ect power button
Discussion in '1st Gen. Tacomas (1995-2004)' started by mcl77, Jul 28, 2020.
  1. Jul 28, 2020 at 7:00 PM
    mcl77
    mcl77 [OP] Well-Known Member
    My 2003 tacoma has this ect power botton on the left of the steering wheel.
    ive never used this in my 10 years of owning this truck. other than to test it to see if i notice a difference.
    it couldnt notice anyyhing different.
    what is this supoosed to do??
    my truck is 4 cyl 4wd auto
    six5crèéd and Taco critter like this.
  2. Jul 28, 2020 at 7:04 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Electronically Controlled Transmission. Just helps it shift a little better. I never turn it off.
  3. Jul 28, 2020 at 7:14 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    ECT...sort of a wannabe tow/haul mode. It just changes the shifting points for the transmission. 3rd gens have something similar.
    I like it, leave it on most of the time. I think I get slightly better MPGs with it but it could depend on driving style.
    Only time I recommend not having it on is if you are on a two lane highway and trying to pass someone. You're not going to have the same quick response from punching the gas to get around the other vehicle and back in your own lane, there's a bit of a delay when you really stomp on the pedal. Hence the better MPG theory.
  4. Jul 28, 2020 at 7:43 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    The ECT, in my own experience in my '01, holds out to a higher RPM before it shifts to the next gear. But if you're easy-driving around town you won't see a difference-it really becomes more notable with more throttle. On the freeway, it will downshift with less throttle input than if you had ECT off.
    I don't know about your 4 cylinder, but my 3.4 is designed for low-end torque so I feel more "pull" with ECT off with throttle input. I like both modes for different reasons.
  5. Jul 29, 2020 at 7:26 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I've actually noticed the opposite, it wants to shift "sooner" with ECT ON than off. Although I don't use it when highway traveling unless pulling my trailer, never saw the need as I routinely turn off O/D going up hills I know would cause the shift.
    also @Ridgerunner they may have more torque than HP but that 3500 rpm curve when it kicks in "myself" wouldn't consider "low-end" :D
  6. Jul 29, 2020 at 7:48 AM
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    I wonder if those who are SC’d noticed more profound changes when they activate the ECT button?
  7. Jul 29, 2020 at 8:32 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Just stating how this thing acts with my truck. There is definitely more of a torquey feel with ECT off, naturally, because the trans is upshifting sooner.
    My gal's '87 Celica GTS has ECT (yup, Toyota had ECT 33 years ago) and in that car, with ECT on, it will hang onto each gear to a MUCH higher RPM than my truck, even with light throttle. It's like a dramatic over-ride of shift points as if I was manually shifting it.
    six5crèéd likes this.
  8. Jul 29, 2020 at 8:34 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I never turn it off on my '03, I get better mileage with it on.
    cruiserguy likes this.
  9. Jul 29, 2020 at 8:50 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    having read all responses
    having understood some perceive the ECT differently
    i still dont know what the ECT is about
    question ............
    a- does it provide a ' Lock Up '
    years ago this was all the riguer providing greater efficiency
  10. Jul 29, 2020 at 9:07 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    no "lock-up" if you're thinking of the torque converter. that is still electronically controlled. the ECT just maintains the gear to a higher RPM before shifting, kind of like what other vehicle's "towing" mode does. but this does not down-shift like towing mode, only holds the up-shift RPM (or down-shifts sooner to accelerate but not "trans-brake-ish")
