ECT Mod -- ON ALL the time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Oct 18, 2016.
  1. Apr 30, 2017 at 1:32 AM
    #141
    DonJuanTaco
    DonJuanTaco Tacoma Bandito & Enthusiast
    San Diego, CA
    '17 Super White DCSB TRD Off Road
    Sub'd. Thanks for this! :)
  2. Apr 30, 2017 at 10:48 AM
    #142
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    it controls when the transmission shifts, when ECT is on it holds each gear a little longer before shifting. it also effects the throttle response, someone else here can better explain that.
    i have posted in the past, drive the truck at 40 MPH with ECT engaged holding at 40MPH push the ECT button to disable it and you will feel like the truck is slightly breaking. try driving in both modes and you will see why some of us like it on all the time. one good test is turning right from a stop when merging into on coming traffic, you can feel a big advantage with RCT on.
    DesertTaco4x4 and Atowns40 like this.
  3. May 2, 2017 at 2:09 AM
    #143
    Ricky2_1
    Ricky2_1 Member
    Ricky
    2017 Silver Tacoma
    Just wondering this is harmless for the tranny and the truck itself?
  4. May 2, 2017 at 4:21 AM
    #144
    USMC8652
    USMC8652 Member
    2016 Barcelona Red Tacoma Double Cab TRD Off-Road
    None yet...
    Thanks have been wondering about this myself. Wish there was a way to get through the factory settings for this!
  5. May 2, 2017 at 7:08 AM
    #145
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    Someone might be able to correct me if i am wrong.. But haven't most if not all toyota AT tacomas had ECT since the 80's?
    I remember my brothers old 84 supra had an ECT button
    Nedrolls likes this.
  6. May 2, 2017 at 7:21 AM
    #146
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Don't think Toyota would put a button there is it was harmful to the vehicle.
    Unfortunately tech stream does not have an option for ECT on all the time
  7. May 2, 2017 at 1:11 PM
    #147
    kahanabob
    Maui
    16 TRD 2WD 4DR
    thanks to this thread we now have that option.
  8. May 3, 2017 at 12:34 AM
    #148
    Atowns40
    Atowns40 Well-Known Member
    Redding, CA
    17 DCLB TRD OffRoad Inferno
    Ive never had an auto before. Ive been dedicated manual driver up until now
  9. May 27, 2017 at 4:43 AM
    #149
    Riksolo
    Riksolo Well-Known Member
    2017 Tacoma TRD Off-Road
    aeromotive has the plug connectors google them send pics they will fedex them right to your door
  10. Jun 2, 2017 at 7:26 PM
    #150
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, RRW wheels 17 x 8.5, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights, OEM sport hood, PPF and tint,
    Aside from disarming my seat belt chime this is by far my favorite mod so far!! Thanks.
  11. Jun 2, 2017 at 7:27 PM
    #151
    MESO
    State of Jefferson
    ^no prob. Ive had the mod on for almost a year... turns on every single day. Not 1 issue.:D
    vprgts likes this.
  12. Jun 3, 2017 at 11:35 AM
    #152
    Deet
    Deet Well-Known Member
    Tracy, CA
    2016 White TRD Off-Road 4x4 DCSB
    Another ass-kickin' mod from Stew! :muscleflexing:
    I completed this mod a couple of days ago. Flawless! Works every time. :thumbsup::D
    vprgts and MESO[OP] like this.
  13. Jun 3, 2017 at 7:12 PM
    #153
    kahanabob
    Maui
    16 TRD 2WD 4DR
    did you cut and splice into the wires from the ECT switch and lighter power source or did you do a clamp (saddle) to connect to the wires i mentioned?
  14. Jun 4, 2017 at 11:58 AM
    #154
    Kenjiro
    Kenjiro Well-Known Member
    2016 DCSB TRD-OR
    This is going to be my weekend project. HUGE props to @mesojdm for the write up. Threads like this are why I joined the forum.
  15. Jun 8, 2017 at 11:46 AM
    #155
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    Hey guys, quick question. I mount all my relays in the engine bay to keep things clean. Looking at doing this and wanted to know if this relay would work instead of the standard relay + alpine adapter.
    https://www.delcity.net/store/Time-...zUMR8LxdkDBCTaA3NKtmPN03iFURyCs3JIaAlzA8P8HAQ
    I'm thinking set a 5 second delay and I should be good. It also mentions this is a solid state relay, but honestly, I don't know if it provides the protection someone else mentioned a few pages ago.
    Thoughts?
  16. Jun 8, 2017 at 11:51 AM
    #156
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    That's delay on release, you want delay on operate.
  17. Jun 8, 2017 at 12:03 PM
    #157
    Nfarrall
    Nfarrall Well-Known Member
    Chester county, PA
    2017 QS DCSB SR5
    I have access to tis and can check the ewd for a connector and get a part number. just need some more info on what connector youre looking for.
  18. Jun 26, 2017 at 4:27 PM
    #158
    kahanabob
    Maui
    16 TRD 2WD 4DR
    tried to do this today but the A/C bezel seems stuck at the left side by the center gauge cluster. any more pulling and am afraid it will break?
    suggestions...
  19. Jun 26, 2017 at 8:34 PM
    #159
    MESO
    State of Jefferson
    It's tucked under the lip of the panel below steering wheel gently pull it out and it will free AC panel
  20. Jun 27, 2017 at 8:28 PM
    #160
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    @kahanabob I finally did this today using @mesojdm instructions, worked first time. I build a tiny harness, but used the module and relay that is mentioned here. Two things to note.
    1. To get 2nd bezel off (with the push to start button), pull the panel to the left out, you don't have to remove it all, just pop that one part to the right of the steering wheel out, just that clip. It flexes out of the way and lets you pop the panel off easier.
    2. It wasn't hard to do, and the default setting of the TR7 module works perfect for me.
    Thanks for the write up Mes.
    TacoSportTRD and MESO[OP] like this.
