ECT Button Use and MPG
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomalimited23, Dec 12, 2023.
  1. Dec 13, 2023 at 11:05 AM
    tacomalimited23
    tacomalimited23 [OP] Well-Known Member
    I believe you two posters are saying the same thing, but seems sort of outside of what I was asking. While the S mode stuff is good info, I was really just asking if ECT in the on position will allow the truck to get to 6th. Part of why I ask, is it seems that on the freeway even on flat ground when turning on ECT while in cruise, it kicks up the RPM's. This leads me to believe that it is shifting down, perhaps to 5th. So, the question then is, when if ever would it get back the 6th in that scenario while staying in cruise.
  2. Dec 13, 2023 at 1:10 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Yes, we are saying the same thing.
    czukie[QUOTED] likes this.
  3. Dec 13, 2023 at 1:33 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Sooo, you're looking to get into 6th gear...automatically at cruising speed, I presume.
    I couldn't tell you how all that works in the ECU*...but I have a suggestion...
    Force the issue by going into 6th gear using S-Drive.
    One member here tested that out and lo and behold, it will manually shift into S6.
    Paging @Rock Lobster
    Buahahahahahaha!
    *ECU controls the engine; TCU/TCM/GCU controls the transmission.
    Rock Lobster likes this.
  4. Dec 13, 2023 at 1:51 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Yes it will go into 6th even in D. However, on the stock tune its a rare day to bang it into 6th with ECT on, and if you do achieve it, its not going to last for very long. The whole point of that button is to keep the rpms in a more torque-y range whenever you are demanding power, and by the time you achieve 6th in normal mode you are already pushing a giant brick against an EF-1 tornado equivalent wind resistance... ergo, demanding a bit of power.
    Its all moot anyway. My advice is to put the blindfold on to whatever the truck is doing or what gear it wants to be in. Unless you are towing, put it in D, let the truck do its weird freaky-deaky thing, and enjoy the drive. If you are towing, then push the ECT button, pop it over to S4, let the truck do its weird freaky deaky thing, and enjoy the drive. Everything else is semantics and hand-wringing.
  5. Dec 13, 2023 at 1:54 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    LOLOLOLOL!!!!
    Freaky-Deaky!!!
    You're making me chuckle quite a bit there Rock!!!
    Here's what google says:
    Most, or perhaps all, late model automatic transmissions are computer controlled. Through sensors the computer knows what the accelerator position is, the car speed is, the engine speed is, the selector lever position is, and perhaps also other information. From that information it decides which gear to use.
  6. Dec 13, 2023 at 3:00 PM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    you really do need a sense of humor if you are going to drive an AT tacoma. :)
    kahanabob and TacoTime55[QUOTED] like this.
  7. Dec 13, 2023 at 3:10 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I like ECT on the highway but it feels really weird on slower streets around 30mph. Like it’s running a very high RPM.
    MGMDesertTaco likes this.
  8. Dec 13, 2023 at 6:05 PM
    MGMDesertTaco
    My truck desperately needs a tune. ECT helps a little for freeway merging and freeway driving, but the transmission is a confused dog. :annoyed:
    Chew likes this.
  9. Dec 14, 2023 at 8:08 AM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    :evil:
    TacoTime55 likes this.
