ECT Power button.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hogzilla, Jan 5, 2011.
  1. Jan 5, 2011 at 5:19 PM
    Hogzilla
    Hogzilla [OP] Well-Known Member
    Michael
    DFW, Texas
    04 Prerunner sr5
    So what exactly does it do? I know it makes the tranny shift at higher rpms, but does this make any real difference? Also, what kind of hit do you take in your mpg while in "power" mode?
  2. Jan 5, 2011 at 5:28 PM
    v1ndictiv3
    v1ndictiv3 Well-Known Member
    Bay Area, California
    '98 PreRunner Xtra Cab 2.7L
    Mostly stock: AFE Pro Dry S Filter, Bedrug, Leer Shell, 265/75/15 Goodyear Wrangler RT, Husky Liners, Wet Okole seat covers... Powertrax No-Slip in the near future =)
    *Note, I have a 2.7
    So today was the first time I've used the ect power mode to see the difference in power output at higher rpm... When I first got my truck I test drove it out on a highway and floored it a bunch of different times from various cruising speeds to see how well it accelerates and it accelerated fairly quickly but obviously lacks the power of a v6 or higher. I only took it to 95mph and was at about 4000 rpms-ish. Was curious about the power mode so I turned it on today, was cruising at about 50mph on the highway when I floored it... Huge difference, to me at least... It accelerated considerably quicker (lot less time to hit 95mph) and the rpm were hanging around in the 5000 rpms... I decided to stop there because I don't like redlining my vehicle if I don't have to and it was at the base of the redline. As for gas consumption, I think that if you use the power mode and drive normally and conservatively you won't notice a difference. In either mode when I floored it I lost a considerable amount of gas, perhaps a bit more with the power... Just my experience.
  3. Jan 5, 2011 at 5:31 PM
    11BSSG
    11BSSG Well-Known Member
    33°28'18"N /-86°48'2"W
    07 4X4 A/C 6 Spd
    Front-Billy 5100'2 @ 2.5, Rear- Wheelers 1.5" AAL w/ Billy 5100's, 17" XD Addict's, 285/70-17 Nitto TerraGrappler AT's, 20% Tint, UWS Low Pro Toolbox, N-Fab Nerf Steps, K&N, Black Head Lights, Hard Wired GPS, XM Onyx, Hardwired Radar Detector, Ultraguage, Thule Mtn Bike Lock, Sleeved Fog Light Housing, Black Emblems, Satoshi/Color Matched grille, Misc. Security Upgrades.
    ECT (Electronically Controlled Transmission) electronically adjusts the rpm at which the transmission shifts. With ECT activated, the automatic transmission will rev to a higher RPM before shifting, and allows quicker acceleration by keeping the engine closer to its power band. Also decreasing fuel economy. It doesn't actually change anything going on in the engine, mess with fuel mapping, ignition timing or any other crazy claim you may have read. Its not a magic "add 50 HP" button, just holds shifts a little longer. I suggest leaving the ECT turned off unless you have a load and are merging on the freeway or something. In my old 4Runner, even if I had the ECT on I had to damn near floor it to see the RPM "hang" and any difference in shifting. The hit you take on mpg's depends on how heavy your foot it....is almost impossible to give a hard # on how much your MPG's will drop. (Order a ScanGauge II or UltraGauge and play with them if you want to figure out your MPG loss. Unless you floor it everywhere you go, there is no point in leaving the ECT power on. Hope this helps.
    Also: http://www.tacomaworld.com/forum/1st-gen-tacomas/121204-ect-power.html
    and
    http://www.tacomaworld.com/forum/1st-gen-tacomas/78237-ect-normal-power-mpg-3-4l-only.html
    search is your friend.
    EB Group likes this.
  4. Apr 26, 2011 at 1:23 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I leave mine on unless for some reason i need to tip-toe, such as really bad weather or something
  5. Apr 26, 2011 at 1:54 PM
    The Munster
    The Munster I like turtles!!!
    Lance
    Moody AFB, GA
    The Rpms could have been higher because the ECM disengaged the torque converter lock up. That would explain why your Rpms where up
  6. Apr 26, 2011 at 1:58 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    That button is there for time travel. Once you hit 88mph you go back to the future. Did you notice anyone riding hover boards? I bet you did. Cuz you hit 95. You must a gone way into the future. What was it like?
  7. Apr 26, 2011 at 4:01 PM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    I honestly was wondering the same thing...
  8. May 15, 2014 at 5:20 PM
    fozalgerts
    fozalgerts New Member
    OK
    1999 Tacoma PreRunner
    4" lift, Loud dual exhaust, running boards/tubes.
    Thank you Matt, your post was very helpful.
  9. May 15, 2014 at 5:26 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    Would ECT help me out when going uphill? When ever I drive to NorCal, my truck always struggles in the grapevine and i always find myself in the slow lane with the big-rigs. Will ECT help me out in this scenario? thanks
    DLtaco02 likes this.
  10. May 15, 2014 at 5:35 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
  11. May 15, 2014 at 5:36 PM
    TashcomerTexas
    Put it in 2 and switch it on.
  12. May 15, 2014 at 5:43 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Electronically Controlled Turbo, incredible feature really.
  13. May 15, 2014 at 5:44 PM
    Zer0
    SGV, California
    99 PreRunner
    I put the gear in 2 and turn ECT on? Im going at freeway speeds (65-70) is it safe to downshift to 2 and turn on ECT? thanks
  14. May 15, 2014 at 5:54 PM
    TashcomerTexas
    Yeah no just the ECT. You should never use speed as a guideline when switching gears, base it on the RPMs. And when it comes to automatics switching gears gets more complex; you can shift anytime while in motion.
  15. May 15, 2014 at 6:17 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I used to leave mine on because my transmission would feel like it hesitates to shift or it would sluggishly shift. Having the ECT on, I stopped that but decreased my fuel economy. So now I leave it off and only turn it on if I'm hauling something in the bed or towing a trailer
  16. May 15, 2014 at 7:26 PM
    ToyComa84
    ToyComa84 Well-Known Member
    Matt(hew)
    "flatland"
    03 prerunner sr5
    plasti dipped wheel caps,
    I think that really helps for me. Thanks!
  17. May 15, 2014 at 11:22 PM
    synergy10
    synergy10 @synergy10.sd
    San Diego
    Have you tried turning off your overdrive when going uphill? I go up the same "hill" and am able to keep a respectable speed at 65-70 mph.
  18. May 16, 2014 at 12:25 AM
    Zer0
    SGV, California
    99 PreRunner
    Ive tried turning overdrive off while going up the grapevine but it seems to rev really high and only gives me just little more power. I usually just keep overdrive on but my foot heavier on the gas pedal. For me to increase more speed I literally have to floor the damn thing. I plan to do a tune-up this weekend maybe my engine is just not running the way it should. How do you drive when you're going up the grapevine? Do you have to floor it too? What engine size are you? Im a 2.7
  19. May 16, 2014 at 12:34 AM
    TashcomerTexas
    Well now try turning O/D off and turning on ect that should make it easier
  20. May 16, 2014 at 12:40 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    That could make your transmission run really hot, vs running with OD off.
