Economics of DIY oil change
Discussion in 'Technical Chat' started by Sido, Feb 12, 2012.
  1. Feb 12, 2012 at 5:20 PM
    Sido
    Sido [OP] Well-Known Member
    Anchorage
    None
    I like to work on my truck, but I wanted to see what you thought of doing your own oil change. In my experience, these are the advantages to going an oil change shop- quick, convenient, no mess, and disposal of the oil. There are some disadvantages, such as the shop putting in too much oil (6qt vs 5.3qt), and wondering if the guy with tats up his arm and neck monkeying around under my truck really knows what is doing.
    I was looking at prices for different kinds of oil, and unless there is a special sale, it really isn't cheaper to do it yourself.
    How do you justify doing your own oil change?
  2. Feb 12, 2012 at 5:23 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    For me is quality of work.
  3. Feb 12, 2012 at 5:24 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    knowing it is done right for me, correct oil, correct amount, new filter, etc... And normally a few $$ :D
  4. Feb 12, 2012 at 5:26 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Quality control is number one. Second, I like to take that time to look around underneath and check things over. Makes me feel good.
  5. Feb 12, 2012 at 5:28 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm not sure what prices you were looking at...but it is certainly cheaper to DIY with the fluids and filters I use. Plus I know it's done right and I get a reason to look under the truck.
  6. Feb 12, 2012 at 5:30 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Letting it drain overnight.
  7. Feb 12, 2012 at 5:32 PM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    You can get a 5qt jug of full synthetic for $25-$30 and if you watch the Advance Auto sales online you can get PureOne oil filters for about $5 each. There are also specials at the various auto parts stores for 5qts Synthetic + Premium filter for $30-$35 pretty much every month. I am partial to Pureone and Bosch Distance Plus, but the Mobil 1 shows up pretty often paired with Mobil 1 oil.
    Being under your vehicle lets you bond a little and check for weird stuff going on. I also go with a 7500 mile oil change interval because I know exactly what is going into the machine and what it looks like coming out. You never know with Iffy Lube.
    The bottom line is that there are very few times where the person changing the oil will be more qualified than I am, and they will never care more than I do.
  8. Feb 12, 2012 at 5:47 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I buy a 5 qt jug from wally world syn 5w 30 - 27$
    A 1 qt jug from wally world - 6.50$
    A filter from napa 6$
    27+6.5+6 = 39.5 w/ tax = 42.27
    On the next oil change I only need the 5qt jug and a filter
    27 + 6 w/tax = 35.31
    42.27
    +35.31
    =77.58/2
    =38.79
    So we can say about 40$ per oil change. I get the correct amount, I used quality oil, quality filter, and I don't make a mess, if I do it gets cleaned. I know its done right, I don't over tighten plugs or filters and I don't leave anything loose. Sure it takes some of my time but it's worth it. I also don't have to drive anywhere and wait in any damn room.
    Rags and funnels and oil disposal is next to nothing and I already do that shit anyway. Plus I get under my truck and give it a thorough look over with a flash light and check everything else in the engine bay over as well.
  9. Feb 12, 2012 at 5:57 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Local shop will do mine for $30 but they use cheap NAPA oil, cheap NAPA filter, and have a history of doing shitty work such as blowing to motor on one of my friends Honda because they forgot to check and see if the gasket on the old filter had come off with the filter, it didn't and spewed oil all over the roads until it ran out and the motor burned up. For me I do it because I have the time to do it and know that it's being done right even at the expense of spending an extra $20.
  10. Feb 12, 2012 at 6:00 PM
    H Bomb
    H Bomb Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    Even If a DIY oil change costed more than at a shop, I'd still do it myself. I like knowing its done right. And, I don't like others touching my trucks...
  11. Feb 12, 2012 at 6:08 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The Toyota stealerships near me were running $9.99 oil changes and I let them do all the oil changes until it was out of warranty (I still marked the old filters to make sure they were replaced). Now, the truck will never see the inside of a shop unless it's something I don't know how to fix or can't fix. I'll echo the others on here when I say I do my own maintanence because I know it was done correctly. Also, when I'm working on the truck, I pay attention to other things and am more apt to see something that needs attention like a heat shield loosening up, grease and check the play in the drive line joints and look for other potential issues under the truck. Most paid shops will just do an oil change and that's it.
  12. Feb 12, 2012 at 6:11 PM
    Frankoo1234
    Frankoo1234 Well-Known Member
    OC
    Double Cab 05 Taco PreRunner
    Running boards, Tint
    easy you learn how to work on your truck.. I never new how too and would go to the stealership to get service which cost about 79 bucks for all the silly inspections and oil change.. All you do is buy a pack of filters. Between 3 and 10 filters from the stealership and it comes out to be cheaper filter wise.. (check out the thread on filter quality..OEM is one of the better ones compared to shitty fram)... You choose the quality oil you want in everything going in including the labor..
    compare a very careful, attention to detail, highest quality and care service place price to a DIY job at home(assuming you do the same as everyone has mentioned above..quality of products and attention to detail). If you compare the two you will see that DIY is much cheaper..AND FUNNER!! ha
    dont compare DIY job with iffy lube
  13. Feb 12, 2012 at 6:21 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Little more pricy around here to change yourself but I enjoy doing it and know quality parts are going in.
  14. Feb 12, 2012 at 6:23 PM
    emt49126
    emt49126 Active Member
    Rodney
    Kentucky
    Tacoma
    How/what did you use to mark your old filter with?
  15. Feb 12, 2012 at 6:25 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    I agree with SVHANC. Advance Auto usually has good prices for oil and filter combo's.......plus you know it's done right and don't have to go behind someone to make sure
  16. Feb 12, 2012 at 8:45 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Use a screw driver (etc.) and scratch the date into the top of side of it.
  17. Feb 12, 2012 at 8:56 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    I was a mechanic for 10 years.
    I never do my own oil changes. Its far easier for me to take it to the dealership then to deal with getting rid of the oil, lying on my back etc.
    I have an advantage though, because i have relationships with all the service writers, manager and techs there so I request the techs that i trust. Plus i stand out there and shoot the shit with them while they do it.
    Its free for my first 4 anyways, then i will only have to pay 19.99!
  18. Feb 12, 2012 at 8:59 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I have to recoup my costs for fucking up my first one...
  19. Feb 12, 2012 at 9:00 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I don't see how it can't be cheaper.
    In my area a regular oil change, non synthetic, goes for 30-35 dollars. I can do a full synthetic oil change for the same price.
    6qt's of Mobil 1 from Costco - $26.99
    Filter from dealer - $4.50
    Replacement plug gasket - $0.50
    Total = 32.00
    So way better product, synthetic vs. regular and I do the work.
  20. Feb 12, 2012 at 9:02 PM
    Fightnfire
    Marysville, WA
    Me too, I'll join you in the transmission flush first time. But I fixed it myself, so 3qt's of WS and a pump for a few bucks. Oh, and a few dollars for the 24mm socket ... I didn't have one.
    :D
