ECT and Overdrive
Discussion in '1st Gen. Tacomas (1995-2004)' started by seanmichaels, Jan 20, 2011.
  1. Jan 20, 2011 at 6:27 AM
    seanmichaels
    seanmichaels [OP] Member
    Florida
    03 Tacoma TRD V6
    Why use ECT in 03 Tacoma TRD? I noticed the ride and breaking much smoother with ECT on but is it bad on my engine?
    If I use ECT can I still turn off my overdrive when in the big city?
  2. Jan 20, 2011 at 11:46 AM
    v1ndictiv3
    v1ndictiv3 Well-Known Member
    Bay Area, California
    '98 PreRunner Xtra Cab 2.7L
    Mostly stock: AFE Pro Dry S Filter, Bedrug, Leer Shell, 265/75/15 Goodyear Wrangler RT, Husky Liners, Wet Okole seat covers... Powertrax No-Slip in the near future =)
    ECT changes the shift points for your tranny so it revs a bit more before shifting.
    Some people keep it on all the time, I have mine off because the shift points are fine for me. If I'm going up a large hill, I turn ECT on and Overdrive off. I keep overdrive on all the time unless I'm ascending a large hill. Your manual should give you a bit of insight on ECT. As for the engine, it shouldn't cause any harm as long as you're not keeping it redlined.
  3. Jan 20, 2011 at 12:07 PM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    In my opinion keep the ECT off for daily driving. Having the ECT on is a waste of gas and actually give you less torque. the 3.4 makes most of its torque between 1800-2500 rpms and having the ECT on puts you over that even in daily driving. So techniqually ur wasting more gas for less get up and go.
  4. Jan 20, 2011 at 1:57 PM
    seanmichaels
    Florida
    03 Tacoma TRD V6
    Thanks, so it sounds to me that ECT on and overdrive off are both for power. The manual breifly mentioned ECT which surprised me.
  5. Jan 20, 2011 at 2:09 PM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    I'm just guessing because I'm no expert but if you talking about changing shift points it sounds to my like this might be a feature with Towing in mind. a lot of times when your towing simething the transmission tends to hunt for the right gear a bit more which causes un needed wear on the trans. Changing the shift points maybe an atempt to reduce some of the hunting that you get. I don't own your model Tacoma so I'm not really sure but from the posts above thats what this sounds like.
  6. Jan 20, 2011 at 6:07 PM
    v1ndictiv3
    Yea, towing or when the engine's straining to get up a hill (as my 4cyl sometimes does in SF's larger hills). Supposed to help the engine stay in a sweet spot and not keep shifting up and down. Some people drive with it on all the time though and say they get slightly better mpg. I guess it all depends on what your commute's like and how light your foot is on the pedal.
  7. Jan 20, 2011 at 7:20 PM
    MTgirl
    Weesa
    Bob's secret mod lair
  8. Jan 20, 2011 at 8:44 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    x2!
