ECT and S4 when towing using 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Griff1234, Jul 10, 2019.
  1. Jul 10, 2019 at 10:53 PM
    Griff1234
    Griff1234 [OP] New Member
    2019 Toyota Tacoma
    i just towed a 3,000lb travel trailer 1,000 miles. I used S4 and didn’t even know about the ECT Button.
    When towing, am I supposed to use the ECT button AND also use S4 gear?
    (The salesman saw my Rpod that I bought the truck to pull and never mentioned either the ECT or gears for towing—not his job I guess)
  2. Jul 10, 2019 at 11:03 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    ECT is recommended
    Freeheelbillie and SLeeper512 like this.
  3. Jul 10, 2019 at 11:09 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    Ect is basically tow haul mode in other trucks. It will help out especially if you have grades or a headwind
    GruntOutdoors likes this.
  4. Jul 10, 2019 at 11:11 PM
    PRE-K
    PRE-K Active Member
    '19 DCSB OR
    Without ECT, you'll want to drive the truck off a cliff (with or without you inside).
    S4 sounds about right, considering that, completely unloaded, anything ~77mph and under, I get BETTER mileage in 5th than I do in 6th... that little motor just struggles with a way-too-tall 6th gear.
  5. Jul 11, 2019 at 6:38 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    It's in the manual. Read it. ECT is recommended for towing.
    G.
  6. Aug 14, 2022 at 6:59 AM
    NOCOTaco1982
    NOCOTaco1982 Active Member
    Wayne
    2019 Tacoma TRD Off Road Cement
    Premium and tech package, Predator Pro running boards
    What is S4? Sorry for not knowing!
  7. Aug 14, 2022 at 8:14 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    moving the gear selector (auto trans) over, it defaults to limit the transmission from shifting above 4th gear (keeping trans out of over drive gears). Of course you can shift it up and down, forcing downshifts or changing the top gear limit to most any other gear.
    in other words, it's the shifter in the auto:D
  8. Aug 14, 2022 at 12:24 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    There is no requirement to use either S-4 or ECT when towing, but if it makes your drive more enjoyable, go for it. I tended to use ECT and D when towing my boat. S mode is for engine braking when descending long steep slopes and we don’t enough a large amount of those where I live.
  9. Aug 14, 2022 at 1:53 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    the owner's manual says to select ECT mode when towing and to use S-5(i think) or lower.
  10. Aug 14, 2022 at 1:54 PM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    S-mode keeps trans temperature low and ECT is recommended when towing.
  11. Aug 14, 2022 at 2:03 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    S4 means the transmission won't shift above 4th gear. The higher engine RPM is easier on the engine and does help keep everything running cooler. It has ALWAYS been recommended to stay out of overdrive when towing. Different vehicles have different ways of accomplishing that.
    That is the most important part. Using ECT will change transmission shift points. It will stay in low gears longer when accelerating. And on most vehicles will downshift more aggressively to help with engine braking.
    When towing light loads you can probably get by with just driving normally. Especially on level ground. But with 3000 or more I'd stay out of over drive. If you didn't use ETC, you didn't hurt anything. It may have been a little better driving experience with it though. But just putting the shift selector in "D" and pulling 3000 lbs is going to overheat the transmission and lead to premature failure.
    vuTron likes this.
  12. Aug 14, 2022 at 2:06 PM
    The_vue's
    The_vue's Well-Known Member
    18 cement
    Ect for city towing. Otherwise highway makes no difference
  13. Aug 14, 2022 at 2:53 PM
    gudujarlson
    Minnesota
    That is incorrect.
  14. Aug 14, 2022 at 3:01 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Ever heard of overdrive gears?
  15. Aug 14, 2022 at 3:26 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    SLeeper512 and Simpleton like this.
  16. Aug 14, 2022 at 4:47 PM
    Old goat1914
    S-4 is correct
    TacoTime55 likes this.
  17. Aug 14, 2022 at 5:57 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    S5.
    @gudujarlson has his own crusade about the semantics of the language used in the manual, but reading the manual as it is implied says S5 and ECT, not S4.
  18. Aug 15, 2022 at 5:16 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I used S4 recently most of the time towing a boat with some other gear around the op's weight. Tried ECT on and off. Imo, seemed sort of a crap shoot at that weight.
  19. Aug 15, 2022 at 5:46 AM
    Old goat1914
    Does S-4 keep the torque converter locked and does that generally keep the transmission fluid from overheating?
  20. Aug 15, 2022 at 8:36 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    s-4 will definitely keep the temps lower than running in overdrive. i know 4th can be locked but not sure if it's locked at all times.
    SLeeper512 likes this.
