ECT Mod -- ON ALL the time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Oct 18, 2016.
  1. Dec 19, 2016 at 2:57 PM
    #101
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Been there, done that. I did a full write up on ECT MOD ON all the time. Don't tap off start signal. All the wires you need are below the radio. (switched power from CLA, and trigger wires on ECT harness)
    Edit: that was weird..replied in a different thread and it posted to this oneo_O
    vinkon235 likes this.
  2. Dec 20, 2016 at 12:50 PM
    #102
    jomopdx
    jomopdx Well-Known Member
    jomo
    2016 Tacoma Sport
    Edited -
    Below is a diagram of the 12v Relay from Radio Shack.
    The pin labels are as follows: upper left two are: 87a(NC), 87(NO). Lower left two are the coil pins: 85, 86, Lower right is ground: 30.
  3. Dec 20, 2016 at 9:27 PM
    #103
    jomopdx
    jomo
    2016 Tacoma Sport
    This posting has been corrected to be as per OP's description on posting #1. And corrected as per posting below #105.
    From SPDT relay - pin 86 to cig lighter ground; pin 87 to ECT pin 1(white/black); pin 30 to ECT pin 4(pink); pin 85 to TR7 blue.
    From TR7 - Blue wire to SPDT pin 85; ground to cig lighter ground; green wire and red wire to cig lighter power.
  4. Dec 20, 2016 at 10:40 PM
    #104
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Great job. I must try
  5. Dec 20, 2016 at 11:03 PM
    #105
    MESO
    State of Jefferson
    @jomopdx
    You're correct on that radioshack^ relay pins. But you have #30 and#86 bassackwards.
  6. Dec 28, 2016 at 10:27 AM
    #106
    jomopdx
    jomo
    2016 Tacoma Sport
    Okay, here is my progress so far in the assembly of the kit:
    smitty99, Wallbright and vinkon235 like this.
  7. Jan 13, 2017 at 1:15 PM
    #107
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Any movement on this? Extremely interested.
  8. Jan 13, 2017 at 1:27 PM
    #108
    jomopdx
    jomo
    2016 Tacoma Sport
    Well, sorry not much, but ready to install. I have soldered the small relay into a small $2.50 Radio Shack circuit board and now just ready for the install. I also have numbers for the SPDT pins in post #1 of this thread if of interest to anyone using that relay type instead of the small one I'm using.
    Here goes on the numbers for the pins on posting #1 of this thread:
    Top: 87.
    Middle three - left to right: 86; 87a; 85.
    Bottom: 30.
    We got two feet of snow here in Portland and still need chains on my narrow hillside street. Also 17 degrees and the snow will be here for a while. Thank goodness for my Tacoma!!!
  9. Jan 20, 2017 at 5:01 PM
    #109
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    can i assume once this mode is done if the ECT button is pushed it will take it OUT of ECT mode? also is the very first post still the best way to get this done? remember reading somewhere there was an issue after a few starts but maybe that was another post.
  10. Jan 20, 2017 at 5:08 PM
    #110
    MESO
    State of Jefferson
    Correct. If you want to DISABLE ECT, push the button to turn it off. First post is the current method I am using.(had some failed trials previsously).
    It's Working 100%, truck gets started multiple times everyday. Love this mod! Thanks @mesojdmo_O:thumbsup:
  11. Feb 1, 2017 at 4:16 PM
    #111
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i just got the exact same relay from Amazon. i am lost, did you ever figure it out or do i need to find out where to get the SPD relay that the OP used? pins are super small!
  12. Feb 1, 2017 at 4:21 PM
    #112
    kahanabob
    Maui
    16 TRD 2WD 4DR
    where did you get the SPDT relay? i got the wrong thing from Amazon see last post above this of thread
  13. Feb 1, 2017 at 4:38 PM
    #113
    MESO
    State of Jefferson
    Any car stereo shop will have it. Just ask for a standard Bosch 12V relay.
  14. Feb 2, 2017 at 12:10 AM
    #114
    kahanabob
    Maui
    16 TRD 2WD 4DR
  15. Feb 2, 2017 at 12:21 PM
    #115
    jomopdx
    jomo
    2016 Tacoma Sport
    Yes, one can use this relay. It came with a test circuit board that can be taped together or one can buy a small circuit board from radio shack ($2.50) that the relay and wires can be soldered.
    Nonetheless, the bigger relays are easier to use and much easier to solder if one wants to go that route.
    Overall - still not a big issue to solve.
  16. Feb 2, 2017 at 12:40 PM
    #116
    jomopdx
    jomo
    2016 Tacoma Sport
  17. Feb 2, 2017 at 12:48 PM
    #117
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Anyone else find ECT is extremely touchy at 1% throttle (just as you touch it I mean) which makes it rather jerky?
  18. Feb 14, 2017 at 5:00 PM
    #118
    hightechcoonass
    hightechcoonass Living the dream
    Ritchie
    land of the swamps LA
    2017 SR5 4x4 super white
    TRD Offroad wheels and decal set.
    Very nice work indeed!
  19. Feb 14, 2017 at 7:37 PM
    #119
    rrentrop
    rrentrop TVDvinyldecals.com Vendor
    Rich
    Orange County, CA
    2016 Tacoma 4x2 Limited MGM
    T-Rex Billet Grille, N-Fab Steps, Tailgate decals, Bed Lights, Power Tailgate Lock
    Yes! For the past few months I've been driving with the ECT on, but the touchy throttle, particularly in reverse was starting to bug me in tight parking lots. I recently went back to normal and have learned to mash the pedal a bit more and actually like the way it is responding now. I'll be getting rev 1 done at my next oil change.
  20. Feb 18, 2017 at 6:11 PM
    #120
    AmericanDrug
    AmericanDrug Well-Known Member
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
