ECT POWER
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacotruck123, Feb 8, 2018.
  1. Feb 8, 2018 at 2:41 PM
    tacotruck123
    tacotruck123 [OP] Member
    South Carolina
    hey guys, I have read a couple threads about the ECT Power button but did not find the answers I was looking for. Does using ECT decrease your gas mileage? I have heard mix responses concerning that. Does it put more wear and tear on your engine? And lastly, can you turn it on and off while driving or do you need to come to a complete stop to allow your transmission to reset? Thank you
  2. Feb 8, 2018 at 2:47 PM
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    Depends, not really, yes you can turn it on and off at will
    over60 likes this.
  3. Feb 8, 2018 at 2:51 PM
    tacotruck123
    South Carolina
    Thank you for the response
  4. Feb 8, 2018 at 2:55 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Of course it burns more gas, it's a performance setting
    over60 and vprgts like this.
  5. Feb 8, 2018 at 2:59 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    Welcome to TW.
    yeah its a mixed bag. if you use ECT when you are loaded and going through hills, you might get better millage since you aren't swifting between gears all the time.
    Wear and tear... not as much as towing, stomping or ORing.
    yeah trigering on the fly is availiable and you do feel the difference almost instantly if you're on the gas.
  6. Feb 8, 2018 at 8:55 PM
    ColdSoda
    ColdSoda Member
    Phoenix, AZ
    17 TRD OR DCSB 4X4
    in progress...
  7. Feb 8, 2018 at 9:54 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    yes. its keeping the engine in a lower gear so higher revs so burning more fuel.
    no. its a transmission setting and even then its just shift points
    yes. push anytime, ill hit it when im about to hit a large grade or want to pass while towing my boat then switch it off when im on a flat area for better mileage.
    over60 and Superman like this.
  8. Feb 9, 2018 at 9:19 AM
    Dee1seven
    Dee1seven Well-Known Member
    RVA
    '17 DCSB TRD OR - Quicksand
    '15 TRD Pro Bilstein Suspension HS 3 leaf AAL TRD PRO Wheels 285/75r16 BFG KO2’s Truxedo Soft Roll Up cover
    I’ve been driving with ECT on 95% of the time the past 3 weeks, I’m actually getting the better mpgs with the ECT on and the drive feels much much better, it’s more responsive.
    Personally I let the transmission get a bit warm before I engage it in the mornings otherwise i feel a bit of harshness between shifts.
    HandsomeTom likes this.
