ECT Auto Turn ON Module
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Oct 11, 2017.
  1. Sep 21, 2018 at 6:20 PM
    #1201
    remgu2000
    remgu2000 Keepin' on keepin' on.
    Ray
    Roswell, GA
    Used to have a 2017 Barcelona Red TRD Off-Road DCSB 4x4
    So instead of splicing you cut the original cable and crimp it with the DIY cable into the plug? Sorry for being dense. I'm 12 hr jet-lagged maybe I need to look at this in the morning.
  2. Sep 21, 2018 at 6:26 PM
    #1202
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    LOL, definitely re-look. It is a female and male connector. It allows you to “build your own” connections between the factory harness and the button.
    remgu2000[QUOTED] likes this.
  3. Sep 21, 2018 at 6:27 PM
    #1203
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    no..the unit you make you attach the connectors he is offering to each end of what you made. then those connector ends you attached will simple plug into, one end to the ECT switch the other connector to the connector that you pulled off the back on the ECT switch. hope i explained it ok. i ran the power to the cig lighter with a crimp connector, i mean you are right there why fool around runing wire down to the fuse box.
  4. Sep 21, 2018 at 6:37 PM
    #1204
    remgu2000
    Ray
    Roswell, GA
    Ahh. Got it. Piggy backing the conections with the DIY piece in between. Thanks guys. I've been striving to stay awake since noon! LOL.
  5. Sep 21, 2018 at 6:50 PM
    #1205
    kahanabob
    Maui
    16 TRD 2WD 4DR
    so you will be using only 2 wires out of the 4 wires that connect to the ECT button yet the 4 wires need to pass thru so now i am confused now that you got me thinking about it! think a wiring diagram is in order here. also need to make sure the correct wires are in the correct pin positions.
  6. Sep 21, 2018 at 6:54 PM
    #1206
    remgu2000
    Ray
    Roswell, GA
    I had the original DIY diagram figured out and now you all throw a wrench in it by adding this adapter. :) Yeah a diagram would be great.
  7. Sep 21, 2018 at 11:35 PM
    #1207
    jbaroune
    jbaroune Member
    2018 TRD OFF ROAD
    I just installed it using the 1st DIY method. $17 & 15 minutes later the mod works great. Thanks
    remgu2000 likes this.
  8. Sep 22, 2018 at 1:25 PM
    #1208
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i would assume the 2 wires that are not tapped into you just pass thru and the other 2 are connected as shown on DIY diagram. issue is making sure the wires are in the correct pin position on the pins you are adding. .
  9. Oct 4, 2018 at 4:35 AM
    #1209
    arexseven
    arexseven Well-Known Member
    Derek
    2018 Cement TRD Off Road
    RCI Skid Plate Bilstein 5100’s Spydertrax Spacers PIAA LED Headlights Cali Raised LED Fogs TRD Pro Tail Lights TRD Pro Grille Debadged with Black Tailgate Inserts
    Subscribed for updates
  10. Oct 6, 2018 at 2:59 PM
    #1210
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    @mesojdm
    Know you're busy bud, but, any updates on these?
    b00gieMonster likes this.
  11. Oct 6, 2018 at 3:29 PM
    #1211
    VersaTrax
    VersaTrax Well-Known Member Vendor
    Nicholas
    2019 Toyota Tacoma
    I have the same question.
  12. Oct 7, 2018 at 7:04 AM
    #1212
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    @mesojdm have you ever had these just fail in the past? I had mine installed for about 6 months and one day it just stopped working all together. I checked the power connection and the fuse that you included and it was fine and getting power. Do you have any ideas?
  13. Oct 7, 2018 at 9:33 AM
    #1213
    jdr43
    jdr43 Well-Known Member
    Jim
    Hamelton Montana
    2016 Tacoma SR5
    Mine did the same thing. Returned it for a full refund. Built my own using meso plans and it's working great
  14. Oct 10, 2018 at 11:58 AM
    #1214
    Ninokioshi
    Ninokioshi Member
    Nino
    17’ DCLB
    Can I still get my hands on of these?
  15. Oct 10, 2018 at 9:40 PM
    #1215
    irANTHONY
    irANTHONY Well-Known Member
    sub'd just in case these come back!
  16. Oct 11, 2018 at 6:56 AM
    #1216
    Opa5
    Opa5 Member
    Denis
    Mass
    2017 Tacoma 4x4 DC TRD OR
    Hondo garage radio knobs with ar15 bolt engraved. In channel vent shades.vinyl tg inset letters,glove box,engine cover & door sill protector vinyl insets also.Just getting started!!!
    I hope meso Puts these out again I am consrantle watching as in the past whenever they are available they are gone right away & I missed it. I am watching this thread more than all others combined!!!
  17. Oct 12, 2018 at 6:31 PM
    #1217
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    @mesojdm when are these coming back?!
    b00gieMonster and Chasespeed like this.
  18. Oct 13, 2018 at 12:59 AM
    #1218
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '19 SSM Limited, '09 DCSB MGM OR
    Patiently waiting
    Chasespeed likes this.
  19. Oct 13, 2018 at 8:13 PM
    #1219
    Xabiss
    Xabiss Member
    Wanting one also!
  20. Oct 14, 2018 at 8:08 PM
    #1220
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
