ECT Power button disables Atkinson Cycle ? I think so
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Suehog60, Jan 14, 2016.
  1. Jan 19, 2016 at 10:49 AM
    #141
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Uh oh, he has been told that before and doesn't like that response. now you will be on his shit list, too
  2. Jan 19, 2016 at 10:55 AM
    #142
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    That was my first thought, just wasn't sure if the VVTi system was doing some new magic tricks. thanks
  3. Jan 20, 2016 at 3:13 AM
    #143
    Upstate NY
    Upstate NY Well-Known Member
    Rob
    Hudson Falls
    2018 TRD Access Cab
    LT265/75 R16 Goodyear Wrangler Duratracs WeatherTech hood guard WeatherTech side window deflectors Toyota bed mat Alabama Crimson Tide hitch cover
    No, as I have not had the opportunity to drag it through any measurable snow cover on the road yet.
  4. Jun 3, 2016 at 1:56 AM
    #144
    InfernoTacMan
    InfernoTacMan Active Member
    Arizona
    2016 TRD Sport
    Magnaflow Exhaust, side steps, custom Carbon fiber wrap, T rex grille and badges, custom rims - off road tires
    I have a 2016 TRD Sport and was majorly disappointed with the HORRIBLE throttle response on the low end. Often found myself doing an imaginary "push" thinking that my bodies momentum would somehow speed up shifts.
    ECT power clears that up almost 100% - staying in "S" completes the package. Its night and day. You will NOT always be revving higher as believed if you calmly drive, however when you kick in some throttle, the shift points are certainty in the higher RPM range. Its how the truck should have been setup for as the default shift pattern in the first place (mandatory MPG numbers spoil all the fun). My fun to drive and responsive 2011 V6 frontier just runs circles around the 2016 tacoma with ECT off.
    Im not a 4 wheeling kind of guy, just want a smooth driving experience. Adding a CAI and scoop attachment when it comes available, leaving in ECT mode at all times, plus sport (minus limited freeway driving) and if they ever make some sort of tuning device for this truck, I'll be first in line to use it.
    Someone else mentioned it in the forum, but the truck needs to "learn" for the first 1000 miles to fix its endless shifting, then learn again if you in any away affect the MAF (via CAI or high flow drop in) .
  5. Jun 3, 2016 at 3:57 AM
    #145
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    S mode doesn't change the shift pattern. Its just a gear limiting feature
  6. Jun 19, 2016 at 6:44 PM
    #146
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    We have that on wife's Venza 6 speed with S mode. It's very effective. The cars have two over drives. 5th and 6 th gear kill acceleration bellow Hyway speeds.
