ECT POWER MPG increase.. why?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Jan 11, 2011.
  1. Jan 11, 2011 at 3:57 PM
    ywen
    ywen [OP] Well-Known Member
    So any official explanation why the ECT POWER mode for AUTO V6 Tacomas increase the MPG significantly? (2-3 MPG)
    My driving habit is to stay at 65-70mph on the highway and almost always apply the gas gingerly when accelerating on local roads.
  2. Jan 11, 2011 at 4:19 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    The ECT power button just changes the shifting points of your trany. Basically when it is on it will downshift sooner and will not shift into a new gear as quick when taking off. When it is off it will shift into a higher gear faster to save on gas.
  3. Jan 11, 2011 at 4:22 PM
    tacomarotto
    tacomarotto Tempus Fugit, Memento Mori
    Jon
    Jacksonville, FL
    2001 DC 4WD TRD 2022 Lexus GX460
    ya know what... i thought i was crazy...
    now i dont feel so alone. when i used my ECT power button a few weeks ago i actually noticed BETTER mpg... i was shocked
    davidstacoma likes this.
  4. Jan 11, 2011 at 4:27 PM
    ywen
    Theoretically you'd think the NORM mode saves gas.. that's what I thought too.. but it is the exact opposite.
    There has to be an explanation.
    I've calculated my MPG both by manual means and in real time with my ScanGauge II
    In fact, once I drove down the highway after getting gas and having the ECT button switched back to NORM accidentally.. I thought I had just gotten bad gas because the MPG in ScanGauge was 2-3 MPG less than what I'm used to. Switched back to ECT PWR and the MPG returned back to normal after a while.
  5. Jan 11, 2011 at 4:29 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Like goomba said though-you get better mileage with the ETC off..not on. When it is off the tranny upshifts sooner each gear to reach high gear asap for economy. ETC on holds each gear out to a higher RPM before upshift for power AND tranny will downshift much more easily under even moderate throttle for power in ETC mode.
    Bottom line is your mileage should be worse with ETC on.
  6. Jan 11, 2011 at 4:29 PM
    ywen
    SOunds like you've never tested this theory out. Give it a try, you might be surprised.
  7. Jan 11, 2011 at 4:33 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I run ETC on fulltime so maybe you might be right but what we told you is what its intended job is-so if you are getting better mileage the other way it's odd but not impossible.
  8. Jan 11, 2011 at 4:46 PM
    goomba
    Josh
    San Antonio Fl
    It will benefit you if you drive on hills a lot.
    straightawaykid likes this.
  9. Jan 11, 2011 at 4:52 PM
    ywen
    still looking for a reasonable explanation for the increase in mileage. Since the commonly known "shift point change" explanation is counter intuitive to the increase in mileage.
  10. Jan 11, 2011 at 4:58 PM
    tacomarotto
    Jon
    Jacksonville, FL
    idk bout yall but i feel like i should drive with my ECT button on a little more often and see what happens.
    Gavingamer901 likes this.
  11. Jan 11, 2011 at 5:03 PM
    ywen
    You should be able to tell the difference after less than a 1/4 tank..
  12. Jan 11, 2011 at 5:10 PM
    tacomarotto
    Jon
    Jacksonville, FL
    ill let you know but its done me good b4
  13. Jan 11, 2011 at 5:28 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    The owners manual states the best gas mileage will be obtained with ECT off. FYI
    Flash
    Brie likes this.
  14. Jan 11, 2011 at 5:30 PM
    surfermatt
    surfermatt Well-Known Member
    CA
    04 prerunner, ext cab
    Front long travel custom: king 10" CO, solid lowers, fabbed spindle, heimed everything ect. Rear still in progress, waiting to be put on: bilstein 9100s, T100 axle. Stock 3.4 engine, 4.30 gears.
    Could possibily be your driving habits, with "ECT power" on then the shifts will be later and you will feel a little more "power" since you will be in a lower gear for a split second longer, instead of making up for the lack of power with your foot but idk, im no expert
    Brie likes this.
  15. Jan 11, 2011 at 5:35 PM
    ywen
    Well I've also observed the drop in MPG while cruising at a steady speed on the highway. So I wouldn't think the different shift points play much role in that driving scenario.
  16. Jan 11, 2011 at 6:15 PM
    surfermatt
    CA
    then there should be no difference at all imo cause nothing should change but im always looking for mpg improvment so ill stay posted :)
    Gavingamer901 and Brie like this.
  17. Jan 11, 2011 at 6:33 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    That's very possible.
  18. Jan 11, 2011 at 10:04 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    I'll have to try it one of these days
  19. Jan 11, 2011 at 11:18 PM
    MidnightSun
    MidnightSun Active Member
    Tim
    San Francisco, CA
    2002 PreRunner Double Cab
    I wonder if it holds true for a 4 banger too:D
    Might have to give it a try on next tank.
  20. Jan 9, 2013 at 12:15 AM
    BackCountry
    BackCountry Well-Known Member
    2001 TRD
    Curious how folks have been making out in ECT MPG stats... I noticed this thread the other day and thought I'd flip mine on and see what's happening. I prefer the shift points with the button on, I notice that while driving at city speeds it's sitting at much lower rpm's. Typically at 45km for example I'd be at about 2100rpm, but with the switch on I'm now running close to 1200. From this point of view I can see how it would yield in better MPG.
    It almost seems like the toggle is reversed or something... I'd expect to be sitting in lower gears at higher rpms, not the opposite. As mentioned by others though, hill climbing makes a difference.
    Brie likes this.
