ECT Stealth PRO shift knob
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Mar 8, 2019.
  1. May 5, 2020 at 7:36 PM
    #2381
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    @Greg's Outdoors in other words, in order for that to work, you'd have to hold the ECT button down the whole time
  2. May 5, 2020 at 7:39 PM
    #2382
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    AKA figure out something else to tie to the second stealth switch connection....or get a latching relay setup.
    Now to figure out what I have that could be tied into this slick mod
  3. May 5, 2020 at 7:41 PM
    #2383
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Look back in the thread. There's a module that'll do it.
  4. May 5, 2020 at 8:15 PM
    #2384
    TacoTaco-BurittoTaco
    TacoTaco-BurittoTaco Well-Known Member
    James
    Georgia
    2023 TRD Off-Road DCSB
    Stock
  5. May 5, 2020 at 9:51 PM
    #2385
    CP40
    CP40 Well-Known Member
    Toyota Tacoma TRD off-road 2020
    Texting millennials have become immune to the normal range of car horn blasts. Burrito-Taco may be right, air horns maybe no longer a novelty mod for jerk-offs but necessary safety feature.
    Not that there's anything wrong with millennials... NOT THAT THERE'S ANYTHING WRONG WITH MILLENNIALS.
    Let me know when you have the wiring diagram sorted out Burrito-Taco.
    TacoTaco-BurittoTaco likes this.
  6. May 5, 2020 at 10:18 PM
    #2386
    James
    Georgia
    Stock
    Will do, most states outlaw them on their decibel levels but I would rather get a ticket then get wrecked again.Will do.
  7. May 5, 2020 at 10:31 PM
    #2387
    CP40
    Right on. Tell us which air horn you decide is best to.
  8. May 5, 2020 at 10:33 PM
    #2388
    James
    Georgia
    Stock
    No worries, Kleinn just finished doing a beta test for the new Tacoma and others. June is supposed to be when they will release one so I’m waiting to see what they product. They have great quality.
  9. May 6, 2020 at 8:23 AM
    #2389
    bill7549
    bill7549 Well-Known Member
    Bill
    2018 Tacoma TRD Pro Cavalry Blue
    Predator pro steps Victory 4x4 Blitz winch bumper WarnVR EVO 8-S winch
    No, this is what they call a momentary switch. Here's a quote off the web: "Momentary switches are switches which only remain in their on state as long as they’re being actuated (pressed, held, magnetized, etc.). Most often momentary switches are best used for intermittent user-input cases; stuff like reset or keypad buttons."
    Rainoffire and DSRamsey13 like this.
  10. May 6, 2020 at 9:05 AM
    #2390
    CP40
    And yet you don't hold down the ECT button. You press it once and it's on. You press it again to turn it off. I'm sure you're right and I'm missing something. I'm just not an electrician.
  11. May 6, 2020 at 9:07 AM
    #2391
    CP40
    The parking assist is exactly the same. You press it once and it's on. You have to press it again to turn it off.
    Greg.Brakes.Tacos likes this.
  12. May 6, 2020 at 9:34 AM
    #2392
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I thought the parking assist was like the qi charger.
  13. May 6, 2020 at 10:10 AM
    #2393
    CP40
    Maybe it doesn't stay depressed. I see the difference now.
  14. May 6, 2020 at 10:22 AM
    #2394
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    The ECT and Parking Assist buttons are still momentary switches but the functions they control do not require constant voltage to operate; they're toggles. You're likely just sending a signal to the ECU or some other component that will use a software latch. That's how I understand it. Not an electrician.
    Rainoffire and Greg.Brakes.Tacos like this.
  15. May 6, 2020 at 10:39 AM
    #2395
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    So regardless of a relay or working directly with the yellow and white wiring within the 2nd Stealth button...can anyone source a diagram or information on what wires are what for the park assist button/wire harness?? Then, hypothetically, it could be tested either with a relay or directly wired (hot and ground from harness to stealth wiring harness hot and ground).
  16. May 6, 2020 at 11:00 AM
    #2396
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Work it out on your own. Test the wires directly. One will be for the lighted portion of the switch and one for the load side of the switch. Easy enough to find the dimmer wires because they'll change with the headlight function.
  17. May 6, 2020 at 12:12 PM
    #2397
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    Testing will end up something like this...https://www.youtube.com/watch?v=NovCph2fMWU
    No multimeter at the house...and I have like 8 friends of 20+ years that are electricians and electronics techs...shameful!
  18. May 6, 2020 at 12:13 PM
    #2398
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    And you'll also need to take into consideration the amount of current you're going to have running through that switch... it's not rated very high (1A, I believe).
  19. May 6, 2020 at 12:18 PM
    #2399
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    SUM OF A BITCH, I mean SCIENCE!!!:rofl:
    DSRamsey13[QUOTED] likes this.
  20. May 6, 2020 at 8:45 PM
    #2400
    CP40
    I'm with Greg. I figure in the vast collective knowledge of Tacoma World someone should know this. But if not...images.jpg
    ... what color wire you going to cut Greg?
    58electricman likes this.
