ECT POWER MPG increase.. why?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Jan 11, 2011.
  1. Jan 9, 2013 at 5:48 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Mileage increase could be due to the tranny shifting gears at the most efficient point, the engine tends to work harder if the revs and shift points aren't optimal. I did notice a similar issue on my old Jimmy when I quit using the overdrive around town, my mileage actually increased a bit. I gotta fill up with gas today, maybe I'll try a tankful with the ECT on although increases may just be due to not getting your foot into it so much as you accelerate up to cruising speed.
    davidstacoma likes this.
  2. Jan 9, 2013 at 6:01 AM
    TacoSkeet
    TacoSkeet 'MERICA
    Steven
    Memphis, TN
    03 DC Tacoma
    sub'd Gotta try this out!
  3. Jan 9, 2013 at 6:04 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    You know when I bought my 96 a few months back I had the button depressed for a few tanks and I was getting better mileage than I am now. I'll have to test this theory on the next tank.
  4. Jan 9, 2013 at 6:27 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I am gonna jump in and say, this is the answer.
    ECT button on, should be less mileage in a perfect world
    ECT off, should be better mileage in a perfect world
    this 'perfect world' is driving with your foot in econo mode as well.
    I have 14 years of ECT on and off experience in a 4runner, with
    10 years scangauged, and overall, there is a smidge better MPG with ECT off
    I use ECT on a lot though, because I am on the highway a lot and I like
    it to downshift sooner as I want to pass and filter myself into the
    traffic patterns...with ECT off it is a dog, and I end up matting it harder
    to blend into traffic. This takes a little off the MPG
    So, it is still 'how you use it' but the ECU program and shift points, -on paper- dictate better
    MPG with ECT off but only if you basically have identical pedal pressure and
    driving pattern.
    mcl77, Brie and tyellis513 like this.
  5. Jan 9, 2013 at 6:31 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
  6. Jan 9, 2013 at 6:36 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Depends on driving style if it will work or not. If ECT power is off and you are an agressive driver it will hold a lower RPM/higher gear with more gas, but not going as fast/quick as if you were in a lower gear. Now if grandma were to use ECT power it will not be effective. Because it will a lower gear for no reason.
    davidstacoma and Brie like this.
  7. Jan 9, 2013 at 7:34 AM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    I was experimenting with this today (didn't see this thread prior) and my Ultra Gauge would report a 3-4 real time mpg increase with the button activated. This was traveling o/a 55 mph on flat highway. I know the Ultra Gauge isn't an science but the increase did catch my eye. Thanks.
  8. Jan 9, 2013 at 12:29 PM
    BackCountry
    BackCountry Well-Known Member
    2001 TRD
    Still makes me think the ECT switch could be reversed in some trucks. I've also noticed some quirkyness with the 4x4 and diff lock lights being wrong, so maybe there are a few gremlins in the system. :D
  9. Jan 9, 2013 at 2:17 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I've been driving with ECT on since i got the truck 17 months ago.. I just liked the shift points better with it on. I'll have to test mpg with it off and report back.
  10. Jan 9, 2013 at 2:33 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Maybe "ECT on" also advances the ignition timing slightly? That could produce better MPGs.
  11. Jan 9, 2013 at 2:36 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    *ECT
  12. Jan 9, 2013 at 2:55 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I used to get better mpg with the button on too in my 01. There are probably many different reasons including driving habits that makes this not true for everyone but RPM are really not the biggest determining factor in fuel consumption. Manifold pressure, aka the load on the engine really determines fuel burn. Those of you taco owners with any aviation experience with piston engine aircraft and constant speed propellers (aka always the same RPM) will understand this.
    Basically if your in too high of gear all the time and the engine is struggling, it will decrease fuel economy just as much or more, and is harder on the engine, than running in too low of gear with too high of RPM. People lugging their stick shifts with some illusion of getting better fuel economy are usually wrong. Some people manage to baby the accelerator in too high of gear and the engine electronics are really good at compensating allowing them to squeeze out a few mpg, but that's besides the point.
    The engines have a happy RPM range, this is where they are designed to run and will get the best fuel economy usually. I believe the ECT button allows the truck to stay in the happy zone more easily when driving on the highway. The engine can really struggle to accelerate when the torque converter is locked.
    Brie likes this.
  13. Jan 9, 2013 at 3:13 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I think it seems to be that for around town driving and uphill you should drive with it on, but for highway and long drives it should be off. Just my opinion...
  14. Jan 9, 2013 at 4:51 PM
    TIPICOTACO
    Tyler
    nw nj
    seems like a good conjecture to me. :thumbsup:
  15. Jan 9, 2013 at 4:53 PM
    #35
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Mine sometimes goes up with it on. I use it on windy trips and it helps hold in gears better up hills.
  16. Jan 9, 2013 at 5:05 PM
    #36
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Manifold pressure equivalent to vacuum pressure if i'm reading your post right EDJY and the same way (that show on SPEED network i think) eek'd a few more MPG's out of their Dodge pickup by installing a vacuum gauge and 'coaching' themselves to keep the vacuum in the good zone thus not just flooding the intake stroke with excess fuel.
    Also, i agree that the truck is happier, peppier, and i feel (and will verify for myself) that a slight MPG gain is had with it activated.
  17. Jan 9, 2013 at 10:48 PM
    #37
    goomba
    Josh
    San Antonio Fl
    I thought that was me for a sec
    Brie likes this.
  18. Jan 10, 2013 at 7:05 AM
    #38
    TIPICOTACO
    Tyler
    nw nj
    I tested the ECT today on my drive in to work (25 miles, mixed hills and highway) Using my UG I showed ZERO difference in instant MPG between ECT off/on, but the truck just felt "better" with ECT on. More responsive and smoother shifts in every situation.
    I'l just leave it on..
  19. Jan 11, 2013 at 5:54 AM
    #39
    ywen
    ywen [OP] Well-Known Member
    some dude in japan knows the logic behind this stupid button and is probably laughing at this thread..
  20. Jan 11, 2013 at 10:26 AM
    #40
    chris66
    chris66 ( ͡°( ͡° ͜ʖ( ͡° ͜ʖ ͡°)ʖ ͡°) ͡°)
    dust
    CO
    2004 Prerunner
    bfg at ko2, method double standard
    lol he probably is but im still gonna try it out :p
    originally when i got the truck i thought it was for just when you were towing or carrying a heavy load and needed the truck to hold onto the gears longer ...
    BUT now i know its a fuel saver button;)
