ECT Auto Turn ON Module
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Oct 11, 2017.
  1. Feb 10, 2019 at 8:53 AM
    #1581
    steve1503
    steve1503 Well-Known Member
    New Hampshire
    2020 SR5
    I have been having problems with my ETC on all the time, I noticed yesterday it worked fine five times, then I went out and ECT did not come on until I held the button in for about 5 seconds. The first time this happened, I questioned myself if I pressed the button off, but now it has happened again.
  2. Feb 10, 2019 at 4:11 PM
    #1582
    DSIM
    DSIM Well-Known Member
    Daniel
    Raleigh, NC
    2017 MGM Tacoma TRD Off-Road
    Question. Do you go to acc mode for a couple seconds before starting? Sometimes can get out of sync if you don't go straight to run.
    If that's not the case, I'll continue to pm you and get you a replacement.
  3. Feb 10, 2019 at 4:15 PM
    #1583
    steve1503
    New Hampshire
    2020 SR5
    I go right to start, no pause.
  4. Feb 10, 2019 at 4:18 PM
    #1584
    DSIM
    Daniel
    Raleigh, NC
    Alright well get it replaced and work out details with you via pm.
    steve1503[QUOTED] likes this.
  5. Feb 10, 2019 at 4:50 PM
    #1585
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Well you cant set the cruise control in gears 1-3 so if you are going ~25-30 and in 4th gear it may be shifting sooner so that it can get up to speed quickly and then shift back to 4th.
  6. Feb 13, 2019 at 1:06 PM
    #1586
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    today for the first time in 2 years it did not come on and did not come on after starting 3 times. i held the button down for 5+ seconds and now it comes on at start up. will see if it holds.
  7. Feb 13, 2019 at 1:12 PM
    #1587
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i had the same issue, see post 1614. then i saw this, about 2 days ago i was just using ACC to add pic to my screen off on the head unit. i bet in my case this might have been the cause and just now noticed it. i never use ACC
  8. Feb 15, 2019 at 7:26 AM
    #1588
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    Very recently I noticed the mod "off" the other day, and it was probably that day I sat in my truck and listened to the radio in ACC mode then started my truck straight from there. Other than that time, it's been the best mod since my remote starter!
  9. Feb 15, 2019 at 7:37 AM
    #1589
    HardShellTacoma
    HardShellTacoma Well-Known Member
    Eric
    Colorado
    2017 DCSB OR
  10. Feb 15, 2019 at 7:44 AM
    #1590
    slowpoke16taco
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
  11. Feb 15, 2019 at 4:22 PM
    #1591
    Danno 1948
    Danno 1948 Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    when you install the ect module are you suppose to push the ect button one time for it to activate it or not, I installed mine and I don't really notice any differants
  12. Feb 15, 2019 at 4:25 PM
    #1592
    th3118
    th3118 Well-Known Member
    Mesa, AZ
    2016 Quicksand TRD Offroad
    Look for the ECT light on dash, that will tell you if's it's on.
  13. Feb 15, 2019 at 4:45 PM
    #1593
    HardShellTacoma
    Eric
    Colorado
    2017 DCSB OR
    Watch the video in the first post in this thread. Probably easier to see it than have it explained.
  14. Feb 16, 2019 at 10:33 AM
    #1594
    kahanabob
    Maui
    16 TRD 2WD 4DR
    when i installed mine i did not push the ECT button, just started the truck and ECT came on. if ECT does not come on at start up hold down the ECT button for 5+ seconds.
  15. Feb 16, 2019 at 1:32 PM
    #1595
    Danno 1948
    Dan
    Ocala,Fl.
    ok thanks,then it goes off and everything is good right
  16. Feb 16, 2019 at 1:56 PM
    #1596
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    There are two “modes” - always On (each time you start the truck, ECT will turn on a few seconds after and stay on), and always Off (each time you start the truck, ECT will not turn on and stay that way).
    You can of course momentarily touch the button to turn it on/off as you wish, but next time you start the vehicle - the mode will continue as previously selected.
    You can change the “mode” by holding the button down for over five seconds.
    Hope that helps...
  17. Feb 16, 2019 at 1:59 PM
    #1597
    kahanabob
    Maui
    16 TRD 2WD 4DR
    adding on, so if you start the truck and the ECT does not come on then you need to hold the ECT button for 5+ seconds. the next time you start the truck ECT should come on.
  18. Feb 18, 2019 at 12:50 PM
    #1598
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
    Didn't see it on the meso site, am I missing a post (probably)?
  19. Feb 18, 2019 at 3:26 PM
    #1599
    SK808
    SK808 Well-Known Member
    Ewa Beach, Hawaii
    2017 Tacoma TRD OR DCSB 4X4
    Magnuson Supercharger, Kings w/Resi front and rear, ICON UCA, Allpro STD leaf pack, C4 Fab Hybrid Front Bumper, RCI Rear Bumper, X20 winch, All Pro U-bolt Flip Kit w/ wheelers bump stop, Method 701, 17X8.5 w/0 offset, BFG KM3 285/70/17, All Pro Sliders, TRD CAI, Spec-U exhaust, Total Chaos bed stiffener, RCI Skid Plates (all skids), Wet Okole seat covers, Diamondback tonneau cover, Grillcraft MX Grille, Husky front floor mats, Weather Tech rear floor mats, bed mat, various Baja Design lights, mobtown tailgate reinforcement plate, and a bunch of other stuff.
    DSIM took over the version 1 ECT Mod from MESO. He posts on this thread when available for sale. It’s currently sold out, but I think he’s working on another batch, but not 100% sure?
    MESO is also working on a new version 2 ECT mod, but no release date yet.
  20. Feb 18, 2019 at 3:43 PM
    #1600
    stiles88
    stiles88 Well-Known Member
    Seattle (Bothell WA)
    2020 GLE 350, 2008 FJ
