ECT button question:
Discussion in '3rd Gen. Tacomas (2016-2023)' started by leonharu, Mar 26, 2022.
  1. Mar 26, 2022 at 7:50 AM
    leonharu
    leonharu [OP] Well-Known Member
    Russell
    On my 2022 Tacoma with the ECT on the truck does not seem to get in high gear.If I activate the cruise control it goes into the higher gear then I can take the cruise off and it seems to stay there.Is this normal operation or do I have a tranny problem?I do know the tranny sure loves to change gears a lot and kinda of annoying!
  2. Mar 26, 2022 at 7:57 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I think ECT is supposed to increase the shift points so you can access higher RPMs. I'm not sure if it changes cruise control at all
    18CHUÑO, TacoManOne and Tacospike like this.
  3. Mar 26, 2022 at 8:00 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Get KDMax tune and all your tranny issues will be forgotten!
    taco_jak, Jerry311SD, PapaRee and 3 others like this.
  4. Mar 26, 2022 at 8:01 AM
    Tacospike
    Two Trucks
    Sounds normal
    I never use cruise control though
  5. Mar 26, 2022 at 8:03 AM
    Exfordman
    Exfordman Well-Known Member
    Norman
    2021 Tacoma TRD OR 4X4 LB White
    None
    With the ECT on in my 2021 the ECU strategy keeps the rpm up much higher by staying in a lower gear. Its great for the local grades and when I tow. No more constant down shifting. Toyota strategy likes to keep your rpm low all the time for fuel mileage. I get 17.2 mpg driving like an old fart and that strategy lacks for me. Bottom line is its normal.
  6. Mar 26, 2022 at 8:06 AM
    BeatnikFink
    BeatnikFink Well-Known Member
    2021 TRD Off Road
    A tune can help me forget my ex? Damn I've got to look into that :wink:
  7. Mar 26, 2022 at 8:31 AM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Since one of its purposes is towing, it might lock out 6th. I use ECT a lot and have not noticed that. One thing I have noticed is it seems to change the torque converter lock/unlock strategy, I suspect to aide with compression braking.
    Most of the time, I drive around town in ECT and use the sport shift function. I like the way it works where I live because it’s hilly.
  8. Mar 26, 2022 at 10:46 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Ect also does something with the mapping of the ecu that affects engine power. I can tell you my 2020 v6 has a different engine tone when ect is pushed. Transmission shift points are changed to. When i had ect on the truck sucked fuel like a v8. Its pretty useless for me. Any towing i do is best without it.
    AxisCab likes this.
  9. Mar 26, 2022 at 10:59 AM
    eurowner
    eurowner Duke Sky
    Scoty
    E̶C̶T̶ O̶n̶ k̶e̶e̶p̶s̶ t̶h̶e̶ a̶u̶t̶o̶m̶a̶t̶i̶c̶ f̶r̶o̶m̶ u̶s̶i̶n̶g̶ 6̶t̶h̶. N̶o̶r̶m̶a̶l̶.
    davidstacoma likes this.
  10. Mar 26, 2022 at 11:06 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Mine still goes into 6th with ECT on, it just doesn’t shift up there until about 75-80 MPH (on a flat road). I’ve make sure by looking at my rpms at that speed with ECT on, then turning ECT off and shifting into S6 and I get the same rpms. Then I’ll shift into S5 and rpms will go up a bit.
  11. Mar 26, 2022 at 11:13 AM
    brandon78lusch
    Brandon
    I always drive with it on. That’s probably why my MPG went from 19 to 15 after I started using it lol
  12. Mar 26, 2022 at 11:49 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I didn’t notice any issue with my 2016 auto. ECT changes the shift points so that the engine runs at a slightly higher rpm thus having slightly more torque/power at a given speed.
    cryptolime and kahanabob like this.
  13. Mar 26, 2022 at 11:49 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i have the "ECT on at startup" mod and don't really see much difference in gas mileage.
    WoodsGhost likes this.
  14. Mar 26, 2022 at 2:05 PM
    zoo truck
    None
    While my truck doesn't have an S6, it will do the above in drive if ECT is on. I swear you can watch the gas gauge going down.
  15. Mar 26, 2022 at 3:05 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Incorrect. ECT does not prevent the transmission from shifting into 6th, it just changes the point at which the transmission shifts.
  16. Mar 26, 2022 at 3:25 PM
    brian2sun
    California
    I think I remember you (or maybe someone else) saying on here somewhere in the past that they didn’t have S6… How can that be when we all have the same transmission (AFAIK, there are no variants of this trans for the Tacoma)?
  17. Mar 26, 2022 at 5:49 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Learning every day! I obviously got bad info.
    mic_sierra[QUOTED] and ktbell444 like this.
  18. Mar 27, 2022 at 8:42 AM
    zoo truck
    None
    I'm telling you S6 just doesn't appear on the led screen like the rest of them...always been that way. You could keep bumping the gear shift up, but S5 is all you'll see on the display. The transmission otherwise works perfect..couldn't be more pleased with everything. Truck has enough torque in all the gears to satisfy me. You'll get S6 in the d mode.
  19. Mar 27, 2022 at 8:46 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I don't think this is correct. My 2017 and my 2020 both have S6 when in S mode, ECT on or not. The only variant of the 3rd gen that doesn't have 6th gear is the 2.7L MT. I don't see a reason for you to not have it...
    fathomblue likes this.
  20. Mar 27, 2022 at 10:33 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    It's not correct. Either his truck is malfunctioning or he's mistaken. Everyone else has a 6th gear in S mode. I even took a picture of my dash showing it once but he ignored that.:notsure:
    Here, let's try it again.
    davidstacoma and SnuggleTruck like this.
