, 2024.
  1. Mar 9, 2025 at 10:18 AM
    #81
    Daulll
    Daulll Well-Known Member
    Saul
    SoCal
    2022 Tacoma OR
    where did you mount the charger?
  2. Mar 10, 2025 at 3:58 AM
    #82
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I removed my passenger rear seat several years back and made a clean plywood platform for my fridge to strap down to and ride there.
    I mounted the charger unit underneath the platform all tucked up nice and tight.
    The only part of my entire 800 watt charging system that can be seen easily, are the connections to the truck battery terminals and the end of the cable to the Delta 2.
    Daulll[QUOTED] likes this.
  3. Mar 10, 2025 at 10:52 AM
    #83
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Does the wire reach from the engine bay to the bed of the truck?
    el_turks likes this.
  4. Mar 10, 2025 at 11:45 AM
    #84
    el_turks
    el_turks Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    Depending on how you route it, Yes. I ran it from the bed under the belly and to the battery with no issues.
  5. Mar 10, 2025 at 10:09 PM
    #85
    6MTPro
    HI -> CA
    Plan would be to run it from the engine bay under the cab and then up between the cab/bed
  6. Mar 13, 2025 at 2:22 PM
    #86
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    You'll be fine with that.
    6MTPro[QUOTED] likes this.
  7. Mar 15, 2025 at 7:38 PM
    #87
    6MTPro
    HI -> CA
    Appreciate the feedback
    INSAYN[QUOTED] likes this.
  8. Mar 18, 2025 at 8:57 PM
    #88
    Daulll
    Saul
    SoCal
    2022 Tacoma OR
    Finally got my alternator charger doing install soon. How did you guys terminate on the battery? My negative battery terminal doesn’t have a spot to add accessories on my 3rd gen. Should I attach to ground wire connected to the chassis? Can I just slide it into bolt that holds clamp on terminal down? Advanced thanks for the responses and feedback!
  9. Mar 21, 2025 at 7:35 PM
    #89
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    I missed out on that issue, as I already swapped out my factory crap battery for a larger Full Throttle AGM battery. This battery has both the normal battery posts and studs like a Deep Cycle battery would have. I just used the studs.
    In your case, you could swap out the factory battery post clamps with aftermarket ones that have several accessory bolts on them.
