ECT Power button disables Atkinson Cycle ? I think so
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Suehog60, Jan 14, 2016.
  1. Jan 14, 2016 at 6:14 PM
    Suehog60
    Suehog60 [OP] Active Member
    Sioux Falls, SD
    2016 Tacoma TRD 4X4 Off Road
    TRD wheels, Michelin Defender LTX tires, Extang solid fold bed cover, OE roof rack added, 32" Caliraised LED light bar behind lower grill, Husky Liner floor mats, OE sliding bed divider, LED strip lights under bed rail, Fumota oil drain valve, TRD Pro skid plate, Warn front bumper, Weathertech in-channel vent visors, Updated TSB front door seals, Glove box and center console organizers,
    I activate "ECT Power" and Manuel Shift mode all the time because I don't like how sluggish and shift happy the engine/auto is when in "regular" mode. Other then the ECT Power raising and holding shift points of the trans I have suspected it disabled (or reduced) the Atkinson cycle because engine is more responsive and I may have confirmed that today. On flat interstate running 65 mph, no wind, no "cruise control" I was in 6th gear w/ECT Power activated and watching the MPG bar on screen between tach and speedo. When I deactivated the ECT Power, the mpg jumped up and I could feel and hear a slight change in the engine which then had that sluggish feel to it. I reactivated the ECT Power and mpg dropped back down and heard the slight change and feel again.
    Only makes sense, in a normally aspirated engine, less fuel is less power. I really like my Tacoma, but 6th gear is almost useless at higher speeds, 75+, because engine doesn't have enough torque to pull 6th gear. Speed limit here in S Dakota is 80 and is easy to maintain in 6th gear in my Vette, but not in my Tacoma.
  2. Jan 14, 2016 at 6:47 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    this has been my theory for some time... however the only way you will know for sure is to hack the ECU. Maybe toggling ECT while stopped and having someone place their hands over the cam sprocket motor would tell us more.
  3. Jan 14, 2016 at 7:31 PM
    Bishop84
    Bishop84 Well-Known Member
    "With this drive mode select system, the driver can allow the vehicle to launch the ECT PWR mode
    through a switching operation.
    The ECM improves acceleration performance and responsiveness by controlling the engine output and
    by changing the shift point of the transmission, thus achieving a sporty drive."
    I doubt there's much beyond shift management and throttle response.
  4. Jan 14, 2016 at 7:57 PM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    One way to test the throttle theory. Put the transmission in 1st (S1)and see how responsive the throttle is with ETC and ETC off. If there is a difference, then fuel mapping is also changing. If not, then it is probably how the AT shifts.
    I have the 4cylinder, and of course no Atkison and the behavior is like what you have described.
    Keep in mind the ECU won't let you ping the engine with the anti-knock adjustments. This means in normal AT mode, it retards the timing when you step on the gas giving you that sluggish feeling. When the engine load is lower, the timing is set better. This means in ETC mode you are loading down the engine less resulting in more power because you are not getting into the ECU retarding the timing.
  5. Jan 14, 2016 at 9:35 PM
    Suehog60
    Sioux Falls, SD
    Yes, Lots of good info after you wade thru all the worthless info and trolls. I just "ignored" lobster also and have some others on the list.
    Andy4wd and Kevindust like this.
  6. Jan 14, 2016 at 9:45 PM
    Bishop84
    We laughed when we got in the new Taco's and saw the ECT button. Some Lexus SUV's have it but I always associated that button to really slow old Toyotas like the 3rd gen 4runners. I'm still surprised they didn't call it "sport" or "tow/haul"
    Back when I was a young punk "race mode" used to be A/C off, ECT on and O/D off haha. :turtleride:
    FeraNatura likes this.
  7. Jan 14, 2016 at 10:08 PM
    Suehog60
    Sioux Falls, SD
    You guys are helping me with my list, :thumbsup:
    ZachMX likes this.
  8. Jan 14, 2016 at 10:11 PM
    Metalnut
    Metalnut It's a clown world
    Adam
    North Alabama
    2016 Tacoma DCLB 4x4 TRD OR
    BP-51s, UCAs, BAMF sliders, SCS Stealth 6, 285 Wildpeaks, HIDs, LEDs, custom grille, hard top.
    The reason I think ECT changes more than just transmission shift points is that without it, the engine seems to produce more braking. I've been playing with this and it's definitely more than throttle response UNLESS the transmission is doing something I don't understand. Once ECT is on, the truck just rolls more freely with or without throttle. I almost hate to turn it off, but I'm getting shit MPG even in D with it off (I average 18 on the highway, FML).
    Something my friend brought up... the same engine is rated for higher horsepower in the other models that it's used in. I'm assuming internals are the same, so that would mean a different tune. Maybe ECT modifies the tune on the fly a bit? I'd be curious about dyno outputs with it on and off, but the real test would be to monitor the ECU of course.
    cryptolyme and Tacoma2GR like this.
  9. Jan 14, 2016 at 10:23 PM
    Suehog60
    Sioux Falls, SD
    I thought the ECT Power only controlled the trans until I watched the MPG jump up and down today so it is definitely controlling the engine tune also. Gas is cheap so not so concerned about the MPG, but I do like it to drive w/o engine laboring at low rpms and then start downshifting excessively. I read on another post that Toyota is working on a trans recalibration due to the shifting, and if so, I would get it.
  10. Jan 14, 2016 at 10:28 PM
    Metalnut
    Adam
    North Alabama
    Yeah, I've been hearing the "Toyota will update the transmission firmware" story for a few months, I'm not really betting on that. I'm with you on the engine tuning, though, it'd make sense honestly.
    For what it's worth, the freeway entrance I take each morning is a marge from about 2 miles of gradual uphill road. In D with ECT off, I may as well be walking onto the highway, the truck just can't get up to speed without me mashing the gas pedal to hell. Throw it in ECT mode, life gets better. Put it in "S" with ECT on and rev the snot out of it, hitting 7K RPM this morning... and I'm at 80mph in a flash. I have NO complaints.
  11. Jan 14, 2016 at 10:37 PM
    Suehog60
    Sioux Falls, SD
    Yes, it's like a different truck using the ECT Power but do wish it had more torque.
    Metalnut, thanks for the logical replies.
  12. Jan 15, 2016 at 7:20 AM
    FOXY 367
    FOXY 367 " PAIN IS LIFE'S GREATEST TEACHER "
    2016 Tacoma DC Long Bed TRD Sport 4 X 4
    None
    The ECT has nothing to do with the motor it is a Transmission control that allows the transmission to wind out 500 RPM more in each gear when it is "ON" The Atkinson Cyl Engine Has two Connecting rods per Piston and the Cam Shaft is ground onto the Crank Shaft
  13. Jan 15, 2016 at 8:25 AM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Is this actually how these engines run? If so.. mind blown:boom:
  14. Jan 15, 2016 at 8:36 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    This theory sucks, thought we already established that. I posted the Toyota published explanation that the ECT works with the transmission controller and has nothing to do with the engine, but yet people insist on arguing.
  15. Jan 15, 2016 at 8:38 AM
    FOXY 367
    None
    You've been in the Boiled water to long Lobster, this is exactly how the Atkinson Cycle engine works and the efficiency derived from it is achieved by allowing all 4 Stroke events of a 4 cycle engine to occur in 1 rotation of the crankshaft eliminates the need for an independent cam shaft and cuts th intake stroke in half of what it is in a true 4 stroker. This same motor has been used in the Lexus GS350 for the past 5 years and has a proven reliability record. If you can prove otherwise please post the proof.
  16. Jan 15, 2016 at 8:47 AM
    Daytona Coupe
    Daytona Coupe Well-Known Member
    Visalia CA
    16 TRD Sport DCSB
    That may be how a "true" Atkinson engine is, but that is not how the Toyota version of it works. Toyota simply delays the closing of the intake valve in order to reduce the effective intake volume in relation to the exhaust stroke. If doesn't have all of that monkey-motion going on in the crankcase.
  17. Jan 15, 2016 at 8:47 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    same thing I've always read. :thumbsup:
  18. Jan 15, 2016 at 9:28 AM
    Metalnut
    Adam
    North Alabama
    Not arguing, theorizing. Trying to explain and understand the perceived feeling of different engine performance and apparently different indicated fuel economy. Questioning something is part of human nature, and published explanations can sometimes be purposely misleading. Not saying that's the case here, but it's an interesting discussion.
  19. Jan 15, 2016 at 9:39 AM
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    Dude... Jesus Christ... the lack of clear communication and mis-information on this forum is scary at times. This engine is a simulated Atkinson cycle engine... pretty sure it's ALL in the intake valve timing. 100% otto cycle under higher loads / WOT
  20. Jan 15, 2016 at 10:29 AM
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    I thought ECT power locks out 6th gear?
