ECT Mod -- ON ALL the time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Oct 18, 2016.
  1. Jun 27, 2017 at 8:45 PM
    #161
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    This is the harness. It's really just the diagram, with the grounds soldered and shrink wrapped, the two on the TR7 connected to a single 16AWG wire. I zip tied the 3 wires on the TR7 not needed together, and then wire loomed it to keep it nice and clean. It dropped behind the dash no problem and shouldn't move around. No rattling while driving.
    Also, getting the cig lighter plug out, just pull, it's not got a clip..but it's in a wierd spot and kinda hard to pull.2017-06-27 18.01.36.jpg
  2. Jun 27, 2017 at 8:47 PM
    #162
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    ^ that's whats up. A little bulky and barbaric. But cheap and works!
    DesertTaco4x4 likes this.
  3. Jun 27, 2017 at 10:49 PM
    #163
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    are the wires on the ECT and cig lighter connector exposed or did you have to cut into a harness covering?
  4. Jun 28, 2017 at 5:53 AM
    #164
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    There's a mesh-like loom with a piece of electrical tape. Just gently cut or remove the tape and you can peel it back and acces the wires.
  5. Jul 5, 2017 at 5:41 PM
    #165
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    To those interested in doing this, even in light of the OV Tune, incoming video showing how easy this really is. Parts, maybe $25? 100% reversible. Not to knock the OV Tune, as I'm sure it's going to be nice, but this is still a cheap and dirty way to get this done on a budget and help those who aren't running stock tires and lifts any more.
  6. Jul 5, 2017 at 5:48 PM
    #166
    MESO
    State of Jefferson
    I think this mod will even be icing on the cake for the OVTune. He mentioned that tuning in ECT Mode yeilded better results.
    And yeah, this is a cake install. You can have it all wired up ready to go, and the install literally requires no tools. Just pull all the panels off and tap the wires.
  7. Jul 5, 2017 at 6:08 PM
    #167
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
  8. Jul 5, 2017 at 6:22 PM
    #168
    MESO
    State of Jefferson
    Great video @fajitas21 !
    It's really that simple.
    Another tip: if you can't unplug the ECT, Just reach back and push it out through the front. Now you can hold the button in your hand and unplug/tap/etc
    Just to clarify, the relay is not powering anything on the ECT wires . All it is doing is "connecting the circuit" when the TR7 tells it to. Basically mimicking the user pushing the button.
    And finally, it's
    ME
    SO
    JDM
    JDM as in Japanese domestic market.
    If you say it fast.. it sounds like you are from there lol.
    remgu2000, Mr-Paul and DesertTaco4x4 like this.
  9. Jul 5, 2017 at 6:27 PM
    #169
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    Yea once I actually went to get your name I realized it was JDM on the end. Sorry about that.
  10. Jul 6, 2017 at 7:25 AM
    #170
    meyergsr
    meyergsr Well-Known Member
    Frederick, MD
    17 Tacoma OR, AC
  11. Jul 6, 2017 at 7:30 AM
    #171
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    I looked into it, and I'm sure the answer is yes, but here's why I just went lazy and copied @mesojdm:
    It was proven.
    So, keeping in mind you need a device to just pulse, not delay, then stay on, I say figure it out and share with the group. We would all appreciate a simpler version of this, but if you're willing to solder or crimp a few wires and hide the bulky harness behind your dash, this is pretty easy and cheap.
    Keep us updated if you try that item there.
  12. Jul 6, 2017 at 7:36 AM
    #172
    meyergsr
    Frederick, MD
    17 Tacoma OR, AC
  13. Jul 6, 2017 at 7:52 AM
    #173
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    That might work, here's what it says on the description page:
    Working modes selection: after power on, long press K1 for 2s, later into the selection of modes: P1~4; K2 to enter the mode.
    P-1: Monostable trigger delay, a signal to trigger relay, time is up, the relay disconnect;
    P-2: A signal trigger and countdown begins, T1 seconds after, the relay open T2 seconds, then close;
    P-3: Open T1 seconds, disconnect T2 seconds, infinite loop. Users can set the relay time T1 and T2;
    P-4: The relay opens when a signal triggers, when the trigger signal disappears, digital countdown begins, and the relay closes when the time is up.
  14. Jul 23, 2017 at 12:08 PM
    #174
    Deet
    Deet Well-Known Member
    Tracy, CA
    2016 White TRD Off-Road 4x4 DCSB
    @kahanabob,
    Sorry I took so long to respond - No wires cut at all. I used Posi-Taps (all I ever use now) for any connections to factory wiring. If necessary, these can be removed in just a few seconds and you can't even tell they were ever there.
    Check 'em out here: http://www.posi-products.com/index.html
  15. Jul 23, 2017 at 12:13 PM
    #175
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Hello,
    Do the bezels pullout or are they screwed into place
  16. Jul 25, 2017 at 12:12 PM
    #176
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    check the vid above, he pulls everything right out, all clips.
  17. Jul 25, 2017 at 1:23 PM
    #177
    harrycary
    Harry
    Got it. Thanks.
    BlkTaco47[QUOTED] likes this.
  18. Jul 25, 2017 at 1:25 PM
    #178
    BlkTaco47
    BlkTaco47 Unhinged
    sure man, didn't know it was quite that ez until
    I watched the vid.
    harrycary[QUOTED] likes this.
  19. Jul 27, 2017 at 10:34 AM
    #179
    BlkTaco47
    BlkTaco47 Unhinged
    anything yet :D
  20. Jul 30, 2017 at 6:00 PM
    #180
    MESO
    State of Jefferson
    Nope sorry. Mine has been working perfect I haven't even thought about looking for an OEM style connector. I prob won't either. It's only 2 wires to tap(not cut) so really easy to install or remove if needed.
