ECT Mod -- ON ALL the time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Oct 18, 2016.
  1. Oct 19, 2016 at 5:50 AM
    #41
    vmantrdorlb
    vmantrdorlb Well-Known Member
    Oklahoma
    2016 Toyota Tacoma TRD SPORT LB
    TRD Wheel + General AT2 265/70/17
    this is how it should be, normal mode with eco button. not the other way around!
    mpg should be the same just drive the same way you did before.
    let us know when you figure something out
    specter208 likes this.
  2. Oct 19, 2016 at 6:41 AM
    #42
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    I'll be doing a mod with a TD relay this weekend. I'll likely tap the cig lighter 12dc to power it aND run pin4 on the ECT button through the normally closed realtor pin2 of the ECT.
  3. Oct 19, 2016 at 6:44 AM
    #43
    scornwel
    Fort Worth
    None
    Or use a solid state relay.
    MOC221_[QUOTED] likes this.
  4. Oct 19, 2016 at 7:50 AM
    #44
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yep.
  5. Oct 20, 2016 at 6:23 AM
    #45
    scornwel
    Fort Worth
    None
    How did you pop off the start button bezel?
    Just pull on it?
  6. Oct 25, 2016 at 2:49 PM
    #46
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I GOT IT!
    This ECT mod has been bugging me:annoyed::angrygirl:
    Side note; ECT CANNOT be set to "default ON". (went through the techstream system thoroughly..we could not find that option at all)
    How'd ya do it?;
    PAC TR-7 timer module. (had one laying around the shop, so i figured i'd test it out)
    Timer wire connections:
    •red AND green wire --->+12v switched power(Purple back of cigarette lighter)
    •black--->ground (white/black strip on back of cigarette lighter)
    •Blue---->+12V timed trigger output (this will go to your relay and activate the ECT switch)
    That's it! The timer kicks on about 2 seconds after the truck starts.
    FYI: it is much easier to access the back of the cigarette lighter if you remove the radio bezel surround(pull hard, pops right off), then the entire A/C/hazard/start bezel pops off. Gaining full access.
    harbrown, remgu2000, ToyoDrew and 9 others like this.
  7. Oct 25, 2016 at 5:50 PM
    #47
    scornwel
    Fort Worth
    None
    Ah you beat me to it! Still don't have my parts from Amazon. So much for Prime. They refunded my money and said if they arrive to just keep them. Apparently it costs more to ship them back.
    When they get here I'll wire power to the cig lighter and run the signal through the NC at start up.
    Good work, but pretty pathetic we have go through this.
    remgu2000 and MESO[OP] like this.
  8. Oct 25, 2016 at 6:40 PM
    #48
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    is this the TR-7 you are talking about? https://www.amazon.com/PAC-TR-7-Universal-Trigger-Output/dp/B0002J22BO
    so the colored wires you are referring to are the ones on the TR-7? do not understand the blue wire..what relay?
  9. Oct 25, 2016 at 7:05 PM
    #49
    MESO
    State of Jefferson
    Correct, that is the one I used (there may be cheaper solutions out there, that is what I had handy). all colors i listed were off the TR7 module.
    Any 12V SPDT relay will work. Go over to your local car stereo shop, they have a ton.
    The timer starts once igniton power is applied(cig lighter). It then pulses +12v output(blue wire) to activate the relay. The relay is used to "close" the contact on the ECT switch momentarily(acting like you hit the button). Then the timer clicks back off.
    Cheers! :cheers:
    remgu2000 and plasticsnaks like this.
  10. Oct 25, 2016 at 9:09 PM
    #50
    Darth M.
    Darth M. Well-Known Member
    16 DCSB 4x4 Sport
    What I want is for Toyota to put the ECT button on the shifter or their steering wheel.
  11. Oct 25, 2016 at 9:54 PM
    #51
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    that's not the way mpg works
    Thunder Fist and 3dBdown like this.
  12. Oct 26, 2016 at 3:52 AM
    #52
    vinkon235
    vinkon235 Well-Known Member
    vince
    steubenville oh
    2016 white tacoma trdor access cab
    opt7 cree series fog lights busman aux relay box viair 450c oba opt7 fluxbeam led headlights
    Well done.Either this mod or some type of switch on the shifter would work for me.
  13. Oct 26, 2016 at 9:08 AM
    #53
    illogical
    illogical Well-Known Member
    2017 TRD 4x4 OR MT
    Really nice work and follow up!
    Putting this on the list of things to do for sure. Thanks!
  14. Oct 26, 2016 at 9:38 AM
    #54
    kahanabob
    Maui
    16 TRD 2WD 4DR
    still lost on exactly where you connect the blue wire?
  15. Oct 26, 2016 at 10:25 AM
    #55
    MESO
    State of Jefferson
    This is how I wired mine
  16. Oct 26, 2016 at 10:41 AM
    #56
    kahanabob
    Maui
    16 TRD 2WD 4DR
    getting closer...the SPDT relay is that a part i also have to buy or is it somewhere in the truck? thanks
    970verland likes this.
  17. Oct 26, 2016 at 10:53 AM
    #57
    MESO
    State of Jefferson
    Need to buy. Should only be a few bucks
  18. Oct 26, 2016 at 11:50 AM
    #58
    vinkon235
    vince
    steubenville oh
    Did you use t taps for your ect wiring connections?
  19. Oct 26, 2016 at 11:54 AM
    #59
    vinkon235
    vince
    steubenville oh
    Sorry, I should have paid more attention to the earlier pages of this thread.
  20. Oct 26, 2016 at 12:33 PM
    #60
    vinkon235
    vince
    steubenville oh
    Oh hell, now i'm confused.Is the pink wire from the ect button going to # 30 on the relay as noted earlier or
    going to 87a as noted after you put in the timer?
