ECT sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinsdad99, Jul 11, 2020.
  1. Jul 11, 2020 at 6:37 AM
    austinsdad99
    austinsdad99 [OP] Well-Known Member
    1999 prerunner 3.4
    Can a coolant sensor go bad but the ecu still get a reading? My cel popped on today for what I assumed was a intermittent P0420. But it was a P0115 instead. I have a scan gauge and it still read the coolant temp as normal. Nothing weird there. My gauge has always been jacked up on the cluster, and the sensor that reads it has been unplugged for years with no issue. My truck uses 2 sensors one for the gauge and one for the ecu.
  2. Jul 11, 2020 at 9:02 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    It's possible. Do the readings seem normal for am operating engine temp? 190 to 200 degrrees.
  3. Jul 11, 2020 at 9:10 AM
    Glamisman
    Glamisman Well-Known Member
    there are 2 engine coolant temp sensors, one for the temp gauge in the combination meter and one for the fuel injection. The fuel injection temp sensor is usually a 2 wire sensor whereas the gauge temp sensor is one wire. Which one is your scan gauge reading not 100% sure but I would suspect the 2 wire one via the PCM.
  4. Jul 11, 2020 at 9:13 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Have you checked connection and wires at ect sensor?
  5. Jul 11, 2020 at 1:48 PM
    austinsdad99
    1999 prerunner 3.4
    Yes, the scanguage reads the pcm as it's plugged in directly to the obd2 port. It reads temps as normal, 185-193ish. I cleared the code and it comes right back within a minute. The 2 wire up front reads the pcm, wires and plugs all look normal. I just assumed if there was an issue it would run bad or the temp would be way high or way low on the scan guage... It the factory sensor it appears.
  6. Jul 12, 2020 at 1:09 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    To set that code the ecm sees an open or short for 0.5 seconds. Possibilities are the sensor, the wires or the ecm.
  7. Jul 12, 2020 at 4:20 AM
    austinsdad99
    1999 prerunner 3.4
    I’m gonna order a new one and go from there.
    mechanicjon and Black DOG Lila like this.
