Ecoflow River Pro power station $429
Discussion in 'Deals & Coupons' started by mikeaesq, Jun 6, 2021.
  1. Jun 6, 2021 at 9:11 AM
    mikeaesq
    mikeaesq [OP] Well-Known Member
    TRD Off-road 4x4
  2. Jun 6, 2021 at 5:19 PM
    CemenTRDgen
    CemenTRDgen Stay Flexible!
    Joshua
    Concord, CA
    2019 DCLB TRDOR Cement
    Bilstein 6112/5160, Icon RXT, BAMF Sliders, Skids, & Hybrid Front Bumper, Warfab Phantom Rear Bumper, & Hitch Skid
  3. Jun 7, 2021 at 11:03 AM
    stonylaroux
    stonylaroux Well-Known Member
    Seattle, WA
    2015 Toyota Tacoma TRD Offroad
    That's the exact scenario I found myself in. Why the hell does Massimo offer a battery that isn't fully compatible with their fridge? This Ecoflow deal blows the Massimo unit out of the water. Same price but much more Wh.
    mikeaesq[OP] likes this.
  4. Jun 8, 2021 at 3:32 PM
    talltree
    talltree Active Member
    Seattle
    04 Sequoia
    Supposedly available until 6/20, but with a "until supplies last" caveat. We're getting so close to my "pull-the-trigger" point on these but I think I decided to hold off. I'm somewhat convinced (ok, hopeful) that by next summer we should see these with LiPo chemistry for the same price or less. Are you listening Ecoflow/Costco?
  5. Jun 8, 2021 at 4:51 PM
    CemenTRDgen
    Joshua
    Concord, CA
    FYI The kickstarter for this power station was 768Wh with LiFePO4 Cells rated for 3,500+ cycles to 80% but when they went to retail it switched to lithium ion.
    Ecoflow states 80% capacity at 800 discharge cycles. That is complete discharges. For my use case I am using it for 5-6 days per month and most likely not discharging it to below 50% state of charge, and not using the fast charge function very often if ever.
    Powering my fridge on HI in HOT weather; 50W at 25% duty cycle, so call that 300Wh per day.
    If I work remotely it is only for one day of a trip so that is 9 hrs at 50W or 450Wh.
    It will almost always be simultaneously be charging via 100W of solar at and actual rate of 75-80W so during the day it will most likely never get below 70% and be back up to 100% by dusk.
    Running the fridge overnight will use another 120Wh so it will be at or above 80% in the morning.
    At these discharge rates it is one full discharge cycle with the fridge all day and the laptop 9 hrs, and 40% for just the fridge for 24 hrs.
    Taking a 3 day trip with one day of laptop use is two discharge cycles with some cell phone and lantern charging thrown in.
    That is 4 cycles for two trips per month.
    48 cycles per year
    800 cycles = 16 years to 80% capacity.
    I will not worry about lost capacity for at least 10 years, and I can always add the additional battery.
    talltree[QUOTED] likes this.
  6. Jun 8, 2021 at 5:03 PM
    talltree
    Seattle
    04 Sequoia
    <snip>
    I fully agree. If you need one (or even just really really want one) now, this is a smoking deal. I merely want one and can wait until next year fairly easily (I bought a knockoff yeti cooler over the winter and it's meeting my weekend needs just fine; next spring summer will be longer trips where I don't wanna deal with soggy food). And hopefully by then the LiFePO4 will be standard, because even if I don't need it, it's a bonus ;-)
  7. Jun 8, 2021 at 6:16 PM
    CemenTRDgen
    Joshua
    Concord, CA
    Last summer over some long weekends Fri-Mon (3 nights) in high 90s weather. I went through 80-100lbs of ice. I was using 1 Coleman 100 qt xtreme 5 day cooler, and and 1 Igloo 70 qt Max Cold cooler. Kept them in the shade. Some food packed vacuum sealed and frozen. One for food only opend 3 times a day, one for drinks (beer, wine, water) in and out all day. In April Costco had the Massimo CX50 on sale for $269 and in May the Massimo 500W power bank for $339, returned it for reasons stated above.
  8. Jun 8, 2021 at 6:25 PM
    talltree
    Seattle
    04 Sequoia
    If I didn't know better, I'd think you guys were trying to talk me into a cooler and power bank.
  9. Jun 9, 2021 at 10:40 AM
    CemenTRDgen
    Joshua
    Concord, CA
    :spending: But in all seriousness buy what you need for your use case, or buy whatever you want if you can afford it. :anonymous:
  10. Jun 11, 2021 at 1:27 PM
    talltree
    Seattle
    04 Sequoia
    For what it's worth, I *just* decided to pull the trigger and now it's gone :-(
  11. Jun 11, 2021 at 2:01 PM
    CemenTRDgen
    Joshua
    Concord, CA
    :censored: Still have it with the extra battery on sale!:bananadead:
    :spending:
