Ect button
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hambone155, Oct 12, 2008.
  1. Oct 12, 2008 at 8:13 PM
    Hambone155
    Hambone155 [OP] Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    what does it do?
    i got a 95.5
    3.4 v6 supercharged
  2. Oct 12, 2008 at 8:14 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    ECT iirc is Electronic Controlled Transmission
    it basically changes your shift points to make towing a bit easier
  3. Oct 12, 2008 at 8:30 PM
    Hambone155
    omaha
    sweet thanks
  4. Oct 13, 2008 at 4:19 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    basicaly anyothing to break if over used...
    if you need it allot, change your tanny fluid more often
  5. Oct 13, 2008 at 8:42 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    should the ECT be used when towing something over a long distance?
  6. Oct 13, 2008 at 8:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it can be used for that. i used it this weekend when towing a trailer of furniture and things for a 2 hour trip.....i used the ect button, and my mileage was actually pretty decent towing and using it. the more you do it though,.........the more you probably need to change transmission fluid!
  7. Oct 13, 2008 at 9:12 PM
    bajaracer
    Charly
    Chandler
    Did you use the ECT AND turn off the OD??
  8. Oct 13, 2008 at 9:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.,........turned off overdrive and used the ect......good mileage from doing it that way.
