ECT Mod -- ON ALL the time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Oct 18, 2016.
  1. Oct 18, 2016 at 2:04 PM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I like driving with ECT mode ON:)
    Problem is, by default is is set to OFF.:(
    I can definitely feel the difference when it is activated; smoother driving, smoother shifting, higher powerband.:D
    So I came up with the simple mod below. This will Activate ECT mode whenever the truck is started. You can still manually turn it off by pushing the button.
    Here is what I used:
    •12V relay
    •Pac TR7 module
    •16awg wire
    •3m T-tap connectors
    I also sell the OEM connectors if you want to make a clean plug and play "T" harness!
    https://mesocustoms.com/collections/diy-parts/products/toyota-ect-connectors
    How To:
    1)Wire up Relay;
    Pin 86: Gorund
    Pin 85: -->blue wire of Tr7
    Pin 30:--> Pink wire on ECT button (pin 4)
    Pin 87:--->White/black wire on ECT button(pin 1)
    Wire up TR7:
    Easiest way I have found to gain access to the Cig lighter power, and ECT button is this way:
    Reach in behind and unplug ECT/Cigareette to tap wires.
  2. Oct 18, 2016 at 2:09 PM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    LOVE IT. I just wish there was a completely plug and play option where a female to male harness was in between the button and the factory harness, so no wire tapping was necessary. If someone comes up with that, I'm all over it.
    IdeaMan and JoeCOVA like this.
  3. Oct 18, 2016 at 2:12 PM
    MESO
    State of Jefferson
    ^ trust me, I have been trying to source the OEM male/female connectors to make a plug n play solution. Until then, this is the next best thing:)
  4. Oct 18, 2016 at 2:16 PM
    hksjza70
    hksjza70 Well-Known Member
    Westminster, CO
    Nice work!
  5. Oct 18, 2016 at 2:26 PM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Well, until that time, this is a REALLY good option and you've laid it out very clearly for us. Thank you!
    Do you have links to the relay you purchased, or will you be selling the wired bundle?
  6. Oct 18, 2016 at 2:32 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I though ECT turned back off if the button was held for 30 seconds?
    AxisCab likes this.
  7. Oct 18, 2016 at 2:34 PM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    He tapped into the start signal instead of a constant 12v on so it's only powering the relay momentarily at start to bridge the connection from what I gather.
    Here's a potential source for connectors, in bulk...just have to know which connectors to get. https://www.alibaba.com/product-det...ness-connector-manufacturers_60157086926.html
  8. Oct 18, 2016 at 2:36 PM
    Aussiek2000
    2016 Offroad AC
    Thanks for clarifying. Looks like I have a mod to do
    AramsTRD likes this.
  9. Oct 18, 2016 at 2:37 PM
    2016MGMTACO
    2016MGMTACO Well-Known Member
    Nice. Thanks for sharing this!
  10. Oct 18, 2016 at 2:38 PM
    MESO
    State of Jefferson
    I had some laying around my shop, but this is very similar:
    https://www.amazon.com/12-VDC-SPDT-...d=1476826485&sr=8-32&keywords=12v+micro+relay
    It does. The way I have configured it, the START signal momentarily connects the relay pins(activating the ECT button) then turns back off after truck has started. Nothing stays on
  11. Oct 18, 2016 at 2:39 PM
    Aussiek2000
    2016 Offroad AC
    can you add which terminal on the relay each wire goes to? IE: 85,86,87,34
  12. Oct 18, 2016 at 2:42 PM
    MESO
    State of Jefferson
    Here ya go:thumbsup:
  13. Oct 18, 2016 at 2:46 PM
    Aussiek2000
    2016 Offroad AC
    Perfect, thank you
  14. Oct 18, 2016 at 3:15 PM
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    Nice job on figuring this out. :bowdown: and even though I'm not going to do this I can see from your pics that's there plenty of wiring available for me to cut off the male switch connector and about 3" of the wiring and solder on extensions to reach the center console for relocating the ECT switch to.
    I also may just leave the original ECT switch in the dash and buy another factory ECT switch to mount on the center console, then all I have to do is tap into each of the 4 wires under the dash.
    Has anyone removed the main center console, and if so please share how to go about it. :)
    James_Bond likes this.
  15. Oct 18, 2016 at 5:02 PM
    Taco16LB
    Taco16LB Well-Known Member
    Nice write up . Good job !
  16. Oct 18, 2016 at 5:11 PM
    Taco16LB
    I take it the relay did not have to have a delay or timed setting .
  17. Oct 18, 2016 at 5:13 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    RIP Fuel Economy
  18. Oct 18, 2016 at 5:14 PM
    MESO
    State of Jefferson
    Nope. Standard relay
    Believe it or not, my MPG stays about the same.(if I do my part and keep my foot out of it)
    SLeeper512 and SothernTaco like this.
  19. Oct 18, 2016 at 5:16 PM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Nice writeup. I've been considering doing this myself.
  20. Oct 18, 2016 at 5:16 PM
    0210
    Vancouver, BC
    I haven't noticed any decrease. If anything, I saw improved numbers a handful of times.
    However I do wonder why Toyota chose to turn this option off when the truck shuts down and not re-start it automatically (as w/ some other buttons), and whether there may be potential downsides to running ECT all the time.
